08-06-2010, 19:01 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Turkey Age: 38
Member: 148781 Status: Offline Sonork: 100.1620312 Thanks Meter: 20 | connection error??? i repaired one of them succesfully. but i see connection error on the other phone. Code: Searching for phone... found Motorola Phone (E1000M), getting test interface... AT command error This error is possible during phone turning on, you may try <Search> once again socket is clear. no problem. but when i checked it on flash mode. i realized something strange. Code: boot loader 0.6.1.2 sw version: R26LD_U_83.38.38.04.01P Battery ok ok to program transfer mode: serial rs-232 i checked the phone menu. but i couldnt find any option for chAnging transfer mode. the phone which works without any connection problem. Code: boot loader 0.6.8.4 sw version: R26LD_U_83.38.38.04.01P ok to program transfer mode: USB |
08-07-2010, 08:23 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ saidgoren, In most cases AT Command error shows that the user code it enabled and the set can not be read properly. Try to read phone information with SCout flasher and perform Master Reset/Master Clear procedures. Alternatively you can try to perform the following: 1. power on the phone with any SIM 2. when it asks for user code, press MENU button 3. then it will ask for security password, enter 000000 and press OK (000000 - default security password. It might not be accepted, in case it was modified by user) 4. now you should be able to perform a Master reset & Master clear from the menu. Best Regards GSMServer team |
The Following User Says Thank You to GSM_Support For This Useful Post: |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
Nokia Datasuite Connection Failure | Judesp | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-27-1999 09:36 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
