04-03-2006, 12:58 | #1 (permalink) |
Freak Poster Join Date: Mar 2002 Location: bucharest
Member: 9843 Status: Offline Thanks Meter: 2 | a1000 boot 01.02.11 dead ( shows 3g and dies ) after unlocking with test point i have a moto a1000, with boot 01.02.11. phone was ok in the beginning and after successfully unlocking it with smart clip and tp ( unlock ok message in sc window ), phone shows motorola 3g and powers off. what to do please thanks ps i cannot flash it with rsd ( i get error erasing subscriber unit ) and i have not found full flash for smart clip thanks |
04-03-2006, 13:48 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | Hello codec_romania, You can try to find *.shx file and flash it in PC mode. If that will not help than probably You have damaged the phone during Tespoint procedure. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com Last edited by Mr.Tinkertrain; 04-04-2006 at 14:04. |
04-03-2006, 14:03 | #3 (permalink) |
Member: 9843 Status: Offline Thanks Meter: 2 | more details about this a1000 i tried to write back the security area and first time i powered on the phone, it worked ok but was not unlocked. now, after powering it again, it s not working again not even after i write pds back up i really dont know what to do suggestions pls? mihai Last edited by codec_romania; 04-03-2006 at 14:15. |
04-16-2006, 16:25 | #4 (permalink) | |
No Life Poster Join Date: Aug 2004 Age: 47
Member: 76257 Status: Offline Thanks Meter: 77 | Quote:
04-16-2006, 17:07 | #5 (permalink) |
No Life Poster Join Date: Feb 2003 Location: albania Age: 52
Member: 22586 Status: Offline Thanks Meter: 36 | Soldering TP wires is NOT suggested at all. In the case of A1000, you solder only the one side of the TP, on the board, while the other side, on the resistor, must not be soldered. If you have soldered both sides, then check the resistor. It must be damaged. If you haven't soldered wires, then problem can be repaired by full flashing. There are some threads in this forum, that can help you. BR Mike |
04-17-2006, 05:10 | #7 (permalink) | |
04-17-2006, 19:11 | #8 (permalink) | |
do not work key mc60 after unlock with test point | 123darius | Siemens Hardware Repair Area | 24 | 12-11-2007 17:51 |
a1000 boot 01.02.02 dead ( shows 3g and dies ) | codec_romania | Motorola P2k | 0 | 10-19-2006 08:49 |
I unlocked a1000 boot 01.02.11 | :::GsmFather::: | Smart-Clip | 11 | 02-01-2006 16:13 |
A1000 bootloader 01.02.11 unlock with smart clip 2.18 | gabrielgsm | Motorola P2k | 1 | 11-27-2005 22:08 |
A1000 bootloader 01.02.11 unlock with smart clip 2.18 | gabrielgsm | Smart-Clip | 0 | 11-27-2005 14:33 |
