Test Jig on MyV65 Hi, I received today my dongle and test boxes from completegsm. Worked fine on unlocking myx2s, then I tried a myv65 on. Connected all up, np. Went to detect phone Np, and then went to unlock but "reboot phone". I checked the pcb for dirt/glue and there was nothing on the board, checked the test point adapters were not jammed and they were fine. When it was connected, i noticed that the test point going to DB9.2 is 1mm off the actual point and is touching the pcb. I put a bit of solder on the point and trailed it off, and it worked. Has anyone else experienced these problems? Or is it a one off case? Thanks in advance John |
i had same problem with my myx2 test jig, i just had to resolder all the pins so they all made contact and everything was fine |
Yeh but this one is 1 mm off. You suggest i solder the pin and then bend the whole adapter so it lines up? |
test point sagem myv65 i dont no how to make the test point for sagem myv65 i need the help When it was connected, i noticed that the test point going to DB9.2 is 1mm off the actual point and is touching the pcb. I put a bit of solder on the point and trailed it off, and it worked. Has anyone else experienced these problems? Or is it a one off case? Thanks in advance John[/QUOTE] |
