Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > NEC
Old 03-31-2005, 10:42   #1 (permalink)
oce
Member: 132251
e616v I can't unlock it. Help!!!
Hi,
I have a great Nec e616v, but i can't unlock it.
I downgraded from sv18 to sv17, and i read the codes with NEC3GR, but when i try to unlock it with the codes, nothing happens.
I use Windows XP.
Can you help me?
Thank you.
Old 03-31-2005, 22:19   #2 (permalink)
blinet's Avatar
Member: 17405
Thanks Meter: 287
similar problem
Old 04-02-2005, 11:16   #3 (permalink)
Kotogsm's Avatar
Member: 34261
Thanks Meter: 6
I have same problem
HELP
Kotogsm
Old 04-02-2005, 11:29   #4 (permalink)
patric's Avatar
Member: 8228
Thanks Meter: 133
try with the soft of spunlock using direct unlock
for me work tested in e313
Old 04-03-2005, 22:11   #5 (permalink)
Kotogsm's Avatar
Member: 34261
Thanks Meter: 6
patric ....
I testing this soft but not work for me ...
Kotogsm
Old 04-04-2005, 02:53   #6 (permalink)
Member: 108321
Originally Posted by oce
Hi,
I use Windows XP.
Can you help me?
Thank you.
What lock you want to remove??
Old 04-05-2005, 11:25   #7 (permalink)
freedomizer's Avatar
Member: 123931
I also have similar problem. Also I tried to use an imei unlocker as the program just doesn't communicate, but the phone just doesn't respont to codes either. Soft ver 22
any ideas?
after flash z750 i can't Customize it..help zablander212 SETool2 2 09-20-2008 13:08
A-Z London Atlas map - I've found a cracked version, but can't download it - HELP? magpies Nokia Multimedia 3 10-27-2007 19:43
unlocked 1 e616v but can't unlock onother musa NEC 15 04-16-2005 19:59
R220 after flash is "No service", imei is wrong and I can't change it! help! Firecell VLSI, Conexant, Skyworks and Old Models 10 03-22-2004 11:01
G450 unlock - panaiemi can't unlock it! igor_m Panasonic 3 08-25-2000 13:44
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.12641 seconds with 8 queries
