N-04c NEC MEDIAS Docomo Too Many Patterns Attempts DONE!!! [REFERENCE] Model N-04c Nec Medias Docomo Problem Too Many Pattern Attempts! Hard Reset Procedure Phone Must Be Off Press Volume Up + Volume Down + Power Switch Wait Until Download mode appear Then Press Volume Down System Recovery will Prompt Select Wipe Data/Factory Reset Use Volume Down for Cursor And Volume Up for Select Click Yes to delete all user data "but before to confirm it will need password for recovery" here's the TIPS: Code: Take the second digit Screen Shots http://www.gsmsandwich.com.ph/forum/...cs/warning.gif http://img51.imageshack.us/img51/3403/12152012089.jpg http://img525.imageshack.us/img525/7085/12152012103.jpg http://www.gsmsandwich.com.ph/forum/...cs/warning.gif http://img5.imageshack.us/img5/9305/12152012117.jpg http://img51.imageshack.us/img51/4743/12152012121.jpg enter your 4 digit password will find at the back of phone http://img832.imageshack.us/img832/8255/12152012122.jpg it will prompt when your password is correct (just click "YES" to reset) http://img715.imageshack.us/img715/2017/12152012126.jpg Finished Product http://img442.imageshack.us/img442/2797/12152012130.jpg http://img715.imageshack.us/img715/3264/12152012136.jpg http://www.gsmsandwich.com.ph/forum/...cs/warning.gif http://img843.imageshack.us/img843/1875/12152012138.jpg this 4 digits marked in red must be your password http://www.gsmsandwich.com.ph/forum/...cs/warning.gif http://img141.imageshack.us/img141/2316/12152012139.jpg :cool: BR, |
Nice information it really work like charm 10000000000000% Tested! the only mistake is the step after recovery, it is actually the ''VOLUME UP'' u need to press b4 u can see the wipe data/factory reset screen, not the volume down. But he did great. Best Regard! |
Tnx this is a real work 1000000000% tnx |
How did you find this out? I have an NEC terrain that has the same requirement for a passcode. I've tried this method and it doesn't work. I know the Medias is made by NEC as well. Appreciate any guidance, thank you. |
how can i found password i triyed 1234.123456.11111111.123456789.0000.00000.00000 but no result what can i do for found my password? |
I even know my gmail username and password, and entered that, and it still doesn't unlock. Has anyone managed to recover from too many pattern attempts on the NEC terrain? Thanks. |
the link you gave does not open, is there any other link |
What you have to do is remove the battery, copy the IMEI somewhere... Then If your IMEI is:0123456789abcde Then your recovery Password is:1bcd |
it's working. |
Great job thanks ;) |
Thanx its work 1bcd |
thanks dear it's working 1000000000000000000%%%%%%%%% |
I have this phone needing network unlock. How do I go about it? |
