11-05-2009, 14:56 | #91 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1154398 Status: Offline Thanks Meter: 0 | can somene help me unlock my nec 804N for free???? tell me what am i supposed to do????plleeaassssee.......email me please,, [email protected] tnx in advance |
12-27-2009, 12:13 | #93 (permalink) |
Freak Poster Join Date: Oct 2005 Location: FREETOWN- SIERRA LEONE
Member: 194431 Status: Offline Thanks Meter: 22 | nec338 v0.4 i also have the same problem but im trying to downgrade it to v0.3 after which i will do unlock by the way do anybody have solution for v0.4 unlocking as downgrading is really difficult and does not take effect some nec |
03-28-2010, 20:21 | #94 (permalink) |
Insane Poster Join Date: Jan 2007 Location: Jessore,Bangladesh Age: 47
Member: 430450 Status: Offline Thanks Meter: 7 | Vodafone 802N by NEC can Unlock? very urgent please. Regards Ferdaus Last edited by Ferdaus; 03-28-2010 at 20:22. Reason: Some text missing |
11-07-2010, 04:02 | #95 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1436983 Status: Offline Thanks Meter: 0 | Hi, I know this thread is a bit old and I am taking my chances here. I really badly need to have the "e313 PC File Transfer Tool". I managed to find the driver but now I am missing the transfer tool to save a few videos that I captured on my e313 nec phone a very long time ago. Thanks, your help will be most appreciated |
02-01-2021, 12:29 | #99 (permalink) |
Crazy Poster Join Date: Feb 2013 Location: London
Member: 1889126 Status: Offline Thanks Meter: 2 | Unlock NEC E808 successful, kind of I have spent the last couple of weeks combing through this forum trying to get 3 E808 devices unlocked. I made my own serial cable, no luck. I modified a RJ45 cable to use with my Furious Gold box, no luck. The only solution was to modify a serial E350 serial cable. Just looked up the pinout of the cable and took Ground , TX and Rx from it. There is no normal cable solution, only Test point like this: I tried the NEC WCDMA Exxx tool but it din to work for me. Tried it with both Windows XP and 98. The connection is correct because the phone software version is recognised but when I hit Unlock I only get "****, something wrong..." message. I tried different cables here with both test points but no luck. Then I tried Furious NEC with TP at the 5V point as shown in the photo. The procedure is this: Sim card out, serial cable in with 9V battery connected, Battery in, click Unlock, when program says Press PWR, hold the phone's power key until the program says Remote battery, then disconnect the phone battery and is unlocked. Here is what il looked like: Before unlock the phone was stuck at the start screen saying USIM Reading data if a Three SIM was inserted or Incorrect SIM if other SIMs were tried. Now is unlocked but only very old 2G Sims will let the phone boot up. Per example I have a very old Orange SIM that works, but if I put a more recent Orange one that says 3G on it, it will be stuck at Reading data.. Now I noticed in the phone's menu in the Networks section, there is a list with old known networks like Orange, BT Mobile etc. I think that when a SIM is inserted, the phone will try to find the SIM ID in that list and if it's not there it will get stuck. I think since 2003 the network ID got changed and that list is obsolete. There is an option to add more networks to the list using the MCC and MNC codes for your specific SIM. I tried that but still can't get past the boot screen with any modern SIM. So even though the phone is unlocked, it can't be used unless you still have an active SIM card from 15 years ago. It is an improvement though. Now you can use the device and it's features, apart from phone calls and texts, if you have some old SIM. Before it was just stuck at the boot screen, so I guess it's something. Was it worth all the hours and brain damage it took to do this? Not really. Download the Furious NEC program here: https://drive.google.com/file/d/1Ok9...w?usp=drivesdk |
02-01-2021, 23:54 | #100 (permalink) |
Member: 1889126 Status: Offline Thanks Meter: 2 | Upon reading a bit about SIM card history, it looks like the E808 phone is scanning for a card in USIM format. The problem is that most networks nowadays use a UICC format which acts both as SIM and USIM, but this phone is unable to figure that out and keeps trying to read the USIM. Oh, well... |
3G NEC 3G Unlock success... 1st time with FREE sw.. | maxmix | NEC | 50 | 02-22-2007 09:37 |
Nec 3g Unlocker - V22/24, Reset Counter, Direct Unlock | techgsm | Main Sales Section | 0 | 02-08-2005 00:22 |
Problem With Nec 3g Unlocker/multi Unlocker | lemor | FuriouS II | 0 | 02-03-2005 12:12 |
nec 3G unlocking codes .... | crossings | NEC | 15 | 11-29-2004 15:07 |
Nec 3g Unlocking North West | nadger | Main Sales Section | 0 | 11-12-2004 23:08 |
