03-05-2005, 18:50 | #1 (permalink) |
Junior Member Join Date: Feb 2005 Age: 42
Member: 115885 Status: Offline Thanks Meter: 0 | nec c616 unlocked with direct unlocker, but will not dial out Also super code reader V1.6 will not read the correct codes from SW22 on 616 nec's. Has anyone had the same problem. Please post below. Thanx! |
03-05-2005, 21:29 | #2 (permalink) | |
No Life Poster Join Date: Nov 2004
Member: 91102 Status: Offline Thanks Meter: 34 | Quote:
press *#06# and u will see that the imei will start with 00xxxxxxxx if u will read regularly then u will see in some posts about using a direct unlocker that use it only for the phones with blocked counter for the rest always use code reader for sw22 use the downgrading solution and use the free code calculator for downgrading just search in forum for flashfiles br | |
03-09-2005, 10:51 | #4 (permalink) | |
Junior Member Join Date: Mar 2005 Age: 42
Member: 123152 Status: Offline Thanks Meter: 0 | Quote:
Who have unlocked succesfully nec 331i with direct unlock? | Uvedovle | Redbox | 0 | 02-06-2006 19:11 |
unblock nec e616v with direct unlocker | James-R | NEC | 3 | 04-08-2005 15:42 |
NEC e616 will not dial out | jamiebrett | NEC | 1 | 09-23-2004 17:32 |
