05-13-2013, 09:16 | #2 (permalink) |
No Life Poster Join Date: Oct 2009 Location: FuriouSGold Age: 18
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | It's qualcomm processor. May be possible to unlock through PACK7 but at the moment I doubt as it's not in the supported list models |
05-16-2013, 08:51 | #4 (permalink) |
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | We will work on it but can't be done in a couple of days, also will ask hack3r2k about the request of the device |
The Following User Says Thank You to FTEAM_MODERATOR For This Useful Post: |
04-01-2014, 15:34 | #9 (permalink) |
No Life Poster Join Date: Sep 2005 Age: 41
Member: 185279 Status: Offline Thanks Meter: 43 | Unlock Huawei Daytona Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Uploading bootloader... OKOK Starting bootloader... OK Disconnecting from server... OK Initializing flash... OK Reading phone info... OK Decrypting IMEI... OK Reading sensitive data... OK Reading bootloader lock status... OK Model name: Huawei MSM8X25 series IMEI: xxxxxxxxxxxxxxx Bootloader status: locked SIM Lock status: locked (NCK lock) 2014-04-01 09:31:58.453 Start unlocking procedure (xxxxxxxxxxxxxxx) Connecting to server... OK Sending data to server... OK Reading data from server... OK Checking bootloader status... OK Initializing flash... OK Reading phone info... OK Decrypting IMEI... OK Reading sensitive data... OK Creating backup of Sensitive Data... OK Sending data to server... OK Reading data from server... OK Writing flash... OK Reseting unblock retry counter... OK Sending data to server... OK Reading data from server... OK Disconnecting from server... OK 2014-04-01 09:32:10.781 Done! Unlock done =) |
05-08-2014, 10:03 | #10 (permalink) |
Junior Member Join Date: Jul 2009 Location: Multan Pakistan
Member: 1084460 Status: Offline Sonork: 1609589 Thanks Meter: 11 | hi gays unlock done with fg done 10000000000000000000000%%%% done HUAWEI ANDROID UNLOCKER v1.00.0058 Searching Huawei phone COM ports... OK Application port: COM114 Diagnostics port: COM115 Driver version: 2.0.6.601 OEMSBL running: 8X25-2030-SSNSKOLYM Checking bootloader status... not running! Connecting to server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Uploading bootloader... OKOK Starting bootloader... OK Disconnecting from server... OK Initializing flash... OK Reading phone info... OK Decrypting IMEI... OK Reading sensitive data... OK Reading bootloader lock status... OK Model name: Huawei MSM8X25 series IMEI: 868038016304942 Bootloader status: locked SIM Lock status: locked (NCK lock) 2014-05-08 14:01:12.941 Start unlocking procedure (868038016304942) Connecting to server... OK Sending data to server... OK Reading data from server... OK Checking bootloader status... OK Initializing flash... OK Reading phone info... OK Decrypting IMEI... OK Reading sensitive data... OK Directory "H:\FURIOUS_GOLD\Pack 7\HUAWEI_ANDROID_UNLOCKER_0034\HUAWEI_ANDROID_UNLO CKER_0034\Backup" not found! Creating backup directory "H:\FURIOUS_GOLD\Pack 7\HUAWEI_ANDROID_UNLOCKER_0034\HUAWEI_ANDROID_UNLO CKER_0034\B ackup"... failed! Backup directory set to default! ("D:\FG\Pack 7\Backup")OK Creating backup of Sensitive Data... OK Backup saved to file "D:\FG\Pack 7\Backup\868038016304942_2014-05-08_140119.fhb" Sending data to server... OK Reading data from server... OK Writing flash... OK Reseting unblock retry counter... OK Sending data to server... OK Reading data from server... OK Disconnecting from server... OK 2014-05-08 14:01:21.660 Done! |
