.:hack3r2k:. | 05-12-2017 08:18 | 12/05/17 SPDTool v1.0.0.3023 - WILIKE / LIKE 3G+ DUO / NYX-XYN 307 / IPLUS I3 - W1ST http://static.furiousgold.com/_files...s_big/3023.jpg SPD SERVICE TOOL - Update 1.0.0.3023
Added: - WILIKE 3G+ DUO - UNLOCK VIA PATCHED FLASH - WORLD FIRST (rest of the operations already supported)
- LIKE 3G+ DUO - UNLOCK VIA PATCHED FLASH - WORLD FIRST (rest of the operations already supported)
- NYX 307 - READ-WRITE FLASH / FORMAT / REPAIR IMEI ETC /UNLOCK VIA PATCHED FIRMWARE - WORLD FIRST
- IPLUS i3 - READ-WRITE FLASH / FORMAT / REPAIR IMEI ETC /UNLOCK VIA PATCHED FIRMWARE - WORLD FIRST
NEW FILES: - NYX_XYN_307_EN_FR_ES-2PATCHED.spd
- IPLUS_I3_EN_FR-2PATCHED.spd
- TELMA_K1_EN_FR-2PATCHED_NEW.spd
- 2051X-3[X=B]TBHU1_EN_HU_CZ_RO_PL_SK-2PATCHED.spd
LIKE 3G+ DUO FULL FLASH FILES: - LIKE 3G-DUO_P1911_BAND18_ZZW_SC7701_EF_DUAL_20150117.spd
- LIKE 3G-DUO_P1911_BAND18_ZZW_SC7701_EF_DUAL_20141202_EN_FR .spd
- LIKE 3G-DUO_P1911_BAND18_ZZW_SC7701_EF_DUAL_20150617_EN_FR .spd
- LIKE 3G-DUO_P1911_BAND18_ZZW_SC7701_EF_DUAL_2016_EN_FR.spd
- LIKE 3G-DUO_P1911_BAND18_ZZW_SC7701_EF_SINGLE_20141107_EN_ FR.spd
- LIKE 3G-DUO_P1911_BAND18_ZZW_SC7701_EF_DUAL_20150617_b100_ EN_FR.spd
LIKE 3G+ DUO PATCH FILES: - LIKE 3G-DUO_P1911_BAND18_ZZW_SC7701_EF_DUAL_20141202_EN_FR _PATCH.spd
- LIKE 3G-DUO_P1911_BAND18_ZZW_SC7701_EF_DUAL_20150617_EN_FR _PATCH.spd
- LIKE 3G-DUO_P1911_BAND18_ZZW_SC7701_EF_DUAL_2016_EN_FR_PAT CH.spd
- LIKE 3G-DUO_P1911_BAND18_ZZW_SC7701_EF_SINGLE_20141107_EN_ FR_PATCH.spd
- LIKE 3G-DUO_P1911_BAND18_ZZW_SC7701_EF_DUAL_20150617_b100_ EN_FR_PATCH.spd
- LIKE 3G-DUO_P1911_BAND18_ZZW_SC7701_EF_DUAL_20150117_PATCH .spd
WILIKE 3G+ DUO FULL FLASH FILES: - WI-LIKE 3G-DUO_ZZW_telma_K88_BAND18_V08_20151207_EN_FR_PT_MYA NMAR.spd
- WI-LIKE 3G-DUO_ZZW_telma_K88_BAND18_V08_20151111_EN_FR_PT_MYA NMAR.spd
- WI-LIKE 3G-DUO_ZZW_telma_K88_BAND18_V08_20151011_EN_FR_PT_MYA NMAR.spd
- WI-LIKE 3G-DUO_ZZW_telma_K88_BAND18_V08_20151111_b100_EN_FR_P T_MYANMAR.spd
WILIKE 3G+ DUO PATCH FILES: - WI-LIKE 3G-DUO_ZZW_telma_K88_BAND18_V08_20151111_EN_FR_PT_MYA NMAR_PATCH.spd
- WI-LIKE 3G-DUO_ZZW_telma_K88_BAND18_V08_20151111_b100_EN_FR_P T_PATCH.spd
- WI-LIKE 3G-DUO_ZZW_telma_K88_BAND18_V08_20151207_EN_FR_PT_MYA NMAR_PATCH.spd
- WI-LIKE 3G-DUO_ZZW_telma_K88_BAND18_V08_20151011_EN_FR_PT_MYA NMAR_PATCH.spd
HOW TO UNLOCK WILIKE 3G+ DUO / LIKE 3G+ DUO
1. Download latest version of SPD TOOL module
2. Select the correct model (WILIKE 3G+ DUO / LIKE 3G+ DUO)
3. Check the sticker under the battery for the correct release date of the firmware installed in the phone
4. Get from the support the PATCH file having the same date as the one found on the sticker. You can
consult the images bellow for the details. If the file is not available then read the flash from the phone and send it
to us or simply reflash the phone with the full flash files available on the support and use after the correct PATCH file for it.
5. If anything goes bad after writing the PATCH file (WHITE SCREEN / HANG) then simply reflash the phone with the full flash files available on the support and use after the correct PATCH file for it. http://static.furiousgold.com/_files...big/wilike.jpg http://static.furiousgold.com/_files...s_big/like.jpg
best regards,
FuriouSTeaM |
