05-29-2020, 16:11 | #1 (permalink) |
No Life Poster Join Date: Apr 2004 Location: POland
Member: 60746 Status: Offline Thanks Meter: 56 | alcatel 2019g connect problem [SOLVED] For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly the boot key 3. Insert the usb cable inside the phone while keeping pressed the boot key Phone detected (@oem258.inf,%dvcdsc%;SCI USB2Serial) (Driver version: ) Preparing to sync; Port opened [COM45]; i tried to write firmware ...... Last edited by zaskar; 05-29-2020 at 16:13. Reason: phone powered on after while and nothing else |
The Following User Says Thank You to zaskar For This Useful Post: |
05-29-2020, 16:46 | #2 (permalink) |
Member: 60746 Status: Offline Thanks Meter: 56 | after restart comp - everything is ok Port opened [COM45]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.2 Starting FDL2; FDL2 sent; Chip type: 6562:0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00EF:0060:0018 - SIZE : 01000000 [00003182369B588A:0000] Reading phone info; PHONE INFO: 2019G-3AALGB1 BT ADDR: 619:41:33:9E:88 SW IMEI[0]: 355992-10-032893-8 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 10EE0000 Uncompressing; Done; Re-programming; ......... |
11-04-2021, 12:20 | #3 (permalink) |
Crazy Poster Join Date: May 2011 Location: Romania Age: 37
Member: 1582886 Status: Offline Thanks Meter: 6 | how to flash alcatel 2019g with nck spreadtrum ???? fails absolutely.... I also tried it with the latest software and I tried it with the old as well EXE: NckDongle Spreadtrum Module 1.1 SELECTED : SC6531 ACTION: Unlock. SCENARIO: SC6531. Start Detect phone... Detected: SPRD U2S Diag (COM12) First loader start fail, aborting. Error boot, aborting. Total Time: 00:00:10 Done. |
11-04-2021, 13:52 | #4 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
This is Furious section. You should go on their section and ask Br | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
