03-06-2020, 10:57 | #1 (permalink) |
Freak Poster Join Date: Mar 2000 Location: Romania Age: 51
Member: 1155 Status: Offline Thanks Meter: 11 | Alcatel 2053D no service after flash! [SOLVED] A customer ask me to put romania language on alcatel 2053D, version 2053D-2AALIB1. There was 50 phones. I tested first 2-3 phones and seems to be ok with firmware from suport. Now the phones are with "no service" message on screen. I made factory reset, write initial firmware .....nothing change, only "no service" message on screen. Any ideeas? Best regards, DanV |
03-06-2020, 10:58 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
Because must repair the imei after for secured devices. Br Sent from my iPhone using Tapatalk Pro | |
03-06-2020, 12:03 | #6 (permalink) |
Member: 1155 Status: Offline Thanks Meter: 11 | Thx for quick answer! I will post here the results. Just on question I have :-). Phones are dual sim, on the back label are 2 imeis, normaly. But software read 4 imeis. Which one of them I must repair, the first 2, on the label or more? look here a log for example: Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.2 Starting FDL2; FDL2 sent; Chip type: 6562:0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 [0000410544995A29:0000] Reading phone info; PHONE INFO: 2053D-2*ALIB1 BT ADDR: 2B:F6:71:2E:E6:E0 SW IMEI[0]: 359162-09-008493-5 SW IMEI[1]: 359162-09-008494-3 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: OFF FIXED NV BASE: 103B8000 Best regards, DanV |
03-06-2020, 12:04 | #8 (permalink) | |
First two Sent from my iPhone using Tapatalk Pro | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
09-29-2020, 16:07 | #9 (permalink) |
Freak Poster Join Date: Sep 2005
Member: 179938 Status: Offline Thanks Meter: 57 | i have 2053x have same issue. even imei repair still no service. Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.2 Starting FDL2; FDL2 sent; Chip type: 6562:0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000 [00001201529A1004:0000] Reading phone info; PHONE INFO: 2053X-2*OFUS1 BT ADDR: 2B:F6:71:2E:E6:E0 SW IMEI[0]: 359161-09-276623-4 SW IMEI[1]: 359162-09-008494-3 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: OFF FIXED NV BASE: 103B8000 Reading NV; NV saved to : NV_000000-00-000000-0_359161-09-276623-4_65620000_29_09_2020_10_02_19.spd Re-programming; NV programmed; Done; IMEI[1] repaired; Remove battery and cable; Log file saved to: LOG_29_09_2020_10_02_56.txt |
09-30-2020, 19:01 | #12 (permalink) | |
Did you actually checked it had signal before !? What its the provider id from the back sticker ? Sent from my iPhone using Tapatalk Pro | |
10-01-2020, 07:47 | #14 (permalink) |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Ok so as i understand phone had no service from start right ?! Have you tried writing 2053X-2[X=A]OFUS1_EN_FR_BRAZILIAN_LATINESP.spd ? Br |
