alcatel 4015x unlock problem [SOLVED] here is alcatel says unlock but still aske for unlock code Using library Brom_DLL_v7.1413.5 Connecting; Be sure you unlock the phone screen; BRAND: ORANGE MODEL: ONE TOUCH 4015X ANDROID: v4.2.2 CPU: MT6572 IMEI: 865910023958352 Trying to get root access; Done; Reading simlock data; Done; Locked to [SIM1]: 234-30 code_cat_n: 1542410261 enabled: yes tries: 10 code_cat_ns: 0702097285 enabled: no tries: 10 code_cat_sp: 3554675691 enabled: no tries: 10 code_cat_c: 2874899425 enabled: no tries: 10 code_cat_sim: 0705887280 enabled: no tries: 10 code_cat_ns_sp: 2805475523 enabled: no tries: 5 code_cat_sim_c: 2713801015 enabled: no tries: 5 Cleaning; Calculating; Reconnecting; Trying to get root access; Done; Unlocking; Done; Phone unlocked; Remove battery and cable; Time needed - 00:00:50 |
Because wrong model selected. Must SELECT OT-4015. Not OT-4015T Br;) |
ok il do that next if an other one will come thanks |
Hi guys I am having problems to flash alcatel 4015x, it shows as the process was succefull but after all is done the phone canīt be turn on I tried with another phone and I unlock it without problem but again same problem when try to flash please help |
Use 4015X-2[X=A,C,G]RGRO3.osp Br;) |
done, thanks for your help ;) |
