06-17-2015, 21:20 | #1 (permalink) |
Freak Poster Join Date: Jul 2010 Location: soudi arabia
Member: 1339076 Status: Offline Thanks Meter: 30 | alcatel 2067x unlock fail pls help [SOLVED-UNLOCKED] Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: MAUI.11A.W11.12.SP1.V14.F20 Hw Version: JRD76_11A_GEMINI_HW Reading phone info; ERROR: IMEI READ FAILED ! Time needed - 00:00:11 |
06-17-2015, 23:36 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,569 | Quote:
Br | |
06-17-2015, 23:53 | #3 (permalink) |
Member: 1339076 Status: Offline Thanks Meter: 30 | i try otz flasher Using library Brom_DLL_v5.1316.1 COM opened ok; Press power and keep it pressed now ! Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: MAUI.11A.W11.12.SP1.V14.F20 Hw Version: JRD76_11A_GEMINI_HW Reading phone info; ERROR: 11 Time needed - 00:00:13 |
06-17-2015, 23:55 | #4 (permalink) |
Member: 1339076 Status: Offline Thanks Meter: 30 | phone switch off press star butten and i connect via usb cable me get mtk usb port i slect ot-2001 and press connect butten after get thies log in the model slect section cant find 2067x |
11-09-2015, 01:21 | #9 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Treasure Island of the pacific
Member: 168090 Status: Offline Thanks Meter: 92 | Using library Brom_DLL_v5.1316.1 COM opened ok; Press power and keep it pressed now ! Requesting authorization; Done; Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: MAUI.11A.W11.12.SP1.V14.F20 Hw Version: JRD76_11A_GEMINI_HW Reading phone info; IMEI: 356789-06-0432XXX-X Reading; Reading security; ERROR: Reading failed; Please retry; Time needed - 00:00:14 Not working on me too., I'm using the latest OTZ flasher br -blu |
11-09-2015, 13:13 | #10 (permalink) | |
Br | |
11-12-2015, 09:57 | #12 (permalink) |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,569 | Then probably some diff fw version. You have 2 possibilities 1. Contact me on skype so i can add this fw support 2. Flash the phone using files from the support /FLASH FILES/ALCATEL/ALCATEL [PACK6]/OT-2067 and unlock after |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
04-07-2016, 14:57 | #14 (permalink) | ||
Freak Poster Join Date: Jan 2014 Location: india
Member: 2111064 Status: Offline Thanks Meter: 21 | Quote:
i too have a alcate ot2067 whihc says unlock needs to be done thru serial port! Quote:
wbr atstech. | ||
