Alcatel OT-8050D PIXI 4 6 Flashing Failed Cannot flash checked with 2 versions from support, have ram and free spahe on hdd, but result is this error: sing library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM4)) Preparing to start flash mode; Preparing to open COM4 Connecting; Downloading DA; Initializing; Rid: 287d331b66292bff63c33df8d1cf2f8b Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM16; DEVICE INFO: BB CHIP: MT6580_S00 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x30000111 0x37473830 0xCE640030 0x53C2B92F [SIZE=0x1D2C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 8050D-2BALWE1 USRDATA INFO: 0xB9800000 SIZE: 0x19400000 Loading the file ... Cfg done ... ERROR: S_NOT_ENOUGH_MEMORY Time needed - 00:00:30 Log file saved to: LOG_6_10_2016_14_29_18.txt What must i do to flash this phone? |
what is wrong with your phone ? |
Phone is working and there are nothing wrong, i must change language pack. With factory flasher Sugar_MTP device flashing and update sucesfull, but only version upgrade, there cannot change language pack. |
Check if enough free space on the hdd where the sw runs. If still same contact me over skype to take a look Br;) |
Maby problem is elsewhere, but not in PC and Phone. |
Then lets meet over skype and fix this Br;) |
Also have some problem, need change language: Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM65)) Preparing to start flash mode; Preparing to open COM65 Connecting; Downloading DA; Initializing; Rid: 06c6fed1531bf319832f34abf217aa82 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem113.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM67; DEVICE INFO: BB CHIP: MT6580_S00 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x30000111 0x37473830 0x80A10030 0x07C2CB2C [SIZE=0x1D2C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 8050D-2AALWE1 USRDATA INFO: 0xB9800000 SIZE: 0x19400000 Loading the file ... Cfg done ... ERROR: S_NOT_ENOUGH_MEMORY Time needed - 00:00:17 Log file saved to: LOG_19_10_2016_16_21_37.txt |
Re-download teh ALRU1 flash from support and retry. It was corrupted Br;) |
Having same problem flashing. Used two files and same not enough memory problem. Please help me. More than enough space on HDD |
