08-16-2014, 23:00 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Budapest Age: 54
Member: 87188 Status: Offline Thanks Meter: 227 | 7041D (Pop C7) Connection failed [SOLVED] Using library Brom_DLL_v7.1347.5 Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start flash mode; Preparing to open COM120 ERROR: Connection failed ! ERROR: BOOT_PHONE; official upgrade see, so driver OK , but I want to change language:-( http://mark1.uw.hu/7041.JPG |
08-18-2014, 09:22 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
Drivers aren't properly installed. You can see the procedure here | |
08-18-2014, 11:10 | #3 (permalink) |
Member: 87188 Status: Offline Thanks Meter: 227 | Thanks work:-) Previously, it did everything right, except for the driver mappa: C:/ Thanks! |
The Following User Says Thank You to Pufi164 For This Useful Post: |
10-25-2014, 23:50 | #4 (permalink) | |
Major Poster Join Date: Oct 2007 Location: Fiji
Member: 603172 Status: Offline Thanks Meter: 1 | Quote:
C:\usb_driver\Driver_Auto_Installer\SmartPhoneDriv er\x86\Infs\usbvcom.inf<--- must be a member of the Administrators group to install a driver package UninstallDriverWithWDK Failed. Try another method. SetupDiEnumDeviceInfo Finish. USB\Vid_0e8d&Pid_200a&MI_02 ---Remove Device Failed. Ignore remove file USB\Vid_0e8d&Pid_2000 found in hDeviceInfoSet. SetupDi[Set]DeviceRegistryProperty SPDRP_CONFIGFLAGS Unknown error Ignore remove file SetupDiEnumDeviceInfo Finish. USB\Vid_0e8d&Pid_2006&MI_02 ---Remove Device Failed. Ignore remove file SetupDiEnumDeviceInfo Finish. USB\Vid_0e8d&Pid_2001 ---Remove Device Failed. Ignore remove file SetupDiEnumDeviceInfo Finish. USB\Vid_0e8d&Pid_2007 ---Remove Device Failed. Ignore remove file =====Operation Succeeded===== File Closed. | |
10-26-2014, 10:24 | #5 (permalink) | |
go to the smart driver folder and right click spinstall.exe and run it as administrator Br | |
03-19-2015, 10:11 | #6 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Poland, Sroda Wielkopolska
Member: 608500 Status: Offline Thanks Meter: 32 | hello. i can't flash 7041d look here: Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (@oem73.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start flash mode; Preparing to open COM27 Connecting; Downloading DA; Initializing; Rid: 5b06b58386296d676f2a595463e059cd Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem73.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM28; DEVICE INFO: BB CHIP: MT6582_S00 [CA00, 00, 6582, FF] HW_STORAGE_EMMC: 0x484A0190 0x64314734 0xA3008604 0x1B3169AE [SIZE=0xE7600000] IMEI1 [OTP 0001]: 863581-02-37xxxx-x IMEI2 [OTP 0001]: 863581-02-37xxxx-x PROVIDER: 7041D-2BP3PL1 USRDATA INFO: 0x65880000 SIZE: 0x81D80000 Loading the file ... Cfg done ... Formatting file system now... Done; Downloading bootloader... Done; ERROR: S_DL_PMT_ERR_NO_SPACE Time needed - 00:00:42 phone condition is good , working but hang on logo. how i can repair this? offcourse alreadfy tested on official ubgrade tool. thanks |
