08-09-2007, 10:10 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Computerworld
Member: 240665 Status: Offline Thanks Meter: 94 | BB; sorry only emergency calls are allowed I have a Blackberry 7290 that is trying to give me problems. I unlocked the phone and now phone cannot make calls. When I try making phone calls it writes, sorry only emergency calls are allowed. I have all the necessary settings on calls forwarding, baring and co but still this phone is giving me the same error. I have flashed it but it's still giving me the same error. Is there any other solution one can suggest? Thanks in advance. |
The Following User Says Thank You to babyelephantt For This Useful Post: |
08-09-2007, 10:48 | #3 (permalink) | |
Member: 240665 Status: Offline Thanks Meter: 94 | Thanks Mamirza Quote: | |
08-09-2007, 16:10 | #4 (permalink) |
No Life Poster Join Date: Jun 2006 Location: With You In Mind
Member: 300540 Status: Offline Thanks Meter: 103 | Hi ! Am sure phone must b showing all network ! Try reflash phone. If same phone is barred/sim not supported/band not supported. Visit here ! BR. |
08-09-2007, 16:14 | #5 (permalink) | |
Member: 240665 Status: Offline Thanks Meter: 94 | Did just that but still Quote:
11-21-2007, 16:51 | #7 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: Inside facebook Age: 47
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | Problem is due to IT policy !!! If after reflash your phone still have this problem then try this working solution tested by me many times Quote:
Note: See this post. This is a How-To for removing IT policy from your BB. In essence, what this does is apply a blank IT policy to the device. The blank IT policy does, unfortunatly, leave some IT policy firewalls in place, however. For instance "keystroke injection" is set by default to "deny" on most IT policies. This blank policy won't give back "allow" for this feature. This becomes a problem if you desire to use a Bluetooth keyboard. You'll be unable to use the keyboard. If a way is found to get this back then I'll edit this post accordingly. A quick check to see if your BB is under IT policy can be done by going to Options/Security on your Device. If you see any references to IT Policy whatsoever, then you have a potentially restrictive IT Policy that can be removed. The Disclaimer/Intended Use. This guide is intended for use by people that own their own Blackberry, and for whatever reason, have inherited a company's IT policy on their device. Really, there are two scenarios where this guide is useful. You bought a Blackberry on eBay and are unable to make changes to the settings or install Third Party Applications. You have a Blackberry that was previously connected to a company's BES and, for whatever reason, you no longer intend to connect to that BES. Important: If you're still connected to a company BES, and simply want to install the latest and greatest third party application I would not recommend this approach. Talk to your BES administrators and ask them to grant you the appropriate rights. There are two problems in using this guide to bypass your company's security policy. First, whenever you reconnect to the company server, your security settings will revert back to how they were. Second, and perhaps more importantly, you run the risk of getting fired. Procedure: Step 1 Ensure the Blackberry Desktop Manager is installed using Blackberry Internet Service, and not Blackberry Enterprise Server. If you are unsure, it would probably be a good idea to uninstall the Desktop Manager and start again. If you don't have the CD that came with your Blackberry, the Software can be downloaded here. Step 2 Download the file policy.bin and save it in your Blackberry installation directory (C:\Program Files\Research In Motion\BlackBerry). Step 3 Wipe your Blackberry, creating a backup if necessary. Select Options/Security/Wipe on the Device. If this option is unavailable, you may have to install the latest software on your Blackberry. You need to Download and install the latest OS for your device. Connect your device, open the Desktop Manager, select Application Loader, and follow the prompts. Step 4 Close the Desktop Manager if it is open. Step 5 From the Windows XP Start Menu select Run..., and at the prompt type regedit. In the tree on the left hand side, navigate to: HKEY_Current_Users\Software\Research In Motion\BlackBerry\PolicyManager Right-Click the Policy Manager Folder and select New/String Value. Name the value Path. Now, Double-Click the Path Subkey and set Value Data to: C:\Program Files\Research In Motion\BlackBerry\policy.bin Step 6 Open the Desktop Manager. Step 7 Connect the Device. Verification Once complete, the Options/Security screen on your Blackberry should not contain references to an IT Policy, you should now be able to change all settings (including password prompts), and install Third Party Applications. A big thanks to 7100simpleisbetter and barjohn of BlackberryForums.com for this BB saving procedure. Original thread here Last edited by snsoftkiller; 11-21-2007 at 16:58. | |
The Following 6 Users Say Thank You to snsoftkiller For This Useful Post: |
11-22-2007, 21:47 | #8 (permalink) | |
Freak Poster Join Date: Jan 2006
Member: 226179 Status: Offline Thanks Meter: 12 | Quote:
thank you for your reply.....but i dont know simple instruction ,,its not working fot me....bb 8700 ....trying to check what is my mistake...everything followed per instruction but no luck.... once again .....thank you ferdie | |
11-22-2007, 22:29 | #9 (permalink) |
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | Try again uninstall desktop manager and do step by step you will get it work 10000% Did you download the file policy.bin and copy it in C:\Program Files\Research In Motion\BlackBerry where "C:" is the harddrive where you install the desktop manager ? |
11-23-2007, 18:25 | #10 (permalink) | |
YES...everything was followed...but i dont why..IT POLICY... still in my bb...AND I CAN NOT MODIFY..... THANKS | |
11-24-2007, 01:27 | #11 (permalink) |
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | Wipe your handset, check if you copy the policy bin in the right folder. Reinstall the desktp manager and again follow step by step. I test it many times !!! |
12-07-2007, 11:04 | #14 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Surabaya
Member: 247433 Status: Offline Thanks Meter: 25 | and how Furious can Unlock the Phone ... Try to explain this ... what i got is ... BBPIN: 40104774 Detected: RIM 7500 Series iDEN Handheld Platform version: 1.4.0.48 Invalid device reply during unlock codes request. Time needed - 00:00:01 ----------------------------------------------- for : blackberry 7520 Wireless hand held v. 4.2.37 ???????? |
12-07-2007, 14:46 | #15 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Br | |
8310 show sorry only emergency call are allowed | kabirhossain | BlackBerry (RIM) | 55 | 01-24-2015 19:03 |
BlackBerry 8700g Sorry, Only Emergency Calls Are Allowed. | .:Towhid:. | BlackBerry (RIM) | 5 | 08-24-2014 10:36 |
Blackberry 8800, sorry, only emergency calls are allowed | Mobile-Expert | BlackBerry (RIM) | 6 | 06-26-2012 08:39 |
Sorry,only emergency calls are allowed | ZoHaiB_(FoneGSM) | FuriousGold | 2 | 08-22-2007 12:34 |
Help:T-mobile BB 7290, Only emergency calls are allowed | saltedfish | HTC & PDA WM( With Touchscreen) | 0 | 09-09-2006 19:38 |
