01-02-2013, 21:48 | #1 (permalink) |
Freak Poster Join Date: Jan 2011
Member: 1482280 Status: Offline Sonork: 100.1600954 Thanks Meter: 23 | ZTE V760 Debug port not found Searching phone; Phone detected (MediaTek PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) ERROR: Debug port not found ! BE sure the drivers from support were installed; AND I GOT CDC Serial.................. drivers |
01-05-2013, 14:07 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,569 | Quote:
Contact me on skype to check if you say the drivers are installed and working . Can try MTKReader_v1.0.0.118.rar from support and check if the problem still same ? Br | |
03-01-2013, 10:27 | #3 (permalink) | |
Member: 1482280 Status: Offline Sonork: 100.1600954 Thanks Meter: 23 | Quote:
Searching phone; Phone detected (PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) ERROR: Debug port not found ! BE sure the drivers from support were installed; Time needed - 00:02:57 | |
03-01-2013, 10:29 | #4 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: Africa
Member: 181277 Status: Offline Thanks Meter: 84 | Quote:
03-01-2013, 11:06 | #8 (permalink) |
Member: 181277 Status: Offline Thanks Meter: 84 | sorry you where right Searching phone; Phone detected (PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM48); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6573, E00 Sw version: MAUI.11AMD.W11.37.SP.V3.P2 Hw Version: ZTENJ73_HW Reading phone info; IMEI: 868215-00-042777-8 Reading simlock info; Locked to: 001-01 code_cat_n: 12345678 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:01:25 |
06-05-2013, 11:34 | #9 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Gujrat (India) Age: 38
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | Searching phone; Phone detected (@oem152.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on FTEAM USB Serial Port (COM41); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6573, E00 Sw version: MAUI.11AMD.W11.37.SP.V27 Hw Version: JRD73_GIN_MODEM_GEMINI2_HW Reading phone info; IMEI: 860767-00-149250-6 Reading simlock info; Locked to: 338-05 code_cat_n: 42881674 enabled: yes tries: 0 code_cat_ns: 07300800 enabled: no tries: 10 code_cat_sp: 31935270 enabled: no tries: 10 code_cat_c: 37257920 enabled: no tries: 10 code_cat_sim: 23565497 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Time needed - 00:00:50 |
