Bmobile Ax515 Problem with PAck6 MetaMode !! Problems with this phone.. is not supported but conect without problem and other user here in forum says that Conect fully ... !!! The phone conect in META MODE without problem (see in display phone)... Drivers installed from support.. because I make Some alcatel that you help me before changing some ID in control panel ..weeks Ago .. here the log ... any help support .. Searching phone; Phone detected (USB Modem Driver) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM20); Preparing to connect meta mode; ERROR: ? Time needed - 00:00:46 |
Did you reset the pc after drivers install ? Br;) |
drivers was installed weeks ago like i told you... for make an alcatel... and everything is ok.. im sure the driver installed are from support.. any ideażżż |
use this driver inside folder: ALCATEL_MTK6573_Android_Unlock_Drivers.rar Searching phone; Phone detected (@oem152.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on FTEAM USB Serial Port (COM41); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6573, E00 Sw version: MAUI.11AMD.W11.37.SP.V27 Hw Version: JRD73_GIN_MODEM_GEMINI2_HW Reading phone info; IMEI: 860767-00-149250-6 Reading simlock info; Locked to: 338-05 code_cat_n: 42881674 enabled: yes tries: 0 code_cat_ns: 07300800 enabled: no tries: 10 code_cat_sp: 31935270 enabled: no tries: 10 code_cat_c: 37257920 enabled: no tries: 10 code_cat_sim: 23565497 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Time needed - 00:00:50 |
