12-14-2009, 19:12 | #1 (permalink) |
Freak Poster Join Date: Dec 2008 Location: cali-colombia Age: 29
Member: 914317 Status: Offline Sonork: 100.1601159 Thanks Meter: 66 | ..::test unlock zte s305g+::.. please help me sir .:hack3r2k:. i try unlock select a316+ Connect phone powered on ! Start auth ! SW Ver: ES-CO-COMCEL-P108A28(S)(U)V1.0.0B02 Imei: 357925030794504 Done; UNSUPPORTED FIRMWARE VERSION. CHECK FULL FLASH IN SOFTWARE AND THIS TIME FLASH WILL BE DUMPED. AFTER UPLOAD IT SOMEWHERE AND CONTACT SUPPORT ! Error ... ! Time needed - 00:00:01 i try read flash select a316+ and work Connect phone powered on ! Start auth ! SW Ver: ES-CO-COMCEL-P108A28(S)(U)V1.0.0B02 Imei: 357925030794504 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Loader sent .... Flash ID(0): 00C2:22C4 Reading ... Saved: ZTE_13.09.59_14.12.2009_FLASH.bin Done ! Time needed - 00:02:00 flash download here. http://www.4shared.com/file/17291127...009_FLASH.html |
The Following User Says Thank You to jesedavidfrv For This Useful Post: |
12-15-2009, 01:33 | #5 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | You got answer if you want support send phone to him if not want send then get lost and not beg becosue this is stupid. If He can do remotly He will do it. In your case He need got phone in hand to can help. bye |
12-15-2009, 03:27 | #6 (permalink) |
Member: 914317 Status: Offline Sonork: 100.1601159 Thanks Meter: 66 | send one phone costs a lot of Colombia to romania and the phone is very cheap is not profitable for me thank you very much for the furious team |
.:: Test Unlock ZTE A931G+ ::.. [FINALLY SOLVED] | The_Dj | FuriousGold | 37 | 11-03-2010 18:23 |
::..:: Successfully Unlock S7330 + I607 ::..:: | mujahid_ali | NSPRO | 4 | 08-05-2009 08:50 |
::first try unlocked zte f230 for free without logs or activation :: | toutou_gsm | PolarBox 3 | 3 | 04-19-2009 21:54 |
:: F480v Freeze (no unlockable versions) Final Unlock method 100% :: | BouRRi_GSM | Easy-Unlocker | 2 | 11-27-2008 00:11 |
:: Unlocking Expert Logger :: All New Alcatel Supported | UnlockingExperts | Main Sales Section | 0 | 01-24-2006 01:31 |
