Cant unlock/read flash/phone lock T156 AY Hi ! Mr.Hacker I have Huawei T156 AY but when I connect it for unlock or phone code or read full flash I always get this error. Software engine version: 1.0.0.5368 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081039636348 Getting config data; Error ... ! Time needed - 00:00:01 Cable is working fine 100% I have two GPG cables both working perfectly. :( waiting for reply. Can't read flash!! |
try to unlock with rx/tx good luck |
Code: Software engine version: 1.0.0.5368 Which version of vodafone you are using ? |
Try restoring with the respective version from T156_Restore_Pack... Do you get same error ? |
As u can see in my 1st post Software engine version: 1.0.0.5368 and here is restore log Software engine version: 1.0.0.5368 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 PARTIAL: T156_P1.2PU01V01.01 RANGE(S): 00000000:001F8000 00000000:001F8000 Erasing ... Writing ... Restored ! Remove battery and put back ! Time needed - 00:01:52 here is log after restoring then unlocking Software engine version: 1.0.0.5368 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081039636348 Getting config data; Error ... ! Time needed - 00:00:01 Also tried with ULC_PhoneLock Using COM6 to connect ... Use COM6 to connect is OK Communication Link Okay Resetting Phonelock ... Phonelock Reset success but still incorrect password :( I tried 0000 1234 1122 |
tried earlier version? |
Br;) |
