fg 2010 edition box problem Furious Team, Please Help I bought brand new Furious Gold Box I follow this instruction and install in freshly formatted/installed OS pc Q: What OS (operating system) are your softwares compatible ? A: Windows XP/2K/Vista. Q: I just got my box and i would like to install drivers. What to do ? A: There are two drivers to install on first use. First get FG_FTDIDRIVER.rar from support, extract in one folder and after connect box to usb cable. In this moment windows will request this driver and just point him the correct directory. After get from support FG_SMARTCARDDRIVER.zip, extract in one fodler, right click on ini file and choose install. End these operations by resetting pc. Q: What is the next step after installing drivers ? A: download latest maintainance tool extraxt on new folder, run the maintenance exe tick format & execute selected operation to double size the dongle volume after finish tick generate licence then click on execute selected operation, after the licence has been generated click on go to support area, you'll be logged in automaticly to support area go to download area >> setup, download the latest installer and make sure to download the latest beta modules, install furious installer and exract beta modules on furious installer folder make sure to put the generated key inside the installer folder. Here comes the problem run the maintenance software, it worked fg box detected exit the sofware then run again no card-reader(s) found, WHY? removed fg box from cable then reconnect box after several minutes, run software it work again exit software then run again, no card-reader(s) found WHY? Any solution for this? Remember i install the software in a newly format pc, so probably no conflict in driver I also use the latest maintenance software from support |
Hi Nataraki Your Drivers are not Installed correctly , can you Please Post screen shot for your Divce Manager |
kindly check the screen shot of my device manager at the link below i can't upload it in other imagehosting my internet connection here is tooooooo slow http://www.mypicx.com/01142010/my_device_manager/ http://www.mypicx.com/01142010/my_device_manager/ |
please please please... really need to solve this problem |
box drivers are installed ok ! but check smartdcard drivers i think u didn't install it |
thanks... but why software is running at first after software exits, then run again no card-reader(s) found or PROTECTION ERROR! |
change the usb cable or plug it on another usb port ( don't use hub) |
If Win7 then means you must open as admin and vista nearly sure the same |
i don't think he's runnig win7/vista if you see his screenshot , it's a winXP |
@toptech mine is 2010 edition its a built in pcb according to my reseller I'm using winXP |
Anymore idea on how to solve this problem? To Furious Team, Is this not a hardware problem? |
It can be that the dongle it's half unplugged. Contact your reseller if he allow you to open box and recheck dongle connection Regards Furious Support |
mine is 2010 edition, no dongle 'coz its "dongle built-in pcb" according to my reseller |
Well it has dongle but it's inside the box. So tell him Regards Furious Support |
