12-02-2014, 00:28 | #1 (permalink) |
No Life Poster Join Date: Jul 2001 Location: PL Age: 41
Member: 5268 Status: Offline Thanks Meter: 24 | [PACK 12]G900f UART factory unlock can't be done BR ceedee |
12-02-2014, 11:32 | #3 (permalink) |
Member: 5268 Status: Offline Thanks Meter: 24 | I told that phone is not detected via UART connection. Every step is 'error [NO_ANSWER]. You want the log - here it is... Code: FG Samsung Module v1.0.3.3 ~ SAMSUNG G900F ~ ~ FACTORY UNLOCK ~ Start at 11:22:30 Checking server 1; ok Connecting to server; ok Asking server for access; ok Disconnecting from server; ok PLEASE "WAKE UP" PHONE IF IT'S IN STANDBY OR WILL NOT BE DETECTED! Searching for phone; ok Reading BUILD INFO; error [ NO_ANSWER ] Reading BRAND; error [ NO_ANSWER ] Reading MODEL; error [ NO_ANSWER ] Reading VERSIONS; error Reading IMEI; error [ NO_ANSWER ] Reading BLUETOOTH INFO; error Reading MSL INFO; error Reading data; error Checking server 1; ok Connecting to server; ok Asking server for access; ok Disconnecting from server; ok End at 11:30:19 Below is the log of USB modem connection Code: FG Samsung Module v1.0.3.3 ~ SAMSUNG G900F ~ ~ FACTORY UNLOCK ~ Start at 00:07:13 Checking server 1; Checking server 1; ok Connecting to server; Connecting to server; ok Asking server for access; Asking server for access; ok Disconnecting from server; Disconnecting from server; ok PLEASE "WAKE UP" PHONE IF IT'S IN STANDBY OR WILL NOT BE DETECTED! Searching for phone; Searching for phone; ok Reading BUILD INFO; Reading BUILD INFO; error [ NO_ANSWER ] Reading BRAND; Reading BRAND; error [ NO_ANSWER ] Reading MODEL; Reading MODEL; ok Reading VERSIONS; Reading VERSIONS; error Reading IMEI; Reading IMEI; ok Reading BLUETOOTH INFO; Reading BLUETOOTH INFO; error Reading MSL INFO; Reading MSL INFO; error MODEL: SM-G900F IMEI: 354734064675636 VERSION: G900FXXU1ANI3/G900FVFR1ANI2/G900FXXU1ANG8/G900FXXU1ANI3 PHONE SN: R58F60Q9TCZ UNIQUE NO: C1608E5A6897131 Reading data; Reading data; error Checking server 1; Checking server 1; ok Connecting to server; Connecting to server; ok Asking server for access; Asking server for access; ok Disconnecting from server; Disconnecting from server; ok End at 00:08:25 ceedee |
12-02-2014, 12:09 | #5 (permalink) |
Member: 5268 Status: Offline Thanks Meter: 24 | Yup - selfmade, done many i9300s, s5620, s5610... etc. with it. Cable is not a problem - that's for sure. Or maybe some other resistance should be applied? |
12-02-2014, 12:19 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: P A K I S T A N
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | brother try another UART cable ... surely its ur UART problem ... some working cables do some problem ... happened with me also ... try another UART cable it will work |
12-02-2014, 12:51 | #9 (permalink) | |
Member: 5268 Status: Offline Thanks Meter: 24 | Quote: if you meant swaping rx and tx - is not a cable from furious, it's self made cable which succesfully worked with z3x and nspro (yes I know that those boxes have different pinout but making 2-dir conversion plug is super easy) BR | |
