FURIOUS GOLD Pack 12 SM-G901F Unlock Help Hello, i have a G901F from UK i need to unlock, i follow the instructions in the Samsung Code Reader (software for pack 12) but i can't seem to get the menu to come up when i type in *#7284# Phone android version is 4.4.4 When i press read info i get OK when BUILD INFO, BRAND, MODEL and VERSIONS but error at IMEI, BLUETOOTH INFO and MSL Please help Thanks in advance |
See SAMSUNG_G800x_G850x_G901F_UART_enable.jpg from support for the uart enable Brhttp://forum.gsmhosting.com/ubb/wink.gif |
Sorry, i'm a bit dumb, i tried looking for the mentioned jpg in the support (via maintenance) which catergory is it under? also i tried looking for a support button in the code reader app too but still couldnt find it looking forward to your reply |
Must use maintenance, press go support, on the browser windoiws go Downloadable file, PINOUTS section http://i1222.photobucket.com/albums/...ps36bcb056.jpg |
Hello, so i have done as the picture says but still no go on the *#7284# command after plugging into the UART cable, i insert the battery and device turns on by itself. i then enter the code but no response http://imageshack.com/a/img537/3743/7Qoz7G.jpg |
will check with coder and come back to you |
You dont need to dial anything. Simply power on the phone like this and will work Br;) |
So after doing the battery trick, i proceeded to read the phone to see if i get anything this is the result http://i107.photobucket.com/albums/m...ps657c2b08.png this seems to be a false reading when it says "Searching for phone; ok" any ideas? |
If you use the cable from our set replace rx with tx. Some of them come with incorrect pinout so you need to swap the pins br;) |
*sigh* i seem to have misplaced the cables that came with the furious gold box, the one i'm using is the one that came with the octoplus box.. is there anything else i can do? might have to resort to submitting to a server for unlock code and hope it works |
no idea of the pinout for that box Br;) |
do you guys have a service for this device to get unlock code via imei? |
Yes. Go to the REMOTE UNLOCK section of the support area Br;) |
Hmm...i tried looking in the samsung section in remote unlock, the model SM-G901F doesnt seem to be in the supported phones list :( Still trying to figure out the reason why my phone cannot be read by my computer? Any ideas? |
You have Samsung Europe Unlock Codes and this includes all the models. As for the detection im sure its cable fault. try swapping rx with tx br;) |
