03-06-2017, 19:58 | #13591 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Portugal Age: 43
Member: 7557 Status: Offline Thanks Meter: 26 | Meo Smart A35 Searching phone; Phone detected (@oem72.inf,%vcom_preloader%;MediaTek PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Gadget CDC VCOM Driver (COM793); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6580, E01 Sw version: MOLY.WR8.W1449.MD.WG.MP.V57.P3 Hw Version: SR6580_WE_M_HSPA_HW Reading phone info; IMEI: 359072-07-042734-5 Reading simlock info; Locked to: C1C-1C code_cat_n: 12345678 enabled: no tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:01:01 Log file saved to: LOG_6_03_2017_18_54_08.txt |
The Following 2 Users Say Thank You to theboy For This Useful Post: |
03-08-2017, 13:46 | #13592 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | HUAWEI LUA-U22 Y3ii FRP Removed C:\Program Files (x86)\Minimal ADB and Fastboot>Fastboot oem frp-unlock 291F5793 3052BF65 ... (bootloader) frp key is set success (bootloader) frp check key ok OKAY [ 0.710s] finished. total time: 0.712s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot reboot rebooting... finished. total time: 0.002s |
03-08-2017, 16:41 | #13593 (permalink) |
Freak Poster Join Date: May 2014 Location: baia mare romania Age: 40
Member: 2195859 Status: Offline Thanks Meter: 19 | telenor pro1201AU001.133 unlocked selecting: pro1201AU001.112(1) Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem115.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM39]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: NONE BT ADDR: 47:8E:64:69:39:C8 SW IMEI[0]: 867041-00-746874-3 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 303C8000 Reading NV; NV saved to : NV_000000-00-000000-0_867041-00-746874-3_65310001_8_03_2017_17_38_13.spd IMEI: 867041-00-746874-3 UNLOCK CODE: NONE Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_8_03_2017_17_38_41.txt Time needed - 00:00:38 |
03-08-2017, 21:38 | #13594 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ALCATEL 4060A FRP DONE Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem405.inf,%qcomdevice90080%;RELINK HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM29 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 01469900732538-7 PTH: 06 PTS: M5K PROV_ID: 4060A-2AAQUS3-R1 SBTADDR: 28:BE:03:7A:80:8D SWIFIADDR: 28:BE:03:7A:F5:49 HS_PN: SAA1GY0WA10C SSN: 48KB08CIBLZ00WD Work id: 066B261E Done; SECURITY: X8C0AB01BR10 Size: 000002A5 Backup saved to: 01469900732538-7 Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; Erase Setup Done; Erase Done; FRPEx Done; Log file saved to: LOG_8_03_2017_16_30_59.txt Time needed - 00:00:34 |
03-09-2017, 17:49 | #13596 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | alcatel 5065n unlock done Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem405.inf,%qcomdevice90080%;RELINK HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM29 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 01470500325102-0 PTH: 03 PTS: N5S PROV_ID: 5065N-2CE4US1 SBTADDR: 28:BE:03:C3:A7:65 SWIFIADDR: 28:BE:03:B9:36:BA HS_PN: SAA34NBAA10C SSN: 98KJ12CGVLZ02M2 Work id: 06DAC12C Done; SECURITY: X2N0UP00CL10 Size: 000002C3 Backup saved to: 01470500325102-0 Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; Erase Setup Done; Erase Done; FRPEx Done; Log file saved to: LOG_9_03_2017_12_47_57.txt Time needed - 00:00:35 |
03-10-2017, 11:23 | #13597 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Huawei Y360 Unlocked... : Using library Brom_DLL_v7.1413.5 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM (Android) (COM92)) Preparing to start flash mode; Preparing to open COM92 Connecting; Downloading DA; Initializing; Rid: 0b6ee17e94ac2e8eec7232fa52c53a8e Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem1.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM98; DEVICE INFO: BB CHIP: MT6582_S00 [CA00, 00, 6582, FF] HW_STORAGE_EMMC: 0x484A0190 0x61324734 0x74420211 0x9F736CE9 [SIZE=0xE9C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x6BB80000 SIZE: 0x7E080000 Searching data; Locked to [SIM1]: 234-15 code_cat_n: 4071969304166122 enabled: yes tries: 7 code_cat_ns: N/A enabled: no tries: 5 code_cat_sp: N/A enabled: no tries: 5 code_cat_c: N/A enabled: no tries: 5 code_cat_sim: N/A enabled: no tries: 5 code_cat_ns_sp: N/A enabled: no tries: 5 code_cat_sim_c: N/A enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:36 Log file saved to: LOG_10_03_2017_09_53_20.txt |
03-10-2017, 15:56 | #13598 (permalink) |
No Life Poster Join Date: Jan 2010 Location: iraq
Member: 1215266 Status: Offline Thanks Meter: 129 | huawei LYO -L02 UNLOCK DONE Searching phone; (insert the USB cable in the powered off phone) Phone detected (MediaTek PreLoader USB VCOM (Android)) Preparing to start MTK debug mode; Searching for debug port; (be sure drivers from support were installed) MTK debug mode entered; Baseband Chip: MT6735,S01 Sw version: Hw Version: LYO-L02C718B122 Baseband Chip: MT6735, E00 Sw version: MOLY.LR9.W1444.MD.LWTG.MP.V42.P40 Hw Version: HQ6753_65C_B1N_L1_HW Reading phone info; IMEI 1: 861947030946503 IMEI 2: N/A Open port success! 2017-03-10 17:52:35.667 Reading data from server... 2017-03-10 17:52:36.091 Reading data from server success! Reading simlock info; Gathering info; Simlock ok; SIM1 Locks cleared; Simlock ok; SIM1 Locks cleared; Simlock ok; SIM2 Locks cleared; Simlock ok; SIM2 Locks cleared; Simlock read end; |
The Following User Says Thank You to tornado779 For This Useful Post: |
03-10-2017, 16:43 | #13599 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Rook From EE Unlocked Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM35)) Preparing to start flash mode; Preparing to open COM35 Connecting; Downloading DA; Initializing; Rid: 85f3bbb3dd138e5d18ee48025c0374b8 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM5; DEVICE INFO: BB CHIP: MT6735M_S00 [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x51000115 0x4D533237 0xDC850042 0x999269DC [SIZE=0x1D2880000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x99000000 SIZE: 0x39880000 Searching data; Locked to [SIM1]: 234-30 code_cat_n: 1353573541534864 enabled: yes tries: 9 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Code reading finished; Remove battery and cable; Time needed - 00:00:07 Log file saved to: LOG_10_03_2017_15_39_15.txt |
03-11-2017, 16:45 | #13600 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | alcatel 4060a unlock done Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem405.inf,%qcomdevice90080%;RELINK HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM29 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 01469900081584-8 PTH: 03 PTS: M5K PROV_ID: 4060A-2AAQUS3-R1 SBTADDR: 20:A9:0E:6C:78:71 SWIFIADDR: 20:A9:0E:7E:B6:BA HS_PN: SAA1GY0WA10C SSN: 48KB05CI7JZ04NR Work id: 06CA8920 Done; SECURITY: X1M0UA02CL10 Size: 000002D4 Backup saved to: 01469900081584-8 Backup file(s) removed; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_11_03_2017_11_40_36.txt Time needed - 00:00:25 |
03-13-2017, 10:38 | #13603 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | Software engine version: 1.0.0.6556 Connect phone powered on ! Start auth ! SW Ver: E-UG-TELECOM-P108A26(S)V1.0.0B02 Imei: 356707032005282 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 48 E9 1B 36 C4 90 48 01 89 0B Flash ID(0): 00EC:257E Saved: ZTE_356707032005282_E-UG-TELECOM-P108A26(S)V1.0.0B02_12.34.49_13.03.2017_PARTIAL.bi n Unlocked ! Remove battery and put back ! Time needed - 00:01:58 |
The Following User Says Thank You to ibrajinja For This Useful Post: |
03-14-2017, 12:09 | #13604 (permalink) |
Freak Poster Join Date: May 2015 Location: Algiers, Algeria
Member: 2399672 Status: Offline Thanks Meter: 187 | SFR 124 unlock done! -Pack 2 -SPD service tool -Select model Sfr 124 -Select operation: Remove sim lock -Hit connect -Phone turned off: hold call button and insert usb cable Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem114.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM283]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0000 Starting auth; HW IMEI : 862644-02-018967-8 Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: 2050G-3DSFFR1 BT ADDR: A7:B5:C4:02:2D:E4 SW IMEI[0]: 352273-01-738634-0 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 303A8000 Reading NV; NV saved to : NV_862644-02-018967-8_352273-01-738634-0_65310000_14_03_2017_12_03_55.spd IMEI: 862644-02-018967-8 UNLOCK CODE: 21911477 Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_14_03_2017_12_04_13.txt Time needed - 00:00:30 |
03-14-2017, 16:37 | #13605 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Pakistan
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Huawei Y3II Erase FRP Done Code: 2017-03-14 20:31:55.108 FlyCaptain Huawei Module v2.0.0.0139 2017-03-14 20:31:55.110 Dongle S/N: Before detection connect cable to usb and enable Manufacture mode ! Qualcomm and HiSilicon: *#*#2846579#*#* MTK: *#*#14789632#*#* Windows: ##2846579# ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode (for MTK other/debug mode) 2017-03-14 20:32:51.147 Start read phone info! 2017-03-14 20:32:51.280 Detect phone done! Model: HUAWEI LUA-U22 Firmware ver.: LUA-U22C328B005 SN: G8M9XA1662310005 2017-03-14 20:32:59.491 Erase FRP start 2017-03-14 20:33:03.313 Reading phone info... 2017-03-14 20:33:03.461 Read phone info success! Model: HUAWEI LUA-U22 Firmware ver.: LUA-U22C328B005 SN: G8M9XA1662310005 2017-03-14 20:33:03.519 Reading Certify data... 2017-03-14 20:33:03.548 Signing certify data... 2017-03-14 20:33:04.142 Signing certify data success! 2017-03-14 20:33:04.147 Erasing FRP... 2017-03-14 20:33:05.333 Erase FRP done! |
