Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 11-21-2017, 14:39   #14071 (permalink)
bright hlatini's Avatar
Member: 1614640
Thanks Meter: 468
Zte f320 network unlock done by furious gold
Searching phone;
For an successful connection do the following:
1. Remove battery and usb cable
2. Insert the usb cable in the phone
3. Keep pressed the boot key and insert the battery
Phone detected (@oem88.inf,%usbcomm_dl%;SPRD U2S Diag)
Preparing to sync;
Port opened [COM17];
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Loader version: Spreadtrum Boot Block version 1.1
Starting FDL2;
FDL2 sent;
Chip type: 7702 FdlStat: 0000
Starting auth;
Memory NAND [CS0]: 00C8:00B1 - SIZE : 08000000
EFUSE HASH: 0000000000000000000000000000000000000000
HW IMEI : 000000-00-000000-0
Reading phone info;
PHONE INFO: VDF_UK_QB18S_P701A24
BT ADDR: 4D:37:7B:F1:16:4C
SW IMEI[0]: 867063-02-075062-6
SW IMEI[1]: 000000-00-000000-0
SW IMEI[2]: 000000-00-000000-0
SW IMEI[3]: 000000-00-000000-0
SIMLOCK FLAG: ON
FIXED NV BASE: 40040000
Reading NV;
NV saved to : NV_000000-00-000000-0_867063-02-075062-6_77020000_21_11_2017_15_30_56.spd
IMEI: 867063-02-075062-6 UNLOCK CODE: 65160330
Re-programming;
NV programmed;
Done;
Phone unlocked; Remove battery and cable;
Log file saved to: LOG_21_11_2017_15_31_32.txt
Time needed - 00:00:45
The Following User Says Thank You to bright hlatini For This Useful Post:
Old 11-21-2017, 15:49   #14072 (permalink)
Member: 2382052
Thanks Meter: 1,511
kyocera c6530n unlock done
Software engine version: 1.0.0.10603
Searching phone ...
MODEL : QCOM SERIES 42
COMPILED DATE : Nov 26 2014 03:53:00
RELEASE DATE : Mar 21 2014 18:00:00
FIRMWARE INFO : MPSS.TR.2.0-00715-M8610BAAAANAZM-1
IMEI : 01401600721236-8
BLUETOOTH ADDR : BB 04 2B 60 76 6C
DONE;
STARTING;
READING;
DONE;
CHECKING SEC;
DONE;
UNLOCKING;
DONE;
READING;
DONE;
SIM_LOCK REMOVED !
AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY;
Log file saved to: LOG_21_11_2017_10_45_54.txt
Time needed - 00:00:50
Old 11-21-2017, 19:43   #14073 (permalink)
GSM.WIZARD's Avatar
Member: 2751525
Thanks Meter: 28
y6 2 2017
Using library Brom_DLL_v7.1712.1
Searching phone in normal mode;
[connect the phone powered off to the usb cable]
Phone detected (MediaTek PreLoader USB VCOM (Android) (COM10))
Preparing to start flash mode;
Preparing to open COM10
Connecting;
Downloading DA;
Initializing;
Rid: c5936a33bb46127901e9591a3b5e17d4
Requesting baudrate change;
Done;
USB SPEED: USB_HIGH_SPEED
DEVICE INFO:
BB CHIP: MT6737T [CA00, 00, 321, FF]
HW_STORAGE_EMMC: 0x484A0190 0x61344741 0x854ED432 0x87748869 [SIZE=0x3AC000000]
IMEI1 [OTP 0000]: 000000-00-000000-0
IMEI2 [OTP 0000]: 554250-59-56875=-1
PROVIDER: N/A
USRDATA INFO: 0x102000000 SIZE: 0x2A8380000
Searching data;
Locked to [SIM1]: FFF-FF
code_cat_n: 12345678 enabled: no tries: 255
code_cat_ns: 56781234 enabled: no tries: 255
code_cat_sp: 1122FFFF enabled: no tries: 255
code_cat_c: 3344FFFF enabled: no tries: 255
code_cat_sim: 5566FFFF enabled: no tries: 255
code_cat_ns_sp: 7788FFFF enabled: no tries: 255
code_cat_sim_c: 9900FFFF enabled: no tries: 255
Time needed - 00:00:04
Log file saved to: LOG_21_11_2017_10_42_24.txt
Old 11-21-2017, 19:45   #14074 (permalink)
GSM.WIZARD's Avatar
Member: 2751525
Thanks Meter: 28
y6 2 2017
Connecting;
Downloading DA;
Initializing;
Rid: cfd3b1ab70f83e9398904c80c12a8453
Done;
DEVICE INFO:
HW_STORAGE_EMMC: 0x484A0190 0x61344741 0xDA20D432 0x7574216C [SIZE=0x3AC000000]
IMEI2 [OTP 0000]: 000000-00-000000-0
PROVIDER: N/A
Searching data;
Log file saved to: LOG_21_11_2017_10_45_05.txt
Old 11-22-2017, 16:43   #14075 (permalink)
iftikhar_246's Avatar
Member: 384949
Sonork: 1611265
Thanks Meter: 523
LG E610l
unlock done
Software engine version: 1.0.0.10600
Searching phone ...
MODEL : E610
COMPILED DATE : Feb 11 2013 09:37:00
RELEASE DATE : Apr 19 2012 06:00:00
FIRMWARE INFO : LGE610vAT-00-V10g-VDF-XXX-FEB-11-2013+0
IMEI : 35358405306866-0
BLUETOOTH ADDR : DC 1A 11 8F 43 C4
ENTERING DOWNLOAD MODE;
ENTERED;
LOADING DATA;
DONE;
STARTING AUTHORISATION;
AUTHORISATION PASSED;
INIT EMMC ROUTINES;
EMMC INIT MADE;
EMMC manufacturer id: 00000015, oem id: 00000000
EMMC name SJS00M, S/N: 1044599304, rev: 00000000
EMMC size: E9000000
Getting partition tables info
Security found at 00022000 size 00002000
Reading;
Initializing security;
Checking security;
MCC-MNC: 214-01
IMEI: 353584-05-306866-0
PID: HD54S130502004855
Calculating security;
Writing;
SIM_LOCK REMOVED !
RESET !
Sign DB updated !
Log file saved to: LOG_22_11_2017_20_24_59.txt
Time needed - 00:02:12
The Following User Says Thank You to iftikhar_246 For This Useful Post:
Old 11-22-2017, 18:52   #14076 (permalink)
hawks007's Avatar
Member: 621737
Thanks Meter: 87
neo3600 unlock
Searching phone ...
MODEL : QCOM SERIES 10
COMPILED DATE : Nov 21 2014 16:32:00
RELEASE DATE : Oct 25 2010 09:00:00
FIRMWARE INFO : LQBKI04.1.2_M034
IMEI : 3575
BLUETOOTH ADDR : A0 51 82 73 04 9C
DONE;
PHONE CODE: 0000
READING DATA;
CALCULATING;
UNLOCK CODE: 2893602275
TO COMPLETE THE UNLOCK ENTER *#8611# AND ENTER THE UNLOCK CODE ABOVE.
Old 11-22-2017, 19:37   #14077 (permalink)
boliargsm's Avatar
Member: 884906
Sonork: none
Thanks Meter: 77
Zte blade L110 unlock done
Root the phone with kingo root
Connecting;
Check your phone and "Always allow from this computer" and select "OK".
Connected;
BRAND: ZTE
MODEL: ZTE BLADE L110
ANDROID: v5.1
CPU: SC8830
IMEI: NA
KERNEL: Linux version 3.10.65-svn3409 (root@zte-128) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Mon May 1 10:52:55 CST 2017
Cleaning;
Loading files;
Done;
Reconnecting;
Getting memory info;
Done;
Gathering info;
Done;
Cleaning done;
Setting permissions;
Reading data;
Getting data size;
00016567 bytes
Decompressing;
BT ADDR: 07:97:FE:6A:68:18
SW IMEI[0]: 862945-03-859069-4
SW IMEI[1]: 004401-78-377925-5
SW IMEI[2]: 358570-01-010389-3
SW IMEI[3]: 910575-60-140046-8
SIMLOCK FLAG: ON
SIM network unlock PIN: 16919986
Unlock Procedure:
1. Enter an restricted SIM
2. Power on the phone and you will be requested to enter the unlock pin
3. Enter the code and the phone will be unlocked
Code reading finished !
Log file saved to: LOG_22_11_2017_14_27_22.txt
Time needed - 00:00:57
Old 11-24-2017, 11:57   #14078 (permalink)
Goldenphone's Avatar
Member: 180702
Sonork: 1586150
Thanks Meter: 48
ZTE Axon 7 Mini Remove and Unlock Done
thanks to the big work of this team it is possible to unlock and remove frp from zte axon 7 mini
log unlock
Software engine version: 1.0.0.10607
Searching phone ...
MODEL :		QCOM SERIES 50
COMPILED DATE :	Mar 15 2017 13:18:00
RELEASE DATE :	Nov 15 2016 22:00:00
FIRMWARE INFO :	TA.2.1.c1-00101-8976_GEN_PACK
IMEI :		86093503411523-4
BLUETOOTH ADDR :	 B3 B7 24 BC 73 60
FIRMWARE: P852A11V1.0.0B23
close_event_report: OK;
close_log_report: OK;
close_message_report: OK;
closing_com_port: OK;
Starting the backup process;
connect_server: OK;
backup in progress: OK;
Backup saved to: D:\Telefonia\Furious Gold\PACK5\86093503411523_24_11_2017_11_20_56.bkp
switching_download_mode: OK;
Preparing to open COM207
Connecting;
Loading;
Init;
Port opened;
Hello Received;
BOOT Loaded;
Getting config;
Getting mem info;
Found an eMMC memory 22F8
Looking for the interface;
Port found [ZTE Handset Diagnostic Interface (COM231)]
connect_server: OK;
restore in progress: OK;
SIM_LOCK REMOVED !
log remove frp
Searching phone ...
connect_server: OK;
Backup saved to: D:\Telefonia\Furious Gold\PACK5\86093503411523_24_11_2017_11_25_49.bkp
Connecting;
Loading;
Init;
Port opened;
Hello Received;
BOOT Loaded;
Getting config;
Getting mem info;
start_frp_reset: OK;
big team
big work
Old 11-24-2017, 14:30   #14079 (permalink)
Member: 1215266
Thanks Meter: 129
Huawei p10 unlock done
2017-11-24 16:28:56.955 Autodetect started!
2017-11-24 16:28:59.537 Found COM port: COM170
2017-11-24 16:28:59.547 Open port COM170 (Android Adapter PCUI (COM170))...
2017-11-24 16:28:59.676 Connecting to server...
2017-11-24 16:29:00.526 Connected!
2017-11-24 16:29:00.536 Read data from server...
2017-11-24 16:29:02.065 Read data from server success!
2017-11-24 16:29:02.286 Phone authorize start
2017-11-24 16:29:05.882 Phone authorize success!
2017-11-24 16:29:05.892 Read secure info...
2017-11-24 16:29:14.753 Read secure info success!
2017-11-24 16:29:14.753 Read basic info...
2017-11-24 16:29:18.776 Read basic info success!
2017-11-24 16:29:18.786 Unlocking start
2017-11-24 16:29:18.796 Phone secure identify start
2017-11-24 16:29:22.869 Phone secure identify success!
2017-11-24 16:29:24.274 Unlock done!
2017-11-24 16:29:24.284 Job finished!
Old 11-24-2017, 14:34   #14080 (permalink)
Member: 1215266
Thanks Meter: 129
Huawei p9 unlock done
2017-11-24 16:32:28.782 Autodetect started!
2017-11-24 16:32:31.364 Found COM port: COM176
2017-11-24 16:32:31.373 Open port COM176 (Android Adapter PCUI (COM176))...
2017-11-24 16:32:31.492 Connecting to server...
2017-11-24 16:32:32.175 Connected!
2017-11-24 16:32:32.175 Read data from server...
2017-11-24 16:32:33.704 Read data from server success!
2017-11-24 16:32:33.931 Phone authorize start
2017-11-24 16:32:36.332 Phone authorize success!
2017-11-24 16:32:36.332 Read secure info...
2017-11-24 16:32:45.278 Read secure info success!
2017-11-24 16:32:45.278 Read basic info...
2017-11-24 16:32:49.251 Read basic info success!
2017-11-24 16:32:49.251 Unlocking start
2017-11-24 16:32:49.251 Phone secure identify start
2017-11-24 16:32:51.708 Phone secure identify success!
2017-11-24 16:32:51.710 Reading data from server...
2017-11-24 16:32:52.103 Reading data from server success!
2017-11-24 16:32:52.886 Unlock done!
2017-11-24 16:32:52.891 Job finished!
The Following 2 Users Say Thank You to tornado779 For This Useful Post:
Old 11-24-2017, 17:15   #14081 (permalink)
Member: 2612403
Sonork: 100.1575170
Thanks Meter: 108
Coolpad 3622A unlock without T-mobiles permission
Go away T-Mobile with those 100 USD unlock prices
Black Friday unlocks are better
Connecting;
Connected;
BRAND: COOLPAD
MODEL: COOLPAD 3622A
ANDROID: v5.1.1
CPU: QCOM
IMEI: NA
KERNEL: Linux version 3.10.49-g3523c12-00131-gfd2b782 (mine@ubuntu) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Mon Apr 11 12:44:54 CST 2016
Cleaning;
Setting usb config;
Done;
Reconnecting;
Port found [Coolpad Android Diagnostics USB VCOM (COM149)]
Backing up sensitive data;
connect_server: OK;
Backup saved to: F:\FURIOUS\NOT ON DVD\PACK5\ADB\
Done;
Done;
Done;
Restarting the phone;
Setting usb config;
Done;
Reconnecting;
Restoring sensitive data;
connect_server: OK;
Done;
SIM_LOCK REMOVED ! POWER OFF / ON THE PHONE MANUALLY TO COMPLETE THE UNLOCK !
Log file saved to: LOG_24_11_2017_17_08_54.txt
Time needed - 00:03:35
The Following 2 Users Say Thank You to byteforce2016 For This Useful Post:
Old 11-26-2017, 12:19   #14082 (permalink)
Member: 2138570
Sonork: 100.1611495
Thanks Meter: 301
ProjectMenu
1.Background setting
2.USB ports setting
Select Manufacture mode (for MTK other/debug mode)
2017-11-26 16:14:17.781 Start read phone info!
2017-11-26 16:14:18.246 Detect phone done!
Model: HUAWEI LUA-U22
Firmware ver.: LUA-U22C328B013
SN: G8M9XA1762423329
2017-11-26 16:14:22.199 Erase FRP start
2017-11-26 16:14:27.616 Reading phone info...
2017-11-26 16:14:28.082 Read phone info success!
2017-11-26 16:14:28.246 Reading Certify data...
2017-11-26 16:14:28.403 Signing certify data...
2017-11-26 16:14:28.970 Signing certify data success!
2017-11-26 16:14:28.972 Erasing FRP...
2017-11-26 16:14:32.811 Erase FRP done!
Old 11-27-2017, 11:59   #14083 (permalink)
Member: 2070850
Thanks Meter: 9
Post Wiko Jerry 2 Unlock Done MTK Reader
Searching phone;
Phone detected (@oem22.inf,%vcom_preloader%;MediaTek PreLoader USB VCOM (Android))
Preparing to start meta mode;
Searching for debug port; (be sure drivers from support were installed)
Debug Port found on Gadget CDC VCOM Driver (COM12);
Preparing to connect meta mode;
Meta mode entered;
Baseband Chip: MT6580, E01
Sw version: MOLY.WR8.W1449.MD.WG.MP.V91.5.P15
Hw Version: TINNO6580_WE_N_HSPA_HW
Reading phone info;
IMEI: 354040-09-0xxxxxx
Reading simlock info;
Locked to: 228-02
code_cat_n: 87654321 enabled: yes tries: 5
code_cat_ns: 56781234 enabled: no tries: 5
code_cat_sp: 11112222 enabled: no tries: 5
code_cat_c: 33334444 enabled: no tries: 5
code_cat_sim: 55556666 enabled: no tries: 5
code_cat_ns_sp: 77778888 enabled: no tries: 5
code_cat_sim_c: 99990000 enabled: no tries: 5
Unlocking SIM2 too.
Time needed - 00:00:59
Log file saved to: LOG_27_11_2017_11_31_10.txt
Old 11-27-2017, 20:25   #14084 (permalink)
Member: 2506735
Sonork: IT ZONE
Thanks Meter: 20
ALCATEL 9008A (A3 XL) FRP done
Phone detected (MediaTek USB Port (COM19))
Preparing to open COM19
Requesting authorization;
Connecting;
Downloading DA;
Initializing;
Rid: b1fca0d1cd27dcca7c6be64f903a9789
Done;
USB SPEED: USB_FULL_SPEED
Switching to DA_HIGHSPEED_VCOM;
Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86;
If the detection fails, install manually the port from the device manager using usbvcom.inf;
DA_HIGHSPEED_VCOM (@oem129.inf,%vcom_da%;MediaTek DA USB VCOM (Android))
TRYING TO OPEN COM20;
DEVICE INFO:
BB CHIP: MT6737M [CA00, 00, 335, 05]
HW_STORAGE_EMMC: 0x30000111 0x33473631 0x4E8E0030 0xBD242BAD [SIZE=0x3AC000000]
IMEI1 [OTP 0001]: 357245-08-007006-3
IMEI2 [OTP 0001]: 000000-00-000000-0
PROVIDER: 9008T-2AVDAU1
USRDATA INFO: 0xC3000000 SIZE: 0x2E4880000
Factory Reset Protection successfully removed !
Time needed - 00:00:00
Log file saved to: LOG_28_11_2017_09_24_07.txt
Old 11-27-2017, 20:27   #14085 (permalink)
Member: 2506735
Sonork: IT ZONE
Thanks Meter: 20
ALCATEL 9008A (A3 XL) unlock DONE
Connecting;
Downloading DA;
Initializing;
Done;
DEVICE INFO:
Searching data;
Locked to [SIM1]: 505-03
code_cat_n: 98936188 enabled: yes tries: 99
code_cat_ns: 93915050 enabled: no tries: 10
code_cat_sp: 09576420 enabled: no tries: 10
code_cat_c: 90742099 enabled: no tries: 10
code_cat_sim: 56345416 enabled: no tries: 10
code_cat_ns_sp: 53297761 enabled: no tries: 5
code_cat_sim_c: 86817778 enabled: no tries: 5
Time needed - 00:00:18
Log file saved to: LOG_28_11_2017_09_27_38.txt
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.43762 seconds with 10 queries
