03-25-2019, 18:51 | #15106 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | Z971 unlock failed yet exe reports success Searching phone ... MODEL : QCOM SERIES 53 COMPILED DATE : Jul 24 2017 19:54:00 RELEASE DATE : Apr 26 2017 06:00:00 FIRMWARE INFO : MPSS.JO.2.0.c1-00179-8937_GENNS_PACK-1.95826.1.96615.1 IMEI : 86372703335845-2 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: P817A22V1.0.0B20 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: C:\Users\ALPHA\Desktop\86372703335845_25_03_2019_2 0_43_33.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM80 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D5 Looking for the interface; Port found [Handset Diagnostic Interface(DFU) (COM225)] connect_server: OK; restore in progress: OK; SIM_LOCK REMOVED ! Log file saved to: LOG_25_03_2019_20_46_42.txt Time needed - 00:03:13 DEVICE STILL HAS COUNTERS OF 10 TIMES |
The Following User Says Thank You to ferouz kassim For This Useful Post: |
03-26-2019, 09:33 | #15107 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Gambia
Member: 1440837 Status: Offline Sonork: 3535 Thanks Meter: 47 | Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MTK USB Port (COM93)) Preparing to start flash mode; Preparing to open COM93 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: fadc98ee24cc7285d620e1a693df0c63 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6739 [CB00, 02, 6739, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333645 0xC1670342 0x158588E4 [SIZE=0x3A4A00000] IMEI1 [OTP 0001]: 015249-00-0 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5059Z-2AE4US7 USRDATA INFO: 0x133800000 SIZE: 0x26CAFBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:07:49 Checking data integrity; Data integrity: OK; SIM_LOCK: ENABLED Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:07:52 Log file saved to: LOG_26_03_2019_08_31_26.txt thank you so much |
03-26-2019, 13:44 | #15108 (permalink) |
Freak Poster Join Date: Feb 2007 Location: thailand
Member: 451521 Status: Offline Thanks Meter: 317 | Honor 9 Huawei id Remove New BootLoader Done! By Resurrector 0.0.0.33 Honor 9 Huiwei id Remove New BootLoader Done! By Resurrector 0.0.0.33 Device detected: COM3: HUAWEI USB COM 1.0 (COM3) BOOTLOADER File to update: Kirin960_T2_A7.0_V5_test OEM File to update: STF-L09 3/26/2019 7:33:19 PM Starting to write device... Writing bootloader... Writing Kirin960_T2_A7.0_V5_test_3.dtwork... Writing Kirin960_T2_A7.0_V5_test_4.dtwork... Writing Kirin960_T2_A7.0_V5_test_5.dtwork... Waiting for fastboot device... Device found: 8BNDU17911008195 Looking for a device in fastboot mode Device found: 8BNDU17911008195 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... SN:8BNDU17911008xxx IMEI:86766703093xxx IMEI1:86766703096xxx MEID:A000008208D5FD Build number: :STF-L09 8.0.0.363(C432) Model: STF-L09 Battery state: 0 OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Writing OEMINFO partition OEMINFO partition UPDATE ...OK Software written 3/26/2019 7:33:57 PM Writing device finished OK THX FG team Best Support |
The Following 7 Users Say Thank You to Tom_ptm For This Useful Post: |
03-26-2019, 17:30 | #15109 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ALCATEL 2038A UNLOCK DONE Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem110.inf,%dc_diag%;SPRD U2S Diag) Preparing to sync; Port opened [COM72]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Chip type: 7702:0000 Starting auth; Memory NAND [CS0]: 00C8:0091 - SIZE : 08000000 EFUSE HASH: 0000000000000000000000000000000000000000 EFUSE LOCK STATUS: 000E 000E 000E 000E 000E HW IMEI : 000000-00-000000-0 Reading phone info; PHONE INFO: 2038A-3BAVDO1 BT ADDR: 76:312:CF:4F:9C SW IMEI[0]: 014870-00-085572-6 SW IMEI[1]: 352751-01-265893-0 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 40040000 Reading NV; NV saved to : NV_000000-00-000000-0_014870-00-085572-6_77020000_26_03_2019_12_24_02.spd IMEI: 014870-00-085572-6 UNLOCK CODE: 8533119732512849 Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_26_03_2019_12_24_23.txt Time needed - 00:00:29 |
03-27-2019, 16:49 | #15110 (permalink) |
No Life Poster Join Date: May 2005 Location: bridgetown Age: 59
Member: 146939 Status: Offline Sonork: 100.1609615 Thanks Meter: 245 | revvl 2 Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM6)) Preparing to start flash mode; Preparing to open COM6 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: ecb4df1943536a893d2eac1b9acc6827 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6739 [CB00, 02, 6739, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333644 0x10690142 0x4395BADC [SIZE=0x749400000] IMEI1 [OTP 0001]: 015246-00-094385-4 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5052W-2ATBUSE USRDATA INFO: 0x133800000 SIZE: 0x6108FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:00:00 Checking data integrity; Data integrity: OK; Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:00:02 Log file saved to: LOG_27_03_2019_11_45_22.txt thanks it done with new update |
The Following 2 Users Say Thank You to sweetboy For This Useful Post: |
03-29-2019, 13:09 | #15111 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | ORANGE NOVA 80 FRP SUCCESSFULLY UNLOCKED Software engine version: 1.0.0.10782 Searching phone ... MODEL : QCOM SERIES 50 COMPILED DATE : May 6 2016 21:29:00 RELEASE DATE : Jan 19 2016 10:00:00 FIRMWARE INFO : MPSS.TA.1.0.c3-00055-8952_GEN_PACK-1 IMEI : 869XXXXXXXXXXXXX BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: FR_ORANGE_P852F52V1.0.0B17 DONE; STARTING FRP RESET; close_event_report: OK; close_log_report: OK; close_message_report: OK; FRP REMOVED SUCCESSFULLY; Log file saved to: LOG_29_03_2019_14_08_07.txt Time needed - 00:00:22 |
04-01-2019, 01:08 | #15112 (permalink) | |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Quote:
change cable i select 5052W Code: Connecting; Downloading DA; Initializing; Rid: fcd458a027272a848c04ac2db310b581 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6739 [CB00, 02, 6739, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0xC7B40742 0x17858BCE [SIZE=0x748800000] IMEI1 [OTP 0001]: 015246-00-196304-2 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5052W-2ATBUSE USRDATA INFO: 0x133800000 SIZE: 0x6108FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:02:34 Checking data integrity; Data integrity: OK; Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:02:38 Log file saved to: LOG_1_04_2019_13_03_07.txt | |
04-01-2019, 14:54 | #15113 (permalink) |
No Life Poster Join Date: Apr 2005 Location: mars
Member: 132881 Status: Offline Thanks Meter: 105 | Optus x start unlock successfull!! sing library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MediaTek USB VCOM (Android) (COM42)) Preparing to start meta mode; Requesting authorization; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739,S01 Sw version: Hw Version: alps-mp-o1.mp1-V1.54_k39tv1.bsp_P56 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R2.MP.V18.P95 Hw Version: TK_MD_L4_HW Reading phone info; IMEI 1: 356267-09-107772-2 IMEI 2: 000000-00-000000-0 Loading config; Done; Working; Unlocking; Phone unlocked; Remove battery and cable; Time needed - 00:01:33 |
04-03-2019, 11:43 | #15114 (permalink) |
No Life Poster Join Date: Jan 2014 Location: africa mali
Member: 2098907 Status: Offline Thanks Meter: 154 | ot 5033d metropcs 8.1.0 frp unlock done Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MTK USB Port (COM133)) Preparing to start flash mode; Preparing to open COM133 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 2b102a50992c2f92f4e6d1e2174218a9 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6739 [CB00, 02, 6739, 00] HW_STORAGE_EMMC: 0x51000115 0x3030574E 0xE6D50B4D 0x8584B0A8 [SIZE=0x1D2880000] IMEI1 [OTP 0001]: 356266-09-322187-4 IMEI2 [OTP 0001]: 356266-09-322188-2 PROVIDER: 5033D-2ERGWB3 USRDATA INFO: 0x85000000 SIZE: 0x1494FBE00 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_3_04_2019_12_40_34.txt |
The Following 2 Users Say Thank You to goudio For This Useful Post: |
04-03-2019, 18:39 | #15115 (permalink) |
No Life Poster Join Date: Jun 2016 Location: UK
Member: 2581848 Status: Offline Thanks Meter: 249 | Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM9)) Preparing to start flash mode; Preparing to open COM9 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: d5950f8929f118da0d81207dcd1f1193 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6739 [CB00, 02, 6739, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333645 0x3FF60342 0x3D85F690 [SIZE=0x3A4A00000] IMEI1 [OTP 0001]: 015249-00-05******** IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5059Z-2AE4US7 USRDATA INFO: 0x133800000 SIZE: 0x26CAFBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:00:00 Checking data integrity; Data integrity: OK; SIM_LOCK: DISABLED Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:00:15 Log file saved to: LOG_3_04_2019_10_36_32.txt coooool 15sc Only |
04-04-2019, 10:14 | #15116 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Cameroon- Bamenda
Member: 69269 Status: Offline Thanks Meter: 175 | Alcatel 1066G unlock done Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly the boot key 3. Insert the usb cable inside the phone while keeping pressed the boot key Phone detected (@oem167.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM54]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.2 Starting FDL2; FDL2 sent; Chip type: 6562:0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000 [000020C73099D63A:69FD] Reading phone info; PHONE INFO: 1066G-2ATMST1 BT ADDR: 59:E6:80A:45:40 SW IMEI[0]: 352936-10-146533-3 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 103B8000 Reading NV; Reading security; NV saved to : NV_000000-00-000000-0_352936-10-146533-3_65620000_4_04_2019_10_08_04.spd IMEI: 352936-10-146533-3 UNLOCK CODE: NONE Gathering security data; Reading simlock; Done; Security check result: 0 Re-programming; Simlock programmed; NV programmed; Done; |
04-04-2019, 10:17 | #15117 (permalink) |
No Life Poster Join Date: Oct 2013 Location: Cote Ivoire ABJ,tvlle, LBJ.23 Age: 39
Member: 2041210 Status: Offline Thanks Meter: 541 | Unlock succefull T-Mobile REVVL 2 / OT-5052W with Furious Gold key Tutorial Unlock succefull T-Mobile REVVL 2 / OT-5052W with Furious Gold key https://www.youtube.com/watch?v=3AD2...TfLdhC_swvNni8 |
04-04-2019, 20:30 | #15118 (permalink) |
Freak Poster Join Date: Mar 2009 Location: jamaica
Member: 1000658 Status: Offline Thanks Meter: 69 | Alcatel 6062w unlock success with fg Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM83)) Preparing to start flash mode; Preparing to open COM83 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: c2a596e9e11ddf45d9c8613f137eadbb Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6763 [CA01, 01, 6763, 00] HW_STORAGE_EMMC: 0x45000170 0x45474249 0xEF270541 0x47652AD3 [SIZE=0x720C00000] IMEI1 [OTP 0001]: 015126-00-274585-5 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 6062W-2BTBUS7 USRDATA INFO: 0x13B800000 SIZE: 0x5E0CFBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:32:19 Checking data integrity; Data integrity: OK; SIM_LOCK: ENABLED Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:32:23 Log file saved to: LOG_4_04_2019_14_26_59.txt |
04-05-2019, 23:12 | #15119 (permalink) |
Freak Poster Join Date: Aug 2004 Location: WORLDWIDE
Member: 78516 Status: Offline Thanks Meter: 62 | huawei mate 10 lite RNE-L21 FRP and Huawei ID removed Code: Device detected: BOOTLOADER File to update: Kirin659_T0_A8.0_V1 OEM File to update: RNE-L21 05/04/2019 23:37:37 Starting to write device... Writing bootloader... Writing Kirin659_T0_A8.0_V1_3.dtwork... Writing Kirin659_T0_A8.0_V1_4.dtwork... Waiting for fastboot device... Device found: FFY5T17C080XXXXX Looking for a device in fastboot mode Device found: FFY5T17C080XXXXX Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... SN:FFY5T17C080XXXXX IMEI:86797303XXXXXXX IMEI1:86797303XXXXXXX MEID:00000000000000 Build number: :RNE-L21 8.0.0.339(C185) Model: RNE-L21 Battery state: 2302mv OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Unlocking FRP... Writing FRP partition FRP partition UPDATE :FAIL partition error Writing FRP partition FRP partition UPDATE ...OK Writing OEMINFO partition OEMINFO partition UPDATE ...OK Software written 05/04/2019 23:38:16 Writing device finished OK thanks BR |
04-06-2019, 04:14 | #15120 (permalink) |
Crazy Poster Join Date: Nov 2016 Location: The Greatest fiji islands
Member: 2644395 Status: Offline Thanks Meter: 11 | world first....... BLUESKY super BSS45 unlocked using 5059 alacatel Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MediaTek USB Port (COM5)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739,S01 Sw version: Hw Version: alps-mp-o1.mp1-V1.192 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R2.MP.V48.12 Hw Version: TK_MD_BASIC_HW Reading phone info; IMEI 1: 3---------------------- IMEI 2: 3----------------------- Loading config; Done; Working; Unlocking; Phone unlocked; Remove battery and cable; Time needed - 00:00:51 brrrr.......... |
The Following User Says Thank You to mezainmy For This Useful Post: |
