05-30-2019, 07:52 | #15181 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Bangladesh Age: 34
Member: 1217931 Status: Offline Sonork: 100.1604251 Thanks Meter: 267 | Huawei Mobile Wifi E5372T Unlock successfull Reading device... Model: E5372T Application port: COM209 IMEI: 862554023982641 Firmware Version: 21.270.05.00.76 Build Date: Feb 19 2014, 15:08:56 Product name: B710D0__0 SIM status: Locked Unlock process started at 30/05/2019 12:46:25 Detecting port... Port detected: COM209 Switching device to download mode... Device VID_12D1&PID_1506 removed Device VID_12D1&PID_1C05 inserted Device found Setting device to download... Device Product: HUAWEI B710D0__0 Downloading data... Downloading data... Downloading data... Downloading data... Downloading data... Downloading data... Downloading data... Downloading data... Downloading data... Downloading data... Downloading data... Downloading data... Data successfully downloaded Switching device to diagnostic mode... Device VID_12D1&PID_1C05 removed Device VID_12D1&PID_1C05 inserted Searching ports in diagnostic mode by VID_12D1 Resetting device Unlock process finished OK at 30/05/2019 12:48:36 |
The Following User Says Thank You to md_amin For This Useful Post: |
06-03-2019, 12:55 | #15182 (permalink) |
Major Poster Join Date: Jan 2016 Location: WEST AFRICA
Member: 2524536 Status: Offline Thanks Meter: 13 | Alcatel 5033x unlock done... Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MediaTek USB Port (COM1)) Preparing to start meta mode; Requesting authorization; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739,S01 Sw version: Hw Version: alps-mp-o1.mp1-V1.54_k39tv1.bsp_P32 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R2.MP.V18.P77 Hw Version: TK_MD_L4_HW Reading phone info; IMEI 1: .............................. IMEI 2: 000000-00-000000-0 Loading config; Done; Working; Unlocking; Phone unlocked; Remove battery and cable; Time needed - 00:01:10 Log file saved to: LOG_3_06_2019_11_37_45.txt |
06-04-2019, 09:31 | #15183 (permalink) |
Freak Poster Join Date: Aug 2012 Location: Armenia Yerevan
Member: 1801587 Status: Offline Thanks Meter: 230 | Vortex synq unlock ok Select Alcatel OT 5025D Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MediaTek PreLoader USB VCOM (Android) (COM7)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739,S01 Sw version: Hw Version: alps-mp-o1.mp1-V1.209 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R2.MP.V54 Hw Version: TK_MD_BASIC_HW Reading phone info; IMEI 1: 353439-10-XXXXXX-1 IMEI 2: 358789-06-XXXXXX-6 Loading config; Done; Working; Unlocking; Phone unlocked; Remove battery and cable; Time needed - 00:00:24 |
The Following User Says Thank You to usta arman For This Useful Post: |
06-05-2019, 10:57 | #15184 (permalink) |
Freak Poster Join Date: Jun 2005 Age: 47
Member: 154051 Status: Offline Thanks Meter: 36 | IMO Q UNLOCK SUCCESSFULLY DONE ONE CLICK WITH SPD Service Tool v1.0.0.3500, I CHOOSE: Diag mode and Model: GENERIC METHOD 2 Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem440.inf,%dc_diag%;SPRD U2S Diag) Preparing to sync; Port opened [COM115]; Entering diagnostic mode; Done; Chip type: 8860:B100 Platform Version: MOCORTM_14B_7731C_W16.12.2_Debug Project Version: sc7731C_CP0_modem BASE Version: TM_BASE_15B_W16.12.2 HW Version: sc7731C_CP0_modem 03-11-2016 21:00:19 Build number: IMO_Q_VM-user 5.1 LMY47D eng.root.20160720.154640 release-keys PHONE INFO: BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: ......-..-......-. SW IMEI[1]: ......-..-......-. SW IMEI[2]: ......-..-......-. SW IMEI[3]: ......-..-......-. SIMLOCK FLAG: ON SIM_LOCK TYPE: 2 IMEI: ......-..-......-. UNLOCK CODE: 86811400 Done; Phone unlocked; Remove battery and cable; |
06-05-2019, 14:55 | #15185 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | ZTE R570 UNLOCK DONE ON FG TEAM Using library Brom_DLL_v5.1428.0 EMI Settings Loaded; Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MTK USB Port (COM50)) Preparing to start flash mode; Connecting; Downloading DA; Initializing; Requesting baudrate change; Done; DEVICE INFO: BB CHIP: MT6261_S0000 [CA00, 00, 6261, 05] MEMORY: [GigaDevice] GD25LQ32 [C8:60:16] [SIZE=0x00400000] FAT INFO: 0x003A7000 SIZE: 0x00057000 Loading the file ... Cfg done ... File contents to write: [70006000-70007EAB] ARM_BL [10002800-100096E3] ARM_EXT_BL [1000A000-100C1813] PRIMARY_MAUI [100C1C14-103A08D3] VIVA Downloading bootloader... Done; Pre-formatting code area.. Done; Downloading images... Done; Done; Done; Done; Formatting file system now... Done; Time needed - 00:00:40 Log file saved to: LOG_5_06_2019_15_54_00.txt |
06-06-2019, 17:42 | #15186 (permalink) |
No Life Poster Join Date: Aug 2016 Location: A few details about yourself Age: 33
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | Wiko Sunny 3 SPD W_K120 unlock successfully Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem219.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM30]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_17C_W18.23.4_P2_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.23.4_P2 HW Version: sc7731e_modem 06-20-2018 11:11:40 Build number: W_K120SUN-user 8.1.0 OPM2.171019.012 1536724428 release-keys PHONE INFO: BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 358074-09-551539-4 SW IMEI[1]: 358074-09-559619-6 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON SIM_LOCK TYPE: 3 IMEI: 358074-09-551539-4 UNLOCK CODE: 88190623 Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_6_06_2019_18_36_35.txt Time needed - 00:00:03 |
06-10-2019, 10:25 | #15188 (permalink) |
No Life Poster Join Date: Jun 2006 Location: ..::SL3 Unlock Source::.. Age: 38
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | alcatle 1054x unlock Done 1 click SPD Service Tool pack 2 Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem39.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM399]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2018, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: 1054X-3AVDGB2 BT ADDR: C6:B3:52:03:4E:4C SW IMEI[0]: 358299-07-531229-4 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 303B8000 Reading NV; NV saved to : NV_000000-00-000000-0_358299-07-531229-4_65310001_10_06_2019_15_21_00.spd IMEI: 358299-07-531229-4 UNLOCK CODE: 17531594 or 3582990717531594 Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_10_06_2019_15_21_30.txt |
06-13-2019, 11:45 | #15189 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Pretoria South Africa Age: 45
Member: 132635 Status: Offline Thanks Meter: 360 | huawei Y6 ATU-L22 imei done 2019/06/13 12:42:41 PM FlyCaptain Huawei Module v2.0.0.0182 Furious Gold Pack 7 Dongle S/N: 6CECD991 Before detection connect cable to usb and enable Manufacture mode ! Qualcomm and HiSilicon: *#*#2846579#*#* MTK: *#*#14789632#*#* Windows: ##2846579# ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode (for MTK other/debug mode) 2019-06-13 12:43:03.087 Autodetect started! 2019-06-13 12:43:03.964 Found COM port: COM202 2019-06-13 12:43:03.968 Open port COM202 (DBAdapter Reserved Interface (COM202))... 2019-06-13 12:43:04.078 Start read phone info! 2019-06-13 12:43:04.084 Read secure info... 2019-06-13 12:43:04.310 Read basic info... 2019-06-13 12:43:04.366 Detect phone done! Model: ATU-L22 IMEI: 862418042317769 SUB_IMEI: 862418042317777 Firmware model: ATU-L22 SN: QFJ9X18915G05216 Custom SN: QFJ9X18915G05216 WiFi MAC: 24:2E:02:B2:5E:2B BlueTooth MAC: 24:2E:02:B2:5E:2C Vendor: hw Country: meafnaf eMMC: 16GB IMEI 1 Sim Lock status: NET: unlocked NETSUB: unknown SP: unknown Fixed IMEI 1 CRC: 352418042317758 Fixed IMEI 2 CRC: 352418042318889 2019-06-13 12:43:33.822 Autodetect started! 2019-06-13 12:43:34.681 Found COM port: COM202 2019-06-13 12:43:35.732 Repairing start New IMEI 1 : 352418042317758 New IMEI 2 : 352418042318889 2019-06-13 12:43:35.751 Connecting to server... 2019-06-13 12:43:37.701 Connected! 2019-06-13 12:43:37.707 Read data from server... 2019-06-13 12:43:40.540 Read data from server success! 2019-06-13 12:43:40.559 Open COM port COM202 (DBAdapter Reserved Interface (COM202))... 2019-06-13 12:43:51.958 Read secure info... 2019-06-13 12:43:52.196 Read basic info... 2019-06-13 12:43:52.249 Repair phone security data start! 2019-06-13 12:43:52.260 Calculating phone secure data... 2019-06-13 12:44:04.222 Calculate phone secure success! 2019-06-13 12:44:04.230 Writing phone secure data... 2019-06-13 12:44:04.417 Writing phone secure data success! 2019-06-13 12:44:05.229 Repair phone security data success! 2019-06-13 12:44:05.247 Repairing IMEI 2... 2019-06-13 12:44:05.262 Calculating SUB_IMEI secure data... 2019-06-13 12:44:09.381 Calculate success! 2019-06-13 12:44:09.398 Writing SUB_IMEI secure data... 2019-06-13 12:44:09.568 Writing SUB_IMEI secure data success! 2019-06-13 12:44:10.364 Repair IMEI 2 success! 2019-06-13 12:44:10.382 Factory reset... 2019-06-13 12:44:10.507 Factory reset success! 2019-06-13 12:44:11.199 Finished! |
The Following User Says Thank You to usman0000 For This Useful Post: |
06-13-2019, 11:47 | #15190 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: FMI OF Age: 52
Member: 866455 Status: Offline Sonork: SAMSUNG CPID ONLINE Thanks Meter: 577 | Alcatel 5053y unlock and frp done add new model big thnx furious team Quote:
06-16-2019, 12:41 | #15191 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | ZTE P16 Phone Lock Remove Done Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem25.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM17]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6530:C000 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0015 - SIZE : 00200000 Reading phone info; PHONE INFO: NONE BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 866065-02-823208-6 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: OFF FIXED NV BASE: 301D0000 Searching fs start and end addr; Formatting 301D8000-30200000; Starting format; Formatted; Done; Remove battery and cable; Log file saved to: LOG_16_06_2019_10_29_04.txt Time needed - 00:00:21 |
06-17-2019, 15:35 | #15192 (permalink) |
Member: 1801587 Status: Offline Thanks Meter: 230 | BLU C5L(C0040UU) unlock done Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem120.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM102]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_17B_Release_W18.39.7_P4_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_17B_Release_W18.39.7_P4 HW Version: sc9832e_modem 12-17-2018 19:20:07 Build number: sp9832e_fs097_go_project-user 8.1.0 OPM2.171019.012 02209 release-keys PHONE INFO: BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 355449-10-000106-4 SW IMEI[1]: 867400-02-031662-0 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON SIM_LOCK TYPE: 3 IMEI: 355449-10-000106-4 UNLOCK CODE: 89310163 Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_17_06_2019_18_25_25.txt Time needed - 00:00:08 |
The Following 4 Users Say Thank You to usta arman For This Useful Post: |
06-19-2019, 17:47 | #15195 (permalink) |
No Life Poster Join Date: Feb 2009 Location: nicaragua
Member: 980307 Status: Offline Sonork: 100.1649165 Thanks Meter: 173 | new tested model spd android.. NYX FIT unlock done Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem61.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM203]; Entering diagnostic mode; Done; Chip type: 8860:B100 Platform Version: MOCORTM_W17.14.5_Debug Project Version: sc7731C_CP0_modem BASE Version: TM_BASE_W17.14.5 HW Version: sc7731C_CP0_modem 04-07-2017 14:07:41 Build number: FIT-user 7.0 NRD90M lvxp10091508 release-keys PHONE INFO: BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 354671-09-086405-9 SW IMEI[1]: 867400-02-031662-0 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON SIM_LOCK TYPE: 3 IMEI: 354671-09-086405-9 UNLOCK CODE: 80898053 Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_19_06_2019_09_39_42.txt Time needed - 00:00:06 |
The Following User Says Thank You to daryl007 For This Useful Post: |
