09-20-2019, 16:41 | #15271 (permalink) |
No Life Poster Join Date: Jan 2017 Location: Jamaica
Member: 2673816 Status: Offline Thanks Meter: 612 | Alcatel 7 (6062W) new security unlock done Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM45)) Preparing to start flash mode; Preparing to open COM45 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: db679c8164184029df561143a523d4cb Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6763 [CA01, 01, 6763, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0x66BF0742 0x295602F2 [SIZE=0x748800000] IMEI1 [OTP 0001]: 015126-00- IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 6062W-2BTBUS7 USRDATA INFO: 0x13B800000 SIZE: 0x6088FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:00:00 Checking data integrity; Data integrity: OK; SIM_LOCK: ENABLED Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:00:04 |
The Following 2 Users Say Thank You to ThePhoneTechDoc For This Useful Post: |
09-24-2019, 13:42 | #15272 (permalink) |
Freak Poster Join Date: Jan 2012 Location: Sylhet Korim Ullah Market Age: 28
Member: 1714226 Status: Offline Sonork: 100.1683394 Thanks Meter: 243 | Alcatel A3 10 9026X unlock done Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM9)) Preparing to start flash mode; Preparing to open COM9 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 3590d1c29f9b304eec8c56781c1f8f7a Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM36; DEVICE INFO: BB CHIP: MT6737M [CA00, 00, 335, 05] HW_STORAGE_EMMC: 0x44000145 0x31303446 0xA10E0136 0x71548AD7 [SIZE=0x3AC000000] IMEI1 [OTP 0001]: 356801-08-021489-4 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 9026X-2COBGB1 USRDATA INFO: 0xEB000000 SIZE: 0x2BC880000 Searching data; Locked to [SIM1]: 234-10 code_cat_n: 73872082 enabled: yes tries: 10 code_cat_ns: 65111448 enabled: no tries: 10 code_cat_sp: 83874123 enabled: no tries: 10 code_cat_c: 07679421 enabled: no tries: 10 code_cat_sim: 15080663 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:05 Log file saved to: LOG_24_09_2019_16_55_28.txt |
09-27-2019, 10:51 | #15273 (permalink) |
Freak Poster Join Date: May 2007 Location: Meetiyagoda
Member: 504925 Status: Offline Thanks Meter: 55 | Alcatel 5041c Unlock done by FG OTSmart v1.0.0.3620 Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MTK USB Port (COM14)) Preparing to start meta mode; Requesting authorization; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739,S01 Sw version: Hw Version: alps-mp-o1.mp1-V1.112_k39tv1.bsp_P19 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R3.MP.V10.3.P23 Hw Version: TK_MD_L4_HW Reading phone info; IMEI 1: 015163-00-795433-1 IMEI 2: 000000-00-000000-0 Loading config; Done; Working; Unlocking; Phone unlocked; Remove battery and cable; Time needed - 00:00:34 Log file saved to: LOG_27_09_2019_15_12_57.txt |
The Following User Says Thank You to kalumetech For This Useful Post: |
09-27-2019, 20:04 | #15274 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Bangladesh
Member: 549972 Status: Offline Sonork: 100.1588180 Thanks Meter: 93 | IMEI REPAIR VIVO Y91C Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM_V1632 (Android) (COM56)) Preparing to start flash mode; Preparing to open COM56 Connecting; Downloading DA; Initializing; Rid: bd992cd2be6ea42716ff68bc066a971e Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333644 0xB8720142 0x4916AA9B [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x132800000 SIZE: 0x6118FBE00 Searching data; Checking data; IMEI repaired; Remove battery and cable; Time needed - 00:00:09 Log file saved to: LOG_28_09_2019_01_00_57.txt |
09-27-2019, 20:56 | #15275 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 252 | wikko y60 w-k510 unlock done used otsmart v1.0.03620 select vodafone vfd527 check remove simlock if promt unlock 2019 security lock choose NO important.. Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MediaTek PreLoader USB VCOM (Android) (COM10)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739 Sw version: Hw Version: alps-mp-p0.mp1-V5.20_tinno.sz.p0mp1.k39tv1.64.bsp_P22 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R3.MP.V37.3.P8 Hw Version: TK_MD_BASIC_HW Reading phone info; IMEI 1: 355572-10-xxxxxx IMEI 2: 3555xxxxx Loading config; Done; Working; Unlocking; Phone unlocked; Remove battery and cable; Time needed - 00:00:33 all done thanks team... but only sim 1 will work |
The Following User Says Thank You to simpleprince49 For This Useful Post: |
10-01-2019, 11:29 | #15276 (permalink) |
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 252 | wikko y6 w-k510 unlocked again now fully unlocked on sim 1 and sim 2.. Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MediaTek PreLoader USB VCOM (Android) (COM10)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739 Sw version: Hw Version: alps-mp-p0.mp1-V5.20_tinno.sz.p0mp1.k39tv1.64.bsp_P22 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R3.MP.V37.3.P8 Hw Version: TK_MD_BASIC_HW Reading phone info; IMEI 1: 355572-10-260446-8 IMEI 2: 355572-10-265488-5 Loading config; Done; Working; Unlocking; Unlocking SIM2; Phone unlocked; Remove battery and cable; Time needed - 00:00:35 Log file saved to: LOG_1_10_2019_10_26_21.txt thanks to mr hacker2k for full support.. |
10-01-2019, 14:37 | #15277 (permalink) |
Crazy Poster Join Date: Mar 2003 Location: Bucuresti / Romania Age: 46
Member: 25196 Status: Offline Thanks Meter: 32 | P Smart Fig-Lx1 9.1.0 FRP Test Point Fly Captain Huawei Resurrector 0.0.0.38 Device detected: COM315: HUAWEI USB COM 1.0 (COM315) BOOTLOADER File to update: Kirin659_T0_A8.0_V1 10/1/2019 4:28:58 PM Starting to write device... Process identifier:4707320 Writing bootloader... Writing Kirin659_T0_A8.0_V1_3.dtwork... Writing Kirin659_T0_A8.0_V1_4.dtwork... Waiting for fastboot device... Device found: XEDDU18227029168 Looking for a device in fastboot mode Device found: XEDDU18227029168 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... SN:XEDDU18227029168 IMEI:868659035708324 IMEI1:868659035760440 MEID:00000000000000 Build number: :FIG-LX1 9.1.0.120(C432E5R1P3) Model: FIG-LX1 Battery state: 0 OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Unlocking FRP... Writing FRP partition FRP partition UPDATE :FAIL partition error Writing FRP partition FRP partition UPDATE ...OK Software written 10/1/2019 4:29:40 PM Writing device finished OK |
10-02-2019, 10:40 | #15278 (permalink) |
No Life Poster Join Date: Jul 2010 Location: North Africa
Member: 1350724 Status: Offline Thanks Meter: 188 | motorola xt1773 frp remove done Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM85)) Preparing to start flash mode; Preparing to open COM85 Connecting; Downloading DA; Initializing; Rid: 9c459730f53c80dc1f22f14a53a83b31 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6737M [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x484A0190 0x61344741 0x7B4FA532 0x5354D1DD [SIZE=0x3AC000000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xF7800000 SIZE: 0x2B0080000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_2_10_2019_11_12_47.txt |
10-04-2019, 11:16 | #15279 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Pretoria South Africa Age: 45
Member: 132635 Status: Offline Thanks Meter: 360 | 2019-10-04 12:12:07.286 Autodetect started! 2019-10-04 12:12:18.379 Found COM port: COM250 2019-10-04 12:12:18.395 Open port COM250 (DBAdapter Reserved Interface (COM250))... 2019-10-04 12:12:18.504 Start read phone info! 2019-10-04 12:12:18.504 Connecting to server... 2019-10-04 12:12:21.281 Connected! 2019-10-04 12:12:21.297 Read data from server... 2019-10-04 12:12:23.699 Read data from server success! 2019-10-04 12:12:32.794 Read secure info... 2019-10-04 12:12:33.028 Read basic info... 2019-10-04 12:12:33.090 Detect phone done! Model: ATU-L01 IMEI: 867266030469992 Firmware model: ATU-L21 SN: 38R9X18602G05142 Custom SN: 38R9X18602G05142 WiFi MAC: C4:9F:4C:E3:45:10 BlueTooth MAC: C4:9F:4C:E3:45:11 Vendor: vodafone Country: za eMMC: 16GB IMEI 1 Sim Lock status: NET: unlocked NETSUB: unknown SP: unknown 2019-10-04 12:12:57.436 Autodetect started! 2019-10-04 12:12:58.512 Found COM port: COM250 2019-10-04 12:12:59.604 Repairing start New IMEI 1 : 352660304566446 2019-10-04 12:12:59.636 Connecting to server... 2019-10-04 12:13:01.554 Connected! 2019-10-04 12:13:01.570 Read data from server... 2019-10-04 12:13:03.582 Read data from server success! 2019-10-04 12:13:03.582 Open COM port COM250 (DBAdapter Reserved Interface (COM250))... 2019-10-04 12:13:10.587 Read secure info... 2019-10-04 12:13:10.805 Read basic info... 2019-10-04 12:13:10.852 Repair phone security data start! 2019-10-04 12:13:10.852 Calculating phone secure data... 2019-10-04 12:13:14.440 Calculate phone secure success! 2019-10-04 12:13:14.456 Writing phone secure data... 2019-10-04 12:13:14.658 Writing phone secure data success! 2019-10-04 12:13:15.126 Repair phone security data success! 2019-10-04 12:13:15.126 Factory reset... 2019-10-04 12:13:15.251 Factory reset success! 2019-10-04 12:13:15.267 Finished! |
10-06-2019, 12:03 | #15280 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM9)) Preparing to start flash mode; Preparing to open COM9 Connecting; Downloading DA; Initializing; Rid: d476e6021e0d749474edf05d01fe4e41 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem113.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM23; DEVICE INFO: BB CHIP: MT6582_S01 [CA01, 01, 6582, FF] HW_STORAGE_EMMC: 0x4B000115 0x4D565835 0xC8280142 0x5791FDE0 [SIZE=0xE9880000] IMEI1 [OTP 0001]: 863859-02-523130-4 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 7041X-2AVDZA2 USRDATA INFO: 0x65880000 SIZE: 0x80000000 Loading the file ... Cfg done ... Formatting file system now... Done; Formatting SECCFG partition now... Done; Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:05:32 Log file saved to: LOG_6_10_2019_12_56_56.txt |
10-08-2019, 09:24 | #15282 (permalink) |
Member: 1714226 Status: Offline Sonork: 100.1683394 Thanks Meter: 243 | Sagem my300C unlock done by fg Press power on shortly ... Starting communication ... MCU ID: 2BA0011743665DC1000000000000D41D ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:327E:4300 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my300C Hash: 000037D0 Algo: 05 Firmware: LH5,PG: 220607 1049 Imei: 355437011369860 Phone code: 0000 Prod. code: 252964634 Id calculation done; CODES: NET LO CODE: 0823863706 NET HI CODE: 1901799770 DIRECT UNLOCK: done Done ! Time needed - 00:02:39 thank you so much FuriouSTEAM... |
The Following User Says Thank You to rubelgsm For This Useful Post: |
10-08-2019, 12:31 | #15283 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,685 | Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM14)) Preparing to start flash mode; Preparing to open COM14 Connecting; Downloading DA; Initializing; Rid: fe9a6f4a61687642e2057dd4dab19461 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem175.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM17; DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, 05] HW_STORAGE_EMMC: 0x46000115 0x4D323145 0x343F0742 0xA7547FAA [SIZE=0x3A4A00000] IMEI1 [OTP 0000]: 358269-08-265396-4 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 5011A-2APWGBK USRDATA INFO: 0xE3000000 SIZE: 0x2BD280000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_8_10_2019_13_29_13.txt |
10-09-2019, 21:27 | #15284 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | HUAWEI MRD LX3 UNLOCK DONE Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM4)) Preparing to start flash mode; Preparing to open COM4 Connecting; Downloading DA; Initializing; Rid: 2c94deeea9d1d5d7dbe80acd6880ff1a Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333644 0xF3FC0142 0x7F167290 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x176800000 SIZE: 0x5D1200000 Searching data; Phone unlocked; Remove battery and cable; Time needed - 00:00:00 Log file saved to: LOG_9_10_2019_16_24_55.txt |
10-12-2019, 16:25 | #15285 (permalink) |
Registered User Join Date: Mar 2008 Location: @ blacksheep digital
Member: 731353 Status: Offline Thanks Meter: 253 | Tecno RB6S or pop 2X Air HARD LOCKED DONE VIA PACK2 WORLD FAMOUS Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem186.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM45]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_17B_Release_W18.26.1_P17_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_17B_Release_W18.26.1_P17 HW Version: sc9832e_modem 04-11-2019 11:41:41 Build number: RB6S-SU335-8.1-ZA-Voda-V004-20190702 PHONE INFO: BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 355189-10-048362-9 SW IMEI[1]: 354648-02-000000-4 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON SIM_LOCK TYPE: 3 IMEI: 355189-10-048362-9 UNLOCK CODE: 86714183 Done; Phone unlocked; Remove battery and cable; |
