01-05-2022, 08:09 | #15797 (permalink) |
No Life Poster Join Date: Oct 2009 Location: NIGERIA
Member: 1149419 Status: Offline Sonork: NIL Thanks Meter: 58 | Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem192.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 2.0.0.131) Preparing to sync; Port opened [COM3]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_20A_W21.29.6_Debug Project Version: sharkl5pro_pub BASE Version: 4G_MODEM_20A_W21.29.6 HW Version: sharkl5pro_modem 07-24-2021 03:27:06 Build number: ums512_1h10_project-user 11 RP1A.201005.001 34511 release-keys PHONE INFO: BT ADDR: SW IMEI[0]: 860598-05-001000-0 SW IMEI[1]: 112222-22-333332-4 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON BKP saved to : BKP_000000-00-000000-0_860598-05-001000-0_00000000_5_01_2022_08_02_21.spd SIM_LOCK TYPE: 3 IMEI: 860598-05-001000-0 UNLOCK CODE: 45750108 Done; Phone unlocked; Remove battery and cable; |
01-05-2022, 08:10 | #15798 (permalink) |
Member: 1149419 Status: Offline Sonork: NIL Thanks Meter: 58 | Hisense h50 lite unlocked Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem192.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 2.0.0.131) Preparing to sync; Port opened [COM3]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_20A_W21.29.6_Debug Project Version: sharkl5pro_pub BASE Version: 4G_MODEM_20A_W21.29.6 HW Version: sharkl5pro_modem 07-24-2021 03:27:06 Build number: ums512_1h10_project-user 11 RP1A.201005.001 34511 release-keys PHONE INFO: BT ADDR: SW IMEI[0]: 860598-05-001000-0 SW IMEI[1]: 112222-22-333332-4 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON BKP saved to : BKP_000000-00-000000-0_860598-05-001000-0_00000000_5_01_2022_08_02_21.spd SIM_LOCK TYPE: 3 IMEI: 860598-05-001000-0 UNLOCK CODE: 45750108 Done; Phone unlocked; Remove battery and cable; |
01-05-2022, 23:28 | #15799 (permalink) |
Insane Poster Join Date: Jan 2016 Location: Santiago de Cuba
Member: 2510340 Status: Offline Thanks Meter: 74 | unlock nokia ta-1351 done (nokia G10) Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5488 Searching phone in normal mode; [connect the phone powered off with volume down and up pressed to the usb cable] Phone detected (MediaTek USB Port (COM42)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM42 Device hw code: 0766 Device hw sub code: 8A00 Device hw version: CA00 Device sw version: 0000 Device secure boot: True Device serial link authorization: True Device download agent authorization: True Disabling watchdog timer; Done; Exploited; Sec code uploaded; Executed; Vodka time; Ready to party; Connecting; Downloading DA; Initializing; Rid: c6f822d600fd3c78103836d72c0c3885 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] BB ID: NTMxQTgyQUZFOEVCMTM5N0ZDRTI5MzI2ODBDRjY2QkE= HW_STORAGE_EMMC: 0x53030188 0x3233444C 0x47F55947 0x351821A9 [SIZE=0x73AC00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x1C0800000 SIZE: 0x575CF8000 Searching data; Phone unlocked; Remove battery and cable; Time needed - 00:00:01 Log file saved to: LOG_5_01_2022_16_12_25.txt |
01-11-2022, 11:51 | #15802 (permalink) | |
Banned Join Date: Nov 2010 Location: :::LONDON:::
Member: 1442994 Status: Offline Thanks Meter: 899 | ALCATEL 9013T finally software done with help of furious supporter Quote:
01-11-2022, 15:11 | #15803 (permalink) |
Freak Poster Join Date: Apr 2006 Location: P A K I S T A N (RWP)
Member: 267787 Status: Offline Thanks Meter: 71 | Nokia 2.4 TA-1275 Unlock Nokia 2.4 TA-1275 Unlock Done With Great Furious Tool Code:
The Following User Says Thank You to Anees-ur-rehman For This Useful Post: |
01-12-2022, 18:07 | #15804 (permalink) |
Freak Poster Join Date: May 2014 Location: Africa
Member: 2179221 Status: Offline Sonork: 100.1685104 Thanks Meter: 66 | Movicel Style Unlock and Read Code Done With Furiousgold Made of the place for Genius, Furiousgold A professional box for professional for the professional. ------------------------------------------------- LOG : Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem106.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 4.19.38.134) Preparing to sync; Port opened [COM4]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Chip type: 7702:0000 Starting auth; Memory NAND [CS0]: 0098:00B1 - SIZE : 08000000 EFUSE HASH: 0000000000000000000000000000000000000000 EFUSE LOCK STATUS: 000E 000E 000E 000E 000E HW IMEI : 000000-00-000000-0 Reading phone info; PHONE INFO: NONE BT ADDR: 55:08:11:05:53:35 SW IMEI[0]: 865806-02-185426-4 SW IMEI[1]: 865806-02-185427-2 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 40040000 Reading NV; NV saved to : NV_000000-00-000000-0_865806-02-185426-4_77020000_12_01_2022_17_15_17.spd IMEI: 865806-02-185426-4 UNLOCK CODE: 56786307 Code reading finished; Remove battery and cable; Log file saved to: LOG_12_01_2022_17_16_10.txt Time needed - 00:01:23 ESIMBI NDEKO |
01-13-2022, 10:49 | #15805 (permalink) |
No Life Poster Join Date: Jul 2010 Location: North Africa
Member: 1350724 Status: Offline Thanks Meter: 188 | alcatel 5030d spd frp remove done Searching phone; For an successful connection do the following: 1. Power on the phone and power it off 2. Keep pressed firmly volume DOWN key 3. Insert the usb cable inside the phone while keeping pressed volume DOWN Phone detected (@oem143.inf,%dvcdsc%;SCI USB2Serial) (Driver version: 1.5.6.1) Preparing to sync; Port opened [COM3]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2019, FuriouSTeaM Starting FDL2; FDL2 sent; Starting auth; memory_type: IF_TYPE_MMC dev_no: 0 part_type: PART_TYPE_UNKNOWN vendor: Man 000088 Snr b6ad3c90 product: SLD32G revision: 5.5 memory_size: 28,9 GB HW IMEI : 000000-00-000000-0 PHONE INFO: Alcatel 1SE Android 10 V1.0 PHONE ID: MDQzNTA3YTEwMDkxMzE5Mw== BT ADDR: NONE SW IMEI[0]: 35xxxxx SW IMEI[1]: 35xxxxx SW IMEI[2]: 867xxxx SW IMEI[3]: 867xxxx SIMLOCK FLAG: OFF Starting format; Formatted; Done; Remove battery and cable; Log file saved to: LOG_13_01_2022_10_47_53.txt Time needed - 00:00:56 remove this pot plz |
01-13-2022, 10:51 | #15806 (permalink) |
Member: 1350724 Status: Offline Thanks Meter: 188 | Searching phone; For an successful connection do the following: 1. Power on the phone and power it off 2. Keep pressed firmly volume DOWN key 3. Insert the usb cable inside the phone while keeping pressed volume DOWN Phone detected (@oem143.inf,%dvcdsc%;SCI USB2Serial) (Driver version: 1.5.6.1) Preparing to sync; Port opened [COM3]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2019, FuriouSTeaM Starting FDL2; FDL2 sent; Starting auth; memory_type: IF_TYPE_MMC dev_no: 0 part_type: PART_TYPE_UNKNOWN vendor: Man 000088 Snr b6ad3c90 product: SLD32G revision: 5.5 memory_size: 28,9 GB HW IMEI : 000000-00-000000-0 PHONE INFO: Alcatel 1SE Android 10 V1.0 PHONE ID: MDQzNTA3YTEwMDkxMzE5Mw== BT ADDR: NONE SW IMEI[0]: 35482xxxxxxxxxxxxx SW IMEI[1]: 35482xxxxxxxxxxxxx SW IMEI[2]: 86740xxxxxxxxxxxxx SW IMEI[3]: 86740xxxxxxxxxxxxx SIMLOCK FLAG: OFF Starting format; Formatted; Done; Remove battery and cable; Log file saved to: LOG_13_01_2022_10_47_53.txt Time needed - 00:00:56 alcatel 5030d spd frp remove done |
01-19-2022, 22:22 | #15807 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ZTE V20 SMART FIN SIN INVALID DONE ZTE 8010 PERM LOCK DONE Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem17.inf,%dvcdsc%;SCI USB2Serial) (Driver version: 1.5.6.1) Preparing to sync; Port opened [COM33]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_18B_W20.34.1_P4_Debug Project Version: sharkl3_pub BASE Version: FM_BASE_18B_W20.34.1_P4 HW Version: sc9863A_modem 10-24-2020 10:06:22 Build number: CLA_CO_P963F05V1.0.0B05 Friendly Name: OEY4M0QwQjFEMkIxM0EzQ0YzRDkwQjI1NzU0NERCMUVGRThFOU NCQQ== PHONE INFO: NONE BT ADDR: NONE SW IMEI[0]: 867805-05-1763 SW IMEI[1]: 867400-02-0316 SW IMEI[2]: 867400-02-0316 SW IMEI[3]: 867400-02-0316 SIMLOCK FLAG: OFF BKP saved to : BKP_000000-00-000000-0_867805-05-176370-8_00000000_19_01_2022_16_33_03.spd SIM_LOCK TYPE: 0 Analysing data; Please WAIT ! Starting auth; Getting data; Sending data; OK Check Done; PHONE ID: RTEwMzZCNDlDOTgwMTQ0MTQ5NkUzQUREQ0ZEREFDRDM= Security check result: 0 Connecting to server; Authorisation process started; Furious Multipurpose Credits: 6 Done; Requesting data from server ! Wait please ... Done; Phone unlocked; Remove battery and cable; |
01-27-2022, 18:12 | #15808 (permalink) |
No Life Poster Join Date: May 2010 Location: Haiti
Member: 1299439 Status: Offline Thanks Meter: 77 | Lg k40 (lm-x420mm) Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5488 Searching phone in emergency mode; [connect the phone in "Firmware Update" Mode. Hold the Volume Up on the powered off phone and enter the USB cable in order to enter it] Phone detected (USB\VID_1004&PID_633A&REV_0409) Preparing to start flash mode; Preparing to open COM96 Opened; Authorising; Authorized; LAF_ERROR_ACCESS_DENIED download_cable = 633A battery_level = 69 download_type = download_speed = 0 usb_version = UHS hardware_revision = rev_10 download_sw_version = device_sw_version = X420MM10r secure_device = S laf_sw_version = 1.1 device_factory_version = LMX420MMAT-02-V10r-310-160-AUG-05-2020-ARB00+0 device_factory_out_version = LMX420MMAT-00-V10r-310-160-AUG-05-2020-ARB00+0 pid = 9AOAAP52DE2D051GQ imei = 359962106XXXXXX model_name = LM-X420MM device_build_type = U chipset_platform = msm8953 target_operator = LAO target_country = COM ap_factory_reset_status = 6 cp_factory_reset_status = 0 isDownloadNotFinish = 0 qem = 0 cupss_swfv = A1596610576-M1596610576-FFFFFFFFFFF-U1596620115-0 is_one_binary_dual_plan = 0 memory_size = 61071360 memory_id = hB8aP> bootloader_ver = MiniOS 3.0 islan_download = 0 skip_readwrite = 0 Starting; Setting secure mode; Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Getting security info; Setting secure mode; Done; Working; Connecting to server; Authorisation process started; Furious Multipurpose Credits: 1 Done; Requesting data from server ! Wait please ... Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Done; Setting secure mode; Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Factory Reset Protection successfully removed ! Setting secure mode; Done; Time needed - 00:06:22 Log file saved to: LOG_27_01_2022_12_04_56.txt |
01-28-2022, 14:15 | #15809 (permalink) |
No Life Poster Join Date: Sep 2012
Member: 1813192 Status: Offline Thanks Meter: 60 | Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5488 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM33)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM33 Connecting; Downloading DA; Initializing; Rid: bcd0df015664bdfbe9a7f9bd48e65aae Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] BB ID: RUUwMUU2NTU5Q0IwOTUzOTFENDU4MEU4OTU3QzgyODQ= HW_STORAGE_EMMC: 0x684A0190 0x50613842 0x38C7013E 0x255687D5 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xEE000000 SIZE: 0x659A00000 Formatting FRP partition now... Done; Factory Reset Protection successfully removed ! Time needed - 00:00:08 Log file saved to: LOG_28_01_2022_14_05_07.txt succsessfull unlock frp honor 8s |
02-01-2022, 13:51 | #15810 (permalink) |
Freak Poster Join Date: Feb 2016 Location: ZIMBABWE
Member: 2534995 Status: Offline Thanks Meter: 93 | Huawei LUA-L01 FRP REMOVE DONE Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5201 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM_V1632 (Android) (COM8)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM8 Connecting; Downloading DA; Initializing; Rid: c24a4e0c130f19d5fdf37340bafe9563 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6735M [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x484A0190 0x65314738 0x51510705 0xEB736E0E [SIZE=0x1D2C00000] IMEI1 [OTP 0000]: 0;188>-30-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xD4000000 SIZE: 0xFCF80000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_1_02_2022_14_46_11.txt |
