07-06-2012, 11:42 | #10846 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Nov 4 2011 17:25:00 RELEASE DATE : Oct 26 2010 14:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-6050 IMEI : 86160300036013-0 BLUETOOTH ADDR : 9D 76 B7 B2 1A 68 TAG_ID:QCNDefP DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; CONTINUE DIRECT UNLOCKING; SIM_LOCK REMOVED ! RESET ! Time needed - 00:00:49 |
07-06-2012, 11:42 | #10847 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.6486 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 A4 37 45 94 20 0A A1 09 Flash ID(0): 0001:22C4 PARTIAL: TDS12_X17EV1.0.0B15-EnRu RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:04:00 |
07-06-2012, 11:45 | #10848 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Software engine version: 1.0.0.6486 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 5B 36 04 9A DE 06 22 08 Flash ID(0): 0001:22C4 PARTIAL: TDS12_X17EV1.0.0B15-EnRu RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:03:52 |
07-06-2012, 14:42 | #10849 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Comm opened 14 ! Baud set ! Auth made ! Sw version: Huawei g2100v100r001uzbc44b103sec test mode status: Off sim status: Off imei: 351633048892122 sn: 0 config done; defeating protection; defeated; working; sim_lock removed ! Time needed - 00:00:22 |
07-06-2012, 15:50 | #10850 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Comm opened 14 ! Baud set ! Auth made ! Sw version: Huawei g2100v100r001uzbc44b103sec test mode status: Off sim status: Off imei: 351633048896446 sn: 0 config done; defeating protection; defeated; working; sim_lock removed ! Time needed - 00:00:20 |
07-07-2012, 10:17 | #10851 (permalink) |
No Life Poster Join Date: Feb 2008 Location: KABUPATEN SLEMAN
Member: 714648 Status: Offline Sonork: 1609640 Thanks Meter: 931 | Succes UNLOCK HUAWEI U7519 with PACK 2 Searching phone ... Phone detected ... MODEL : Q62xx-FSBL STARTING; OK; LOADING; OK; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT NAND ROUTINES; NAND INIT MADE; LOOKING SENSITIVE DATA; OK; DONE; IMEI : 35619203449139-4 READING; SP_SAVED_TO: SP_35619203449139_DA7_04.08.39_08.07.2012_HUAWEI.b in CHECKING; LOCKED_TO: MCC-MNC [0]: 001-01 MCC-MNC [1]: FFF-FF MCC-MNC [2]: FFF-FF MCC-MNC [3]: FFF-FF MCC-MNC [4]: FFF-FF MCC-MNC [5]: FFF-FF MCC-MNC [6]: 160-FF MCC-MNC [7]: FF0-31 MCC-MNC [8]: FFF-FF MCC-MNC [9]: FFF-FF MCC-MNC [10]: FFF-FF MCC-MNC [11]: FFF-FF MCC-MNC [12]: FFF-FF MCC-MNC [13]: 310-20 MCC-MNC [14]: FFF-FF MCC-MNC [15]: FFF-FF MCC-MNC [16]: FFF-FF MCC-MNC [17]: FFF-FF MCC-MNC [18]: FFF-FF MCC-MNC [19]: 210-FF MATCHED; ERASING; WRITING; SIM_LOCK REMOVED ! RESET ! DONE ! Time needed - 00:01:49 |
The Following User Says Thank You to mr.omphonx For This Useful Post: |
07-08-2012, 09:52 | #10852 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | G1000 UFONE unlock done COMM OPENED 5 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820040482979 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:19 |
07-08-2012, 15:29 | #10853 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Comm opened 14 ! Baud set ! Auth made ! Sw version: Huawei g2100v100r001uzbc44b103sec test mode status: Off sim status: Off imei: 351633048910197 sn: 0 config done; defeating protection; defeated; working; sim_lock removed ! Time needed - 00:00:20 |
07-09-2012, 15:10 | #10854 (permalink) |
No Life Poster Join Date: Jan 2002 Location: 24° 51′ 36″ N, 67°
Member: 8353 Status: Offline Sonork: 113276 Thanks Meter: 335 | Telenor Alcatel one Touch 990 successfully unlocked!!!!!! Software engine version: 1.0.0.8143 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Feb 20 2012 19:51:00 RELEASE DATE : Jun 20 2011 03:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-6180 IMEI : 35576904382125-6 BLUETOOTH ADDR : D8 08 CD AC 71 94 ENTERING DOWNLOAD MODE; ENTERED; LOADING DATA; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT NAND ROUTINES; NAND INIT MADE; READING SEC INFO; SAVED: B47BB08F284B7D9453F93328D920B690.bin UNLOCK CODE: 0665907083 RESET ! Time needed - 00:01:39 |
07-09-2012, 16:02 | #10855 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | huawei u8081 unlock done!!!! Searching Huawei phone COM ports... not found ! Searching Android USB Interface... OK Checking bootloader status... not running! Connecting to server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Uploading bootloader... OK Starting bootloader... OK Sending data to server... OK Reading data from server... OK Sending boot data... OK Initializing NAND functions... OK Initializing NV functions... OK Server disconnected! Reading NV item #550...OK Reading NV item #114...OK Reading NV item #60001...OK Searching for OEMINFO data... OK Product name: U8150 Model name: Huawei U8180/SFR STARSHINE IMEI: 357232046193726 S/N: D5J4CD11C1303417 Firmware: U8180-1V100R001C00B620_EFS SIM Lock status: locked (NCK lock) 2012-07-09 15:56:55.171 Start unlocking procedure (357232046193726) Connecting to server... OK Sending data to server... OK Reading data from server... OK Checking bootloader status... OK Reading NV item #550...OK Checking bootloader status... OK Reading NV item #114...OK Searching for OEMINFO data... OK Creating backup of Sensitive Data... OK Backup saved to file "C:\Documents and Settings\BRYAN\Bureau\HUAWEI_ANDROID_UNLOCKER_0020 _2\Backup\357232046193726_2012-07-09_155757.fhb" Sending data to server... OK Reading data from server... OK Writing NAND... OK Verification... OK Reseting unblock retry counter... OK Sending data to server... OK Reading data from server... OK Server disconnected! 2012-07-09 15:58:21.468 Done! |
07-10-2012, 23:29 | #10856 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Paris Age: 48
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | sagem 411c Press power on shortly ... Starting communication ... MCU ID: 38600113846700C2000000000000FC12 ROM HASH: 731C27AB2AE00189FBD4FD3013B53252 ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: VF533 Hash: 00002878 Algo: 07 Firmware: EVN,ZJ: 011008 0841 Imei: 354649020100968 Phone code: 0000 Prod. code: 254067128 Id calculation done; CODES: NET LO CODE: 1085447001 NET HI CODE: 3750962232 DIRECT UNLOCK: ok Done ! Time needed - 00:02:59 Last edited by Nadoui; 07-10-2012 at 23:36. |
07-10-2012, 23:31 | #10857 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | ZTE SFR 112 Software engine version: 1.0.0.6486 Connect phone powered on ! Start auth ! SW Ver: EFSPI-FR-SFR-P108E10FM(S)V1.0.0B06 Imei: 353894030889710 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0103 Reading ... Saved: ZTE_353894030889710_EFSPI-FR-SFR-P108E10FM(S)V1.0.0B06_17.06.36_04.07.2012_PARTIAL. bin Erasing ... Writing ... Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:22 |
07-10-2012, 23:34 | #10858 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | Product: SFR3440 Provider ID: F344X-2[X=A]SFFR1 IMEI: 867242001112481 Start code calculate... NCK:2965156020 NSCK: SPCK: PCK: Code calculate finished successfully! Product: SFR3440 Provider ID: F344X-2[X=A]SFFR1 IMEI: 867242001299981 Start code calculate... NCK:2096415292 NSCK: SPCK: PCK: Code calculate finished successfully! Product: SFR3440 Provider ID: F344X-2[X=A]SFFR1 IMEI: 867242000203521 Start code calculate... NCK:4103184574 NSCK: SPCK: PCK: |
07-10-2012, 23:38 | #10859 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | ZTE sfr Staraddict Software engine version: 1.0.0.8143 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Feb 13 2012 02:05:00 RELEASE DATE : Oct 26 2010 14:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-6050 IMEI : 86853400072878-1 BLUETOOTH ADDR : A6 F9 9C B2 1A 68 TAG_ID:P743FB05 DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; CONTINUE DIRECT UNLOCKING; SIM_LOCK REMOVED ! RESET ! Time needed - 00:00:41 Press power on shortly ... Starting communication ... BootRom v05.02 Authorising ... Sending certificate ... Sending preloader ... Preloader started ... Sending applet ... Changing baudrate ... Flash ID(0): 0001:2A7E:2400 IMEI: 3534670220019600 Requesting mepd info ... Saved: LOCOSTO_18.09.27_29.06.2012_SP.bin Direct unlock finished. 0 locks were cleared. Done ! Time needed - 00:00:21 |
