DRA-LX2 imei DONE with great Furious Gold Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off with volume down and up pressed to the usb cable] Phone detected (MediaTek USB Port (COM3)) Preparing to start flash mode; Preparing to open COM3 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 7502f6e80046f265942f36e20bc1d812 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6739 [CB00, 02, 6739, 00] HW_STORAGE_EMMC: 0x484A0190 0x61344741 0x8ADFD432 0xF7C59B12 [SIZE=0x3AC000000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xEC000000 SIZE: 0x2BE3FBE00 Searching data; Checking data; IMEI repaired; Remove battery and cable; Time needed - 00:00:05 |
Alba Tab 10 AC101CPLV3 FRP Reset done Successfully removed FRP with Furious gold OTSmart. Select model as "Acrhos Sence 50 dc" Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off with volume up pressed to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM23)) Preparing to start flash mode; Preparing to open COM23 Connecting; Downloading DA; Initializing; Rid: 6f26de292ee4578ca37469e5cae9ddb2 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT8163 [CB00, 01, 8163, FF] HW_STORAGE_EMMC: 0x4D000115 0x46344741 0x1DD6F742 0x938FD3F3 [SIZE=0x3AB820000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xC6000000 SIZE: 0x2E4380000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_15_10_2019_10_50_13.txt |
vodafone y5 2019 unlock done Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM65)) Preparing to start flash mode; Preparing to open COM65 Connecting; Downloading DA; Initializing; Rid: 05100fb5f13114debed2de82e8eecc8f Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] HW_STORAGE_EMMC: 0x484A0190 0x61344741 0x77DFD432 0x7F161F6C [SIZE=0x3AC000000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xEE000000 SIZE: 0x2BD200000 Searching data; Phone unlocked; Remove battery and cable; Time needed - 00:00:00 Log file saved to: LOG_15_10_2019_19_13_36.txt |
huawei mrd-lx2 imei repair done successfully foriousgold.. |
Vodafone VFD513 network unlocked Software engine version: 1.0.0.10880 Searching phone ... MODEL : QCOM SERIES 51 COMPILED DATE : Jun 17 2017 11:25:00 RELEASE DATE : Apr 24 2017 03:00:00 FIRMWARE INFO : MPSS.JO.3.0-00291-8909_GEN_PACK-1 IMEI : 35785008023278-5 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: AU_VDF_P809V51V1.0.0B12 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: D:\Phones\FuriousGold\Software\QCOM_SMART_TOOL_v1. 0.0.10880\35785008023278_16_10_2019_19_07_50.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM26 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD reading_data; modem - 05004000 - 04000000 reading_data: ok; writing_data; modem_downgrade: ok; reading_data_after: ok; Looking for the interface; Port found [ZTE Handset Diagnostic Interface (COM70)] connect_server: OK; restore in progress: OK; SIM_LOCK REMOVED ! Log file saved to: LOG_16_10_2019_19_13_02.txt Time needed - 00:05:15 |
Tecno rb6s lock for ever one click done |
Furious gold unlock alcatel 5039d in 30 seconds FURIOUS GOLD PACK 5 SUCCESSFULLY UNLOCK ALCATEL 5039D IN JUST 30 SECONDS PROCEDURE: 1. Connect phone in EDL (adb reboot edl) 2. Open QCOM SMART TOOL MODULE 3. Select FIREHORSE MODE 4. Click on DO JOB My log Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem157.inf,%qcomserialportdesc90080%;Android HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM3 Connecting; Loading; Init; Port opened; Hello Received; MSM_ID: 0x000BE0E1 OEM_ID: 0x0042 MODEL_ID: 0x0047 PK_HASH: 79FBA8B6DC1F344D6D7D9C3252CAB3F25ED8A198A233C7DFDC 3E9A08B9DC789379FBA8B6DC1F344D6D7D9C3252CAB3F25ED8 A198A233C7DFDC3E9A08B9DC789379FBA8B6DC1F344D6D7D9C 3252CAB3F25ED8A198A233C7DFDC3E9A08B9DC7893 BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory size 14.6 GB, target id 8937 IMEI: 3533171000****-3 PTH: 09 PTS: D23 PROV_ID: 5039D-2BTWIE1 SBTADDR: 94:27:90:61:23:A3 SWIFIADDR: 94:27:90:53:69:9D HS_PN: SAA2DL00G10C SSN: 54LC06BPJGC01B3 Work id: 22021984 Done; Stype: 00000001 SECURITY: X2D0CR00CX00 Size: 00000400 Backup saved to: 35331710002***-3 Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_22_10_2019_05_41_40.txt Time needed - 00:00:30 |
2019-10-25 11:20:28.331 Autodetect COM port and phone type start! 2019-10-25 11:20:29.126 Found COM port: COM41 2019-10-25 11:20:29.126 Found phone type: Huawei Android phone (HiSilicon CPU) 2019-10-25 11:20:29.142 Open COM port COM41 (Android Adapter PCUI (COM41))... 2019-10-25 11:20:29.282 Start read phone info! 2019-10-25 11:20:34.415 Connecting to server... 2019-10-25 11:20:35.179 Connected! 2019-10-25 11:20:43.307 CP State: ready 2019-10-25 11:20:43.307 Read phone basic info... 2019-10-25 11:20:44.180 Read phone secure info... 2019-10-25 11:20:50.342 Read phone info done! Model: FIG-L11 MEID: 00000000000000 pESN: 00000000 IMEI: 865878034670219 IMEI2: 000000000000000 IMEI3: 865878034670219 IMEISV: 22 Firmware ver.: System 8.0.0.046(02PE) Dataver: FIG-LX1 8.0.0.122(C16)_DATA_FIG-L11_mtn_za SN: HBEDU18307006327 PCB SN: DU4MBH1839044968 WiFi MAC: 04:79:70:AA:48:42 BlueTooth MAC: 04:79:70:AA:53:FB Vendor: mtn Country: za FASTBOOT:Chipset-dallas8.0.0.001(012V)_FASTBOOT BOOT:System 8.0.0.046(02PE)_BOOT RECOVERY:(unknow) SYSTEM:System 8.0.0.046(02PE) MAINVER:System 8.0.0.046(02PE) DATAVER:FIG-LX1 8.0.0.122(C16)_DATA_FIG-L11_mtn_za APTIME:Thu Jan 4 12:59:34 CST 2018 RAM: 3G eMMC: 32G eMMC ID: 90014A484247346132D4C6F398672500 HUN: 6798F3C600000000 IMEI 1 Sim Lock status: NET: unlocked NETSUB: unlocked SP: unlocked 2019-10-25 11:20:51.278 Phone info data backup saved to file D:\All Device Software\Backup\20191025_112050_865878034670219.BA K Fixed IMEI 1 CRC: 865000765435353 2019-10-25 11:21:16.016 Autodetect COM port and phone type start! 2019-10-25 11:21:18.797 Found COM port: COM41 2019-10-25 11:21:18.812 Found phone type: Huawei Android phone (HiSilicon CPU) New IMEI 1 : 865000765435353 2019-10-25 11:21:19.000 Open COM port COM41 (Android Adapter PCUI (COM41))... 2019-10-25 11:21:19.187 Connecting to server... 2019-10-25 11:21:20.092 Connected! 2019-10-25 11:21:30.122 CP State: ready 2019-10-25 11:21:30.122 Read phone basic info... 2019-10-25 11:21:31.027 Read phone secure info... 2019-10-25 11:21:37.532 Phone info data backup saved to file D:\All Device Software\Backup\20191025_112137_865878034670219.BA K 2019-10-25 11:21:38.078 Read from server... 2019-10-25 11:21:38.827 Read from server success! 2019-10-25 11:21:41.869 Phone secure identify start 2019-10-25 11:21:47.423 Phone secure identify success! 2019-10-25 11:21:47.438 Writing IMEI 1 start 2019-10-25 11:21:47.438 Reading from server... 2019-10-25 11:21:49.919 Read from server success! 2019-10-25 11:21:50.886 Write IMEI success! 2019-10-25 11:21:54.084 Synchronize NV... 2019-10-25 11:21:54.552 Synchronize NV success! 2019-10-25 11:21:54.552 Factory reset... 2019-10-25 11:21:57.204 Factory reset success! 2019-10-25 11:21:57.220 Finished! |
ALTICE S70 UNLOCK DONE THANKS TO HACK3R2K FOR SUPPORT Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM5)) Preparing to start flash mode; Preparing to open COM5 Connecting; Downloading DA; Initializing; Rid: d2d2ba84b4981c59ef7792e612688f83 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6750 [CB00, 01, 6750, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333645 0x12010342 0xBBB4E7F2 [SIZE=0x3A4A00000] IMEI1 [OTP 0001]: 357581-08-031784-3 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x12F800000 SIZE: 0x270AFBE00 Searching data; File not found; Locked to [SIM1]: 370-01 code_cat_n: 12345678 enabled: no tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Locked to [SIM2]: 370-01 code_cat_n: 12345678 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:17 Log file saved to: LOG_25_10_2019_16_49_08.txt |
Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MTK USB Port (COM24)) Preparing to start flash mode; Preparing to open COM24 Connecting; Downloading DA; Initializing; Rid: b2eac11bc1162f71990c8357b632c0cc Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333644 0x18360142 0xAD7554D4 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x14E800000 SIZE: 0x5F9200000 Loading the file ... Cfg done ... Downloading bootloader... Done; Downloading images... Done; Success; Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MTK USB Port (COM24)) Preparing to start flash mode; Preparing to open COM24 Connecting; Downloading DA; Initializing; Rid: b2eac11bc1162f71990c8357b632c0cc Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333644 0x18360142 0xAD7554D4 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x14E800000 SIZE: 0x5F9200000 Searching data; Checking data; Contents saved to : C:\Users\Dream\Desktop\JAT-L29\HUAWEI JAT-L29_IMEI_47049DD5_F3EE2A72_b2eac11bc1162f71990c835 7b632c0cc_26_10_2019_14_46_43.osp Downloading images... Done; Searching phone; (insert the USB cable in the powered off phone) Phone detected (MediaTek PreLoader USB VCOM (Android) (COM6)) Preparing to start fastboot mode; Done; Fastboot mode entered; Connecting; switching_fastboot_mode: OK; resistance is futile : OK !?; data_written : OK; data_written : OK; data_written : OK; data_written : OK; data_written : OK; data_written : OK; data_written : OK; data_written : OK; data_written : OK; IMEI repaired; Remove battery and cable; Time needed - 00:01:26 Log file saved to: LOG_26_10_2019_14_48_07.txt |
Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem83.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM23]; Entering diagnostic mode; Done; Chip type: 8860:B100 Platform Version: MOCORTM_W17.14.5_Debug Project Version: sc7731C_CP0_modem BASE Version: TM_BASE_W17.14.5 HW Version: sc7731C_CP0_modem 08-08-2017 15:47:57 Build number: ww815_7731c_n_64v8-user 7.0 NRD90M eng.zqingh.20170830.212539 release-keys PHONE INFO: BT ADDR: 22:61:DB:CA:D8:A4 SW IMEI[0]: 352394-09-020250-9 SW IMEI[1]: 867400-02-031662-0 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON SIM_LOCK TYPE: 3 IMEI: 352394-09-020250-9 UNLOCK CODE: 85392253 Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_27_10_2019_12_18_28.txt Time needed - 00:00:04 |
Software engine version: 1.0.0.10880 Searching phone ... MODEL : QCOM SERIES 48 COMPILED DATE : Sep 2 2016 01:38:00 RELEASE DATE : Aug 17 2016 08:00:00 FIRMWARE INFO : MPSS.JO.1.2.c3-00123-8909_GEN_PACK-1 IMEI : 86224203039974-0 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: FNB_ZA_P809F52V1.0.0B08 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: E:\Software'\FG\Pack 5\QCOM_SMART_TOOL_v1.0.0.10880\86224203039974_27_1 0_2019_04_36_38.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM26 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD Looking for the interface; Port found [ZTE Handset Diagnostic Interface(DFU) (COM25)] connect_server: OK; restore in progress: OK; SIM_LOCK REMOVED ! Log file saved to: LOG_27_10_2019_04_40_12.txt Time needed - 00:03:37 |
A1 smart N9 or Vodafone smart N9 FRP done Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MTK USB Port (COM51)) Preparing to start flash mode; Preparing to open COM51 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 11ea822f139b1a84f9d9129c65fff88c Requesting baudrate change; Done; DEVICE INFO: BB CHIP: MT6739 [CB00, 02, 6739, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333645 0x0C510342 0xFB75A8E4 [SIZE=0x3A4A00000] IMEI1 [OTP 0001]: 359187-09-014579-0 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: V720-2BVDSI1 USRDATA INFO: 0x138000000 SIZE: 0x2682FBE00 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_30_10_2019_09_43_24.txt |
Huawei Y5 2019 frp Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM21)) Preparing to start flash mode; Preparing to open COM21 Connecting; Downloading DA; Initializing; Rid: ed4a7d4656ad0a20f25f618ebb8f883d Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333645 0x3E4A0442 0xE5C582CE [SIZE=0x3A4A00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xEE000000 SIZE: 0x2B5C00000 Formatting FRP partition now... Done; Factory Reset Protection successfully removed ! Time needed - 00:00:03 Log file saved to: LOG_30_10_2019_17_45_01.txt :) |
HUAWEI MRD LX3 UNLOCK DONE Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM4)) Preparing to start flash mode; Preparing to open COM4 Connecting; Downloading DA; Initializing; Rid: 8798c758f44e0ee48b4019e5d467c76a Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] HW_STORAGE_EMMC: 0x684A0190 0x50613842 0x8762013E 0x098617DC [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x176800000 SIZE: 0x5D1200000 Searching data; Phone unlocked; Remove battery and cable; Time needed - 00:00:00 Log file saved to: LOG_30_10_2019_13_15_02.txt |
