<<<<Succsessfully unlock zte t108 with furious-gold>>>> Here is log: Software engine version: 1.0.0.5949 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Feb 1 2010 19:08:00 RELEASE DATE : Nov 10 2009 00:00:00 FIRMWARE INFO : TEL_AU_P607C4V1.0.0B08-S IMEI : 35883403018617-5 BLUETOOTH ADDR : 85 36 71 1A 18 08 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 1 (MCC: 1 MNC: 1) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:10 Br: Harkishan |
G2158 sucessful unlock .................. G2158 sucessful unlock .................. Software engine version: 1.0.0.5472 Connect phone powered on ! Start auth ! SW Ver: REL_P1.1PU01V01.06 Imei: 35889203409???? Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Reading ... Saved: HUAWEI_35889203409????_REL_P1.1PU01V01.06_12.53.27 _10.02.2011_PARTIAL.bin Erasing ... Press reset button ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:59 br:. shabir97 |
GS390go Unlock done Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... UNLOCK CODES: NETWORK: 1991041963298954 NETWORK SUBSET: 8876776373677218 SERVICE PROV.: 5595903880516649 CORPORATE: 6429591960601681 SIM/USIM: 4900794658661298 Power on phone with original sim. Type 2945#*390# and enter code. Done ! Time needed - 00:00:19 |
Searching for usb device ... Reading info ... IMEI: 355767013995977 Calculating ... MEP LOCK: MEP-04598-005 MEP1 [SIM]: 0897639179539133 MEP2 [NETWORK]: 4394880172994096 MEP3 [NETWORK SUBSET]: 2420252964212772 MEP4 [SERVICE PROVIDER]: 6944363146022141 MEP5 [CORPORATE]: 1120518828188460 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:51 ----------------------------------------- > IMEI: 012295000462046 > NCK: 028532286044 > SPCK: 668796286536 FOR SOME MODELS TYPE *983*8284# OR ###825*09# (WITHOUT SIM) TO ENTER THE N.P. CODE. ---------------------------------------- Searching for usb device ... Reading info ... IMEI: 357154022517480 Calculating ... MEP LOCK: MEP-04104-007 MEP1 [SIM]: 5207586980574217 MEP2 [NETWORK]: 6745546607090480 MEP3 [NETWORK SUBSET]: 6018217609790087 MEP4 [SERVICE PROVIDER]: 2738312569714813 MEP5 [CORPORATE]: 8744830803217402 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:49 --------------------------- Starting cab upload; Preparing to install; Preparing to do application unlock; Application security unlock performed; Starting cab upload; Preparing to install; Checking installed file; Library and exe found; Reading data; DOC ID: 0000000082260203110E03420209067B00 Doing sp area internally backup; Please wait; Simlock area read failed ! ERROR: kioctl(FLASH, init1) - The network request is not supported. error initializing flash Trying alternative scanning method; Scanning 0 Saved: C:\Program Files\FuriouS-Gold\HTC_0000000082260203110E03420209067B00_14.41. 51_10.01.2011.bin IMEI: 35169501143776 NCK CODE: 44868963 Time needed - 00:00:42 ---------------------- Insert Battery In Phone ! Starting communication ... Speed changed ... Sending boot ... Boot sent ... Application started ... Flash ID : 0001:227E IMEI : 01034500055143-9 Version : C20.15 > fPLMN CR Blocked [%d] C1=%d_ Lock : OFF Phone is allready unlocked. Operation finished. Enter 2945#*# without a sim inside and select 'Fact. Reset'. Time needed - 00:00:04 ----------------------- Press power on ! Starting communication ... Platform: E-Gold Lite ... Preloader sent .... Loader sent .... Flash ID(0): 007F:22F6 Bypassing security ... LOCK: INACTIVE IMEI: 358503027228270 UNLOCK CODE: 00000000 Saved: INFINEON_13.13.06_12.01.2011_EEP.bin REMOVE BATTERY AND PUT BACK ! Time needed - 00:00:21 -------------------------- Searching for usb device ... Reading info ... IMEI: 355283046780964 Calculating ... MEP LOCK: MEP-07723-007 MEP1 [SIM]: 5089098752751714 MEP2 [NETWORK]: 4037770552795018 MEP3 [NETWORK SUBSET]: 9185324970515172 MEP4 [SERVICE PROVIDER]: 0087434423819676 MEP5 [CORPORATE]: 2833697899445385 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:45 ----------------------------------- > Model: V770 > IMEI: 353039016828262 > NCK: 1539567647 > NSCK: 1775796353 > SPCK: 3035734616 > SIM: 2415849583 > C: 0905680467 > Other: 3225436973 ----------------------- Starting cab upload; Preparing to install; Preparing to do application unlock; Application security unlock performed; Starting cab upload; Preparing to install; Checking installed file; Library and exe found; Reading data; DOC ID: EC00E67542603439323731350202030800 Doing sp area internally backup; Please wait; Saved: C:\Program Files\FuriouS-Gold\HTC_EC00E67542603439323731350202030800_23.23. 52_19.01.2011.bin IMEI: 35563402021934 NCK CODE: 88118624 Time needed - 00:00:39 -------------------------- Press power on ! ASIC ID: 00040105 JTAG ID: B619 Platform: OMAP V1030 ... Baud rate change request ... Flash ID(0): 00AD:0036 Unlocking ... Reading ... Saved: OMAP_10.49.06_25.01.2011_EEP.bin IMEI: 01129800045239804 Writing ... Unlocked ! Resetting ... Done ! Time needed - 00:01:02 --------------------------------- Software engine version: 1.0.0.5368 Connect phone powered on ! Start auth ! SW Ver: P1.2JD01V01.04:ULC2GL Imei: 353081032814421 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:05 ------------------------ Starting cab upload; Preparing to install; Preparing to do application unlock; Application security unlock performed; Starting cab upload; Preparing to install; Checking installed file; Library and exe found; Reading data; DOC ID: 000000003F1901011D3A17BB060806D300 Doing sp area internally backup; Please wait; Simlock area read failed ! ERROR: kioctl(FLASH, init1) - The network request is not supported. error initializing flash Trying alternative scanning method; Scanning 0 Saved: C:\Program Files\FuriouS-Gold\HTC_000000003F1901011D3A17BB060806D300_15.05. 35_26.01.2011.bin IMEI: 35169501109683 NCK CODE: 82196539 Time needed - 00:00:33 ------------------------------------- Software engine version: 1.0.0.5949 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Jul 15 2009 11:34:00 RELEASE DATE : Jun 24 2009 19:00:00 FIRMWARE INFO : H3G_GB_P607C3V1.0.0B07-sec IMEI : 35674003003445-9 BLUETOOTH ADDR : B1 79 F8 A1 19 00 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:49 ----------------------------- Software engine version: 1.0.0.5949 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Dec 2 2009 11:18:00 RELEASE DATE : Aug 26 2009 02:00:00 FIRMWARE INFO : H3G_GB_P607C3V2.0.0B04-S IMEI : 35674003244953-1 BLUETOOTH ADDR : 0E 20 3F 4A 15 D0 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:48 ----------------------------- Searching for usb device ... Reading info ... IMEI: 980070002083761 Calculating ... MEP LOCK: MEP-15326-002 MEP1 [SIM]: 93881638 MEP2 [NETWORK]: 00610789 MEP3 [NETWORK SUBSET]: 77679401 MEP4 [SERVICE PROVIDER]: 88596114 MEP5 [CORPORATE]: 15617690 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:39 ------------------------------ Searching for usb device ... Reading info ... IMEI: 980046000427085 Calculating ... MEP LOCK: MEP-15326-002 MEP1 [SIM]: 94056528 MEP2 [NETWORK]: 18994109 MEP3 [NETWORK SUBSET]: 67486319 MEP4 [SERVICE PROVIDER]: 16513330 MEP5 [CORPORATE]: 39901764 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:39 ----------------------------- Press power on ! Starting communication ... Platform: S-Gold2 ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Baud rate changed ok ! Flash ID(0): 0089:88B0 0489 Flash ID(1): 0089:88B0 0489 Bypassing security ... CODE: 06321752 Power on phone with original sim. Type 2945#*9701# and enter code. Done ! Time needed - 00:04:53 --------------------------- Starting cab upload; Preparing to install; Preparing to do application unlock; Application security unlock performed; Starting cab upload; Preparing to install; Checking installed file; Library and exe found; Reading data; DOC ID: EC0043157E4E3038333631371C1C020800 Doing sp area internally backup; Please wait; Saved: C:\Program Files\FuriouS-Gold\HTC_EC0043157E4E3038333631371C1C020800_20.48. 22_07.02.2011.bin IMEI: 35727602030193 NCK CODE: 28561466 Time needed - 00:00:53 ---------------------------- Starting cab upload; Preparing to install; Preparing to do application unlock; Application security unlock performed; Starting cab upload; Preparing to install; Checking installed file; Library and exe found; Reading data; DOC ID: FFFFFFFFD9FFFFFF9A6B0D5F07009BD600 Doing sp area internally backup; Please wait; Simlock area read failed ! ERROR: kioctl(FLASH, init1) - The network request is not supported. error initializing flash Trying alternative scanning method; Scanning 0 Scanning 1 Saved: C:\Program Files\FuriouS-Gold\HTC_FFFFFFFFD9FFFFFF9A6B0D5F07009BD600_23.17. 33_10.02.2011.bin IMEI: 35286201207804 NCK CODE: 36089754 Time needed - 00:00:38 ----------------------------------------- |
unlock success ku250 & cu920 -------------------------------------------------------------------------------- thanks to furious team |
successfully unlock Z100 Software engine version: 1.0.0.4874 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865042912477 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 24 36 05 92 D1 04 90 11 Flash ID(0): 00C2:22A7 Saved: ZTE_352865042912477_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_12.43.43_11.02.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:48 |
Successfully unlock T156 Software engine version: 1.0.0.4874 Connect phone powered on ! Start auth ! SW Ver: P1.2PU02V01.01 Imei: 353081034534605 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_353081034534605_P1.2PU02V01.01_14.41.19_11. 02.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:40 |
Successfully Unlock T156 |
Vodafone 246 Vodafone 246 succesfully unlocked. Thank you Furious Team. BR. Software engine version: 1.0.0.5463 Insert cable in box now [NO BATTERY INSIDE PHONE] ! Starting communication ... Platform: E-Gold Voice3-32 [00 00] ... Preloader sent .... Loader sent .... Flash ID(0): 00EF:4016 Checking firmware version ... Detected: ED-DE-P118A2V1.0.0B10 Saved: ZTE_NONE_ED-DE-P118A2V1.0.0B10_14.45.47_11.02.2011_PARTIAL.bin Erasing ... Writing ... Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:44 |
T156 Done. Software engine version: 1.0.0.5419 Connect phone powered on ! Start auth ! SW Ver: P1.2nV01.05:ULC2GL Imei: 359428010214062 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:13 B,R. ;) |
friends which is the program to calculate the MEP2 of Blackberry? which software is used? please help |
F102 unlocked log: Quote:
MIANLINKS |
U890 Unlock Done Software engine version: 1.0.0.5901 Searching phone ... MODEL : U890 COMPILED DATE : Jun 7 2006 15:56:00 RELEASE DATE : Jun 7 2006 17:00:00 FIRMWARE INFO : U890-MSM6250A-V10a_wm-JUN-07-2006-H3G-UK IMEI : 35921300342333-8 BLUETOOTH ADDR : 87 4A 46 56 12 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:1980 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35921300342333800 BLUETOOTH ADDR: [OK] 874A46561200 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01:10 |
huawei t156 unlock done.................. huawei t156 ufone.. Software engine version: 1.0.0.5472 Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 35308103995???? Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_35308103995?????_P1.2PU03V01.01_16.21.15_12 .02.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:24 br:. shabir97 |
T156 Done. Software engine version: 1.0.0.5419 Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081037711978 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_353081037711978_P1.2PU03V01.01_18.13.02_12. 02.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:45 B,R. ;) |
