04-15-2020, 15:28 | #15436 (permalink) |
Registered User Join Date: Jan 2006 Location: Romania Age: 39
Member: 215866 Status: Offline Sonork: 100.1617874 Thanks Meter: 125 | Huawei Y7 2019 DUB-LX1 Frp done Phone detected (@oem168.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM134 Connecting; Loading; Init; Port opened; MSM_ID: 0x0009A0E1 OEM_ID: 0x0015 MODEL_ID: 0x0065 PK_HASH: 6BC369511DA9CADB3A7AF61574F89DB385003D6241BDD1FF57 3DBA61BF6AE1196BC369511DA9CADB3A7AF61574F89DB38500 3D6241BDD1FF573DBA61BF6AE1196BC369511DA9CADB3A7AF6 1574F89DB385003D6241BDD1FF573DBA61BF6AE119 BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory, target id 8953 start_frp_reset: OK; frp_reset: OK; Log file saved to: LOG_15_04_2020_17_13_03.txt Time needed - 00:00:13 |
The Following User Says Thank You to nae For This Useful Post: |
05-04-2020, 10:40 | #15437 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | kicka4 plus network unlock done here log not dont press any key for network unlocking Code: Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off with volume down and up pressed to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM6)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM6 Connecting; Downloading DA; Initializing; Rid: b555ce1a9ac1ce2831b4b0906fa752dd Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x45000170 0x41493445 0x03170134 0x47352411 [SIZE=0xE2480000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x73800000 SIZE: 0x6AC80000 Searching data; File not found; Locked to [SIM1]: 460-01 code_cat_n: 12345678 enabled: yes tries: 241 code_cat_ns: 56781234 enabled: no tries: 255 code_cat_sp: 11112222 enabled: no tries: 255 code_cat_c: 33334444 enabled: no tries: 255 code_cat_sim: 55556666 enabled: no tries: 255 code_cat_ns_sp: 77778888 enabled: no tries: 255 code_cat_sim_c: 99990000 enabled: no tries: 255 Phone unlocked; Remove battery and cable; Time needed - 00:00:07 Log file saved to: LOG_4_05_2020_11_35_00.txt |
05-06-2020, 17:09 | #15438 (permalink) | ||
No Life Poster Join Date: Jan 2005 Location: PT Age: 40
Member: 108180 Status: Offline Sonork: 100.106866 Thanks Meter: 381 | GRA-L09 Resurrection ( FAIL ) I have a gra-l09 and dead no power, i have make testpoint ( Huawei USB Com 1.0 ) driver installed. I try Repair Bootloader ( 2 Version of Kirin) and the same error Quote:
guedes666 | ||
05-06-2020, 17:56 | #15439 (permalink) |
No Life Poster Join Date: Jan 2006 Location: PORTUGAL
Member: 216446 Status: Offline Thanks Meter: 220 | ALCATEL OT-2005X UNLOCK Pack 6 furious otz flasher… Power off Select configration>>>usb Model 2005/2005d Select operation>>>>remove sim lock Connect Press * and connect usb in power off Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MediaTek USB Port (COM59)) Preparing to start meta mode; Requesting authorization; Done; Meta mode entered; Baseband Chip: MT6250 Sw version: MAUI.11B.W12.24.MP.V2.F21 Hw Version: JRDHZ50_12864_11B_24MP_HW Reading phone info; IMEI: 869795-01-100158-8 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:05 Log file saved to: LOG_6_05_2020_17_43_03.txt |
05-07-2020, 17:41 | #15440 (permalink) |
Member: 216446 Status: Offline Thanks Meter: 220 | vodafone vfd820 smart x9 frp done Frp Qcom smart tool>>>>furious>>> Put ftm mode ….zte hs-usb diagnastic mode Scan port Unlock Software engine version: 1.0.0.10962 Searching phone ... MODEL : QCOM SERIES 56 COMPILED DATE : Feb 18 2019 17:12:00 RELEASE DATE : Nov 29 2018 23:00:00 FIRMWARE INFO : MPSS.TA.3.0.c1-00366-8953_GEN_PACK-1.180411.1 IMEI : 35477709017052-8 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: VDF_P450K10V1.0.0B38 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: C:\Users\Etronics\AppData\Local\Temp\Rar$EXa6584.3 6381\35477709017052_7_05_2020_17_33_41.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM82 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22F9 start_frp_reset: OK; frp_reset: OK; Log file saved to: LOG_7_05_2020_17_36_58.txt Time needed - 00:03:21 |
05-09-2020, 18:21 | #15441 (permalink) |
No Life Poster Join Date: Aug 2011 Location: UK
Member: 1629133 Status: Offline Thanks Meter: 498 | Alcatel V795 unlock done Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM3)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM3 Connecting; Downloading DA; Initializing; Rid: 02b641a5efc173b7d945201239c9008a Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem19.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM4; DEVICE INFO: BB CHIP: MT6735M_S00 [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x51000115 0x4D533237 0x1EAF0042 0xB1A2269A [SIZE=0x1D2880000] IMEI1 [OTP 0001]: 352185-07-381039-5 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: V795-2BVDRO1 USRDATA INFO: 0x99000000 SIZE: 0x135480000 Searching data; Locked to [SIM1]: 226-01 code_cat_n: 2951680575807313 enabled: yes tries: 3 code_cat_ns: 1919933977860157 enabled: no tries: 10 code_cat_sp: 7007106002663450 enabled: no tries: 10 code_cat_c: 1985174223997100 enabled: no tries: 10 code_cat_sim: 5618025031603234 enabled: no tries: 10 code_cat_ns_sp: 5618025031603234 enabled: no tries: 5 code_cat_sim_c: 5618025031603234 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:35 |
05-10-2020, 18:01 | #15442 (permalink) |
No Life Poster Join Date: Apr 2005 Location: mars
Member: 132881 Status: Offline Thanks Meter: 105 | Nokia 1 ta1047 frp removed SELECTED ZTE BLADE A520 FROM THE OT SMART DROP DOWN AND BOOMMM!! Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM4)) (Driver version: 2.0.0.0) Preparing to start flash mode; Preparing to open COM4 Connecting; Downloading DA; Initializing; Rid: 05f15998418511ae74967fd748aa7d59 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6737M [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x484A0190 0x61344738 0xC634A532 0x95255D01 [SIZE=0x1D2C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x7F800000 SIZE: 0x151780000 SPECIAL NOTE: If you are using windows 10 x64 be sure that the installed mtk driver version is 3.0.1504.0 . Any different drivers will create random read bugs on newer chipset phones. As usual the correct drivers come inside OTSMart archive inside the "usb_driver" folder Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_10_05_2020_18_56_01.txt |
The Following 2 Users Say Thank You to toptech For This Useful Post: |
05-11-2020, 19:26 | #15443 (permalink) | ||
Member: 108180 Status: Offline Sonork: 100.106866 Thanks Meter: 381 | VFD 820 Aka Vodafone smart X9 Unlock Quote:
guedes666 | ||
05-14-2020, 10:59 | #15444 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Hatfield Harare Zimbabwe Age: 42
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | ZTE Blade A462 unlocking done by FuriousGold I first root phone kingoroot apk https://mega.nz/file/lc5D3R4A#aI6vFN...RkR8EhRqQtinkM Code: Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; BRAND: ZTE MODEL: ZTE BLADE A462 ANDROID: v6.0.1 CPU: QCOM IMEI: NA KERNEL: Linux version 3.10.49 (root@scl_xa243_184) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Sat Feb 4 13:23:44 CST 2017 Cleaning; Setting usb config; Done; Reconnecting; Looking for the interface; Port found [ZTE Handset Diagnostic Interface (COM10)] Backing up sensitive data; connect_server: OK; backup in progress: OK; Backup saved to: C:\My Software & Unlocking\FG Gold\Pack 5\ADB\ Done; Done; Done; Restarting the phone; Setting usb config; Done; Reconnecting; Looking for the interface; Port found [ZTE Handset Diagnostic Interface (COM10)] Restoring sensitive data; connect_server: OK; restore in progress: OK; Done; SIM_LOCK REMOVED ! POWER OFF / ON THE PHONE MANUALLY TO COMPLETE THE UNLOCK ! Log file saved to: LOG_14_05_2020_11_46_05.txt Time needed - 00:14:23 |
The Following User Says Thank You to johnmadzeka1 For This Useful Post: |
05-14-2020, 17:30 | #15445 (permalink) |
Insane Poster Join Date: Jan 2016 Location: Santiago de Cuba
Member: 2510340 Status: Offline Thanks Meter: 74 | unlock zte blade a3 lite Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly volume DOWN key 3. Insert the usb cable inside the phone while keeping pressed volume DOWN Phone detected (@oem180.inf,%dvcdsc%;SCI USB2Serial) (Driver version: 1.5.6.1) Preparing to sync; Port opened [COM109]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Starting auth; HW IMEI : 000000-00-000000-0 Analysing data; Please WAIT ! OK; PHONE INFO: NONE PHONE ID: MDA5MDE3OTMwODM1OTAyOQ== BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 8xxxxxxxxxxxxxx SW IMEI[1]: 86xxxxxxxxxxxxx SW IMEI[2]: 86xxxxxxxxxxxxx SW IMEI[3]: 86xxxxxxxxxxxxx SIMLOCK FLAG: ON Reading NV; NV saved to : NV_000000-00-000000-0_86xxxxxxxxxxxxx_98550000_25_04_2020_11_06_38.spd Gathering security data; Security check result: 0 Connecting to server; Authorisation process started; Done; Requesting data from server ! Wait please ... Re-programming; Security programmed; Sync NV; Done; Phone unlocked; Remove battery and cable; |
The Following User Says Thank You to duboy For This Useful Post: |
05-14-2020, 17:38 | #15446 (permalink) |
Member: 2510340 Status: Offline Thanks Meter: 74 | unlock alcatel 5024a Searching phone; For an successful connection do the following: 1. Power on the phone and power it off 2. Keep pressed firmly volume UP key 3. Insert the usb cable inside the phone while keeping pressed volume UP Phone detected (@oem100.inf,%dvcdsc%;SCI USB2Serial) (Driver version: 1.5.6.1) Preparing to sync; Port opened [COM34]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2019, FuriouSTeaM Starting FDL2; FDL2 sent; Starting auth; memory_type: IF_TYPE_MMC dev_no: 0 part_type: PART_TYPE_UNKNOWN vendor: Man 00008f Snr e0192314 product: UY5CS0 revision: 1.0 memory_size: 29,3 GB HW IMEI : 000000-00-000000-0 PHONE INFO: NONE PHONE ID: MTAzZTQ2OTgwMDkwMjIxMg== BT ADDR: NONE SW IMEI[0]: 35xxxxxxxxxxxxx SW IMEI[1]: 86xxxxxxxxxxxxx SW IMEI[2]: 86xxxxxxxxxxxxx SW IMEI[3]: 86xxxxxxxxxxxxx SIMLOCK FLAG: ON Reading NV; NV saved to : NV_000000-00-000000-0_355xxxxxxxxxxxx_98550000_24_02_2020_15_57_32.spd Gathering security data; Security check result: 0 Connecting to server; Authorisation process started; Done; Requesting data from server ! Wait please ... Re-programming; Security programmed; Sync NV; Done; Phone unlocked; Remove battery and cable; |
05-17-2020, 02:24 | #15447 (permalink) |
Member: 2510340 Status: Offline Thanks Meter: 74 | unlock 5032W Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MediaTek USB Port (COM137)) Preparing to start meta mode; Requesting authorization; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6765 Sw version: Hw Version: alps-mp-p0.mp1-V5.117_tct.tmo.p0mp1.k39tv1.64.bsp_P22 Baseband Chip: MT6765 Sw version: MOLY.LR12A.R3.MP.V66.11.P30 Hw Version: TK_MD_L4_HW Reading phone info; IMEI 1: 01xxxxxxxxxxxxx IMEI 2: N/A BB ID: MTA0N0FDQ0I1RDc4MzlBMDU1N0MzNjA2MDJBNTAyRjI= Working; Connecting to server; Authorisation process started; Done; Requesting data from server ! Wait please ... Checking data integrity; Data integrity: OK; SIM_LOCK: ENABLED Rebuilding security; Unlocking; Phone unlocked; Remove battery and cable; Time needed - 00:00:30 Log file saved to: LOG_16_05_2020_21_20_47.txt |
05-20-2020, 14:25 | #15449 (permalink) |
No Life Poster Join Date: Apr 2008 Location: nigeria
Member: 757064 Status: Offline Sonork: 11111111 Thanks Meter: 365 | alcatel 5049w successfull unlock done Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MTK USB Port (COM2)) (Driver version: 2.0.0.1) Preparing to start flash mode; Preparing to open COM2 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: b0dd81b29d15a2fc25b0d049e54a742d Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem182.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM1; DEVICE INFO: BB CHIP: MT6738 [CB00, 01, 6738, 00] BB ID: M0QxNEVFQ0RBODA0ODk5MTAwMDAwMDAwMDAwMDAwMDA= HW_STORAGE_EMMC: 0x51000115 0x4D333158 0x7C9E0742 0x4F155FC8 [SIZE=0x748800000] IMEI1 [OTP 0001]: 014976-00-616824-4 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5049W-2ATBUS1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 SPECIAL NOTE: If you are using windows 10 x64 be sure that the installed mtk driver version is 3.0.1504.0 . Any different drivers will create random read bugs on newer chipset phones. As usual the correct drivers come inside OTSMart archive inside the "usb_driver" folder Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:00:00 Checking data integrity; Data integrity: OK; SIM_LOCK: ENABLED Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:00:04 Log file saved to: LOG_20_05_2020_14_22_01.txt |
05-20-2020, 14:33 | #15450 (permalink) |
Member: 757064 Status: Offline Sonork: 11111111 Thanks Meter: 365 | One revvl 2 plus successfull unlock done Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MTK USB Port (COM2)) (Driver version: 2.0.0.1) Preparing to start flash mode; Preparing to open COM2 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 602b9126ce065344390237e64a9aabfe Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6763 [CA01, 01, 6763, 00] BB ID: QkRGMjAxMzNENjBEMzhGQzAwMDAwMDAwMDAwMDAwMDA= HW_STORAGE_EMMC: 0x47000115 0x4D423644 0x2DEB0142 0x79958D9A [SIZE=0x748800000] IMEI1 [OTP 0001]: 015248-00-SKYULOCK IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 6062Z-2CTBUS7 USRDATA INFO: 0x13B800000 SIZE: 0x6088FBE00 SPECIAL NOTE: If you are using windows 10 x64 be sure that the installed mtk driver version is 3.0.1504.0 . Any different drivers will create random read bugs on newer chipset phones. As usual the correct drivers come inside OTSMart archive inside the "usb_driver" folder Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:00:00 Checking data integrity; Data integrity: OK; SIM_LOCK: PARTIAL_UNLOCK Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:00:03 Log file saved to: LOG_20_05_2020_14_31_17.txt |
