05-22-2020, 16:19 | #15451 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,690 | Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MediaTek USB Port (COM361)) Preparing to start meta mode; Requesting authorization; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739,S01 Sw version: Hw Version: alps-mp-o1.mp1-V1.54_k39tv1.bsp_P36 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R2.MP.V18.P33 Hw Version: TK_MD_L4_HW Reading phone info; IMEI 1: 352060-10-219763-7 IMEI 2: 000000-00-000000-0 Working; Unlocking; Phone unlocked; Remove battery and cable; Time needed - 00:02:46 Log file saved to: LOG_22_05_2020_17_16_02.txt |
05-30-2020, 13:35 | #15452 (permalink) |
Freak Poster Join Date: May 2013 Location: india punjab
Member: 1930279 Status: Offline Sonork: 100.1663273 Thanks Meter: 113 | Huawei ascend y635-l03 unlock done by furious 2020-05-30 17:56:15.343 Autodetect started! 2020-05-30 17:56:26.163 Found COM port: COM14 2020-05-30 17:56:26.459 Connecting to server... 2020-05-30 17:56:28.166 Connected! 2020-05-30 17:56:28.182 Read data from server... 2020-05-30 17:56:32.249 Read data from server success! 2020-05-30 17:56:32.258 Open COM port COM14 (DBAdapter Reserved Interface (COM14))... 2020-05-30 17:56:39.419 Read secure info... 2020-05-30 17:56:39.470 Read basic info... 2020-05-30 17:56:39.572 Unlocking start 2020-05-30 17:56:43.743 Read data from server... 2020-05-30 17:56:50.386 Read data from server success! 2020-05-30 17:56:50.391 Writing security data... 2020-05-30 17:56:50.517 Write security data success! 2020-05-30 17:56:51.163 Unlock done! 2020-05-30 17:56:51.174 Job finished! |
06-03-2020, 12:46 | #15455 (permalink) |
No Life Poster Join Date: Jan 2006 Location: PORTUGAL
Member: 216446 Status: Offline Thanks Meter: 220 | Unlock vodafone vfd500 done Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM59)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM59 Connecting; Downloading DA; Initializing; Rid: c3be32923b52907e642265ad4130f9e5 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem140.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM64; DEVICE INFO: BB CHIP: MT6735M_S00 [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x30000111 0x37473830 0x51610030 0x294371CD [SIZE=0x1D2C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: V500-2AVDPT1 USRDATA INFO: 0xBD000000 SIZE: 0x111480000 Searching data; Locked to [SIM1]: 268-01 code_cat_n: 8053657405245871 enabled: yes tries: 9 code_cat_ns: 3413503409178736 enabled: no tries: 10 code_cat_sp: 5173457559674468 enabled: no tries: 10 code_cat_c: 2327674908451254 enabled: no tries: 10 code_cat_sim: 9409919598990412 enabled: no tries: 10 code_cat_ns_sp: 8391823918787605 enabled: no tries: 5 code_cat_sim_c: 8313251747747286 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:06 Log file saved to: LOG_3_06_2020_12_44_00.txt |
06-05-2020, 11:40 | #15456 (permalink) |
Freak Poster Join Date: Sep 2007 Location: VN
Member: 579694 Status: Offline Thanks Meter: 75 | Alcatel OT-4044W unlock ok . Pack 5 Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem53.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM15 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory size 3.5 GB, target id 8909 IMEI: 01468400317321-3 PTH: 10 PTS: C5S PROV_ID: 4044W-2BTBUS1 SBTADDR: 9C:4F:CF0:B2:63 SWIFIADDR: 9C:4F:CF:9A:B8:94 HS_PN: SAA61UBAA10C SSN: A7KF17CDAEB02KB Bruteforcing data; This operation can take up to 30 minutes !!! Done; Work id: 11DB6864 Done; Stype: 00000001 SECURITY: XWC5UMS2BR00 Size: 0000032F Backup saved to: 01468400317321-3 Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_5_06_2020_17_37_49.txt Time needed - 00:26:16 |
06-07-2020, 22:07 | #15457 (permalink) |
No Life Poster Join Date: Aug 2011 Location: UK
Member: 1629133 Status: Offline Thanks Meter: 498 | huawei p8 lite unlock done with pack 7 IMEI: 86XXXXXXXXXXX SUB_IMEI: 86XXXXXXXXXXX IMEISV: 98 Firmware ver.: ALE-B898 SN: QLF7N17329000963 Custom SN: 7N3MVK173T103753 WiFi MAC: 70:8A:09:19:E6:AA BlueTooth MAC: 70:8A:09:19:EA:A7 Vendor: vodafone Country: ro FASTBOOTailyBuild_201711171328_FASTBOOT BOOTailyBuild_201711171328_BOOT RECOVERYunknow) SYSTEM:ALE-L21C02B898_SYSTEM MAINVER:ALE-B898 DATAVERunknow) APTIME:Fri Nov 17 13:34:21 CST 2017 CUSTTIME:Wed Nov 22 13:04:35 CST 2017 RAM: 2G eMMC: 16G IMEI 1 Sim Lock status: NET: locked, unlock retry counts: 10 NETSUB: unlocked SP: unlocked 2020-06-02 18:37:32.719 Autodetect started! 2020-06-02 18:37:33.297 Found COM port: COM30 2020-06-02 18:37:34.527 Connecting to server... 2020-06-02 18:37:35.706 Connected! 2020-06-02 18:37:35.711 Read data from server... 2020-06-02 18:37:41.978 Read data from server success! 2020-06-02 18:37:41.983 Open COM port COM30 (Android Adapter PCUI (COM30))... 2020-06-02 18:38:00.144 CP State: ready 2020-06-02 18:38:00.149 Read phone basic info... 2020-06-02 18:38:01.320 Read phone secure info... 2020-06-02 18:38:11.118 Unlocking start 2020-06-02 18:38:11.119 Phone secure identify start 2020-06-02 18:38:14.423 Phone secure identify success! 2020-06-02 18:38:14.433 Read from server... 2020-06-02 18:38:15.715 Read from server success! 2020-06-02 18:38:18.113 Unlock done! 2020-06-02 18:38:18.119 Job finished! |
06-10-2020, 10:46 | #15458 (permalink) |
No Life Poster Join Date: Nov 2017 Location: Russian
Member: 2778414 Status: Offline Thanks Meter: 342 | MRD-AL00 Play market done On the advice of the FuriousGold team Firmware and model replacement Was MRD-AL00 Became JAT-L29 Everything works perfectly |
The Following User Says Thank You to solgeo For This Useful Post: |
06-10-2020, 14:43 | #15459 (permalink) |
Freak Poster Join Date: Apr 2014 Location: perú Age: 28
Member: 2169302 Status: Offline Thanks Meter: 51 | lg k20 REPAIR done k20 repair done with furious gold Using library Brom_DLL_v7.1813.3 Connecting; Check your phone and "Always allow from this computer" and select "OK". BRAND: LGE MODEL: LM-X120 ANDROID: v9 CPU: MMH6LM IMEI: 35xxxxxxxxxxxxx KERNEL: Linux version 4.4.146 (jenkins@LGMCSBS03-SP) (gcc version 4.9.x 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Tue Jul 2 12:12:31 -03 2019 Cleaning; Loading files; Done; Reconnecting; Setting access; Running app; Done; Config : 00000000 00000001 00000000 Connecting to server; Authorisation process started; Done; Requesting data from server ! Wait please ... Reading security; BBID: MDAyRUUzOTYyMzk0QUUzNjQyOEQzM0I4Qjc4QkQ0MzI= Checking security; Done; IMEI A: 35xxxxxxxxxxxxx IMEI B: 35xxxxxxxxxxxxx IMEI C: 35xxxxxxxxxxxxx WiFi ADDR: AC:F6:F7:E8:E9:EC BT ADDR: AC:F6:F7:72:F3:1E LOCK STATUS: 1 0 1 Contents saved to : E:\SEC_BKP_LG K20_35xxxxxxxxxxxxx.osp IMEI1 repaired; IMEI2 repaired; Rebooting; Time needed - 00:01:20 thanks team furious |
The Following 3 Users Say Thank You to elmiki1596321 For This Useful Post: |
06-16-2020, 12:19 | #15461 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,108 | Hisence F16 / E6 Network Lock Unlock Done Code: Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MediaTek PreLoader USB VCOM (Android) (COM17)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739,S01 Sw version: Hw Version: alps-mp-o1.mp1_P18 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R2.MP.V48.12.P4 Hw Version: TK_MD_BASIC_HW Reading phone info; IMEI 1: 3XXXXXXXXXXXXXXXXX IMEI 2: 3XXXXXXXXXXXXXXXXX Working; Unlocking; Phone unlocked; Remove battery and cable; Time needed - 00:00:34 Log file saved to: LOG_16_06_2020_13_02_57.txt
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
06-17-2020, 00:07 | #15462 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | Avvio a400 frp done SELECT DIAG MODE 3 THEN FORMAT FILE SYSTEM Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem110.inf,%dc_diag%;SPRD U2S Diag) (Driver version: 1.0.0.21) Preparing to sync; Port opened [COM4]; Entering diagnostic mode; Done; Chip type: 8860:B100 Platform Version: MOCORTM_W17.33.5_Debug Project Version: sc7731C_CP0_modem BASE Version: TM_BASE_W17.33.5 HW Version: sc7731C_CP0_modem 08-17-2017 21:02:54 Build number: HD405D_Avvio_DR-user 7.0 NRD90M eng.dhm.20190116.100143 release-keys PHONE INFO: BT ADDR: C6:36:14:1A:55:00 SW IMEI[0]: 352117-09-2586 SW IMEI[1]: 867400-02-031662-0 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON Starting factory reset; Modem imei: 3521170925869 Working; Done ! Log file saved to: LOG_16_06_2020_19_06_06.txt Time needed - 00:00:12 |
The Following 2 Users Say Thank You to maxpatri9 For This Useful Post: |
06-17-2020, 10:37 | #15463 (permalink) |
Freak Poster Join Date: Jul 2017 Location: Globe
Member: 2742707 Status: Offline Thanks Meter: 138 | ZTE A3 2019 IMEI Repair Done Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly volume DOWN key 3. Insert the usb cable inside the phone while keeping pressed volume DOWN Phone detected (@oem123.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 2.0.0.131) Preparing to sync; Port opened [COM29]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Starting auth; HW IMEI : 000000-00-000000-0 Analysing data; Please WAIT ! OK; PHONE INFO: NONE PHONE ID: MDA5MDE0OTYwNDBlMGExMg== BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 860250-04-XXXXXX-X SW IMEI[1]: 867400-02-031662-0 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: OFF Reading NV; NV saved to : NV_000000-00-000000-0_860250-04-XXXXXX-X_98550000_15_06_2020_13_54_29.spd Gathering security data; Security check result: 0 Connecting to server; Authorisation process started; Done; Requesting data from server ! Wait please ... Re-programming; Security programmed; Sync NV; Done; IMEI[0] repaired; Remove battery and cable; Log file saved to: LOG_15_06_2020_13_54_45.txt Time needed - 00:03:04 |
The Following User Says Thank You to ...::S.L.S::... For This Useful Post: |
06-19-2020, 21:27 | #15464 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Rep Dom Age: 38
Member: 884906 Status: Offline Sonork: none Thanks Meter: 77 | Huawei Y9 2019 DUB-LX3 Frp Reset (Test Point Method) Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem555.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM10 Connecting; Loading; Init; Port opened; Hello Received; MSM_ID: 0x0009A0E1 OEM_ID: 0x0015 MODEL_ID: 0x0065 PK_HASH: 6BC369511DA9CADB3A7AF61574F89DB385003D6241BDD1FF57 3DBA61BF6AE1196BC369511DA9CADB3A7AF61574F89DB38500 3D6241BDD1FF573DBA61BF6AE1196BC369511DA9CADB3A7AF6 1574F89DB385003D6241BDD1FF573DBA61BF6AE119 BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory, target id 8953 start_frp_reset: OK; frp_reset: OK; Log file saved to: LOG_19_06_2020_16_14_11.txt Time needed - 00:00:23 Easy, fast and cool |
The Following 2 Users Say Thank You to boliargsm For This Useful Post: |
06-23-2020, 12:39 | #15465 (permalink) |
No Life Poster Join Date: Aug 2012 Location: under pross
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,047 | zte blade a7 2019 spreadtrum repair done i got zte blade a7 2019 spreadtrum hang on zte logo thanks goes to mr .:hack3r2k:. thank you very much for the flash file and your support |
