09-24-2020, 13:27 | #15526 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | Nokia C1 TA-1165 Network Unlock Done Code: Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem47.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 2.0.0.131) Preparing to sync; Port opened [COM3]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_17C_W18.41.3_P26.03_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.41.3_P26.03 HW Version: sc7731e_modem 11-19-2019 14:05:07 Build number: k150-user 9 PPR1.180610.011 00WW_1_100 release-keys PHONE INFO: BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 353185-11-291241-7 SW IMEI[1]: 353185-11-297641-2 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON BKP saved to : BKP_000000-00-000000-0_353185-11-291241-7_00000000_24_09_2020_14_20_50.spd SIM_LOCK TYPE: 4 Analysing data; Please WAIT ! OK; Security check result: 0 Connecting to server; Authorisation process started; Done; Requesting data from server ! Wait please ... Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_24_09_2020_14_25_04.txt Time needed - 00:04:16 |
The Following User Says Thank You to yuranc8 For This Useful Post: |
09-24-2020, 23:01 | #15527 (permalink) |
Freak Poster Join Date: May 2014 Location: Africa
Member: 2179221 Status: Offline Sonork: 100.1685104 Thanks Meter: 66 | Unlock LG KU990 FuriousGold Done Software engine version: 1.0.0.10965 Searching phone ... MODEL : KU990 COMPILED DATE : Aug 15 2008 15:54:00 RELEASE DATE : Aug 15 2008 17:00:00 FIRMWARE INFO : KU990-MSM6280-V10i-AUG-15-2008-XX IMEI : 35493502632682-6 BLUETOOTH ADDR : 0A 97 C7 FB 21 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00bogg MEMORY INFO : 0800:0040:06C3 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Log file saved to: LOG_24_09_2020_22_54_03.txt Time needed - 00:00:06 In Qcom Module Pack 5 |
09-25-2020, 14:08 | #15528 (permalink) |
No Life Poster Join Date: Jan 2006 Location: PORTUGAL
Member: 216446 Status: Offline Thanks Meter: 220 | Using library Brom_DLL_v7.1413.5 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM91)) (Driver version: 3.2.0.0) Preparing to start flash mode; Preparing to open COM91 Connecting; Downloading DA; Initializing; Rid: 2c80445965bf81b738d79e11716901d0 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem303.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM210; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x504E01FE 0x34394A31 0x9659124D 0x9D722E75 [SIZE=0xE9B00000] IMEI1 [OTP 0001]: 357774-06-218076-4 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: V695-2BVDPT1 USRDATA INFO: 0x61B80000 SIZE: 0x87F80000 Searching data; Locked to [SIM1]: 268-01 code_cat_n: 00859963 enabled: yes tries: 10 code_cat_ns: 20529407 enabled: no tries: 10 code_cat_sp: 20908987 enabled: no tries: 10 code_cat_c: 21343805 enabled: no tries: 10 code_cat_sim: 02641892 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:15 Log file saved to: LOG_25_09_2020_14_01_09.txt |
09-25-2020, 18:09 | #15529 (permalink) |
Freak Poster Join Date: Oct 2007 Location: colombia
Member: 603138 Status: Offline Thanks Meter: 100 | Phone detected (MediaTek USB Port (COM42)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM42 Connecting; Downloading DA; Initializing; Rid: a4f35db85c6538b26c32ba785e1082d8 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] BB ID: RkI4QUQ2NEZGMzgzOThBODFDRjk2NTk1NzhEMTFCNTQ= HW_STORAGE_EMMC: 0x684A0190 0x50613843 0x1500013E 0x3F47DEFD [SIZE=0xE91000000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x158800000 SIZE: 0xD36E00000 Searching data; Checking data; NVRAM integrity check passed; Formatting NVDATA partition now... Done; IMEI repaired; Remove battery and cable; Time needed - 00:00:13 Log file saved to: LOG_25_09_2020_11_55_45.txt |
09-25-2020, 18:21 | #15530 (permalink) |
Registered User Join Date: Mar 2008 Location: @ blacksheep digital
Member: 731353 Status: Offline Thanks Meter: 254 | STYLO S40 Life network done via FG Searching phone; Phone detected (@oem108.inf,%vcom_preloader%;MediaTek PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on MediaTek USB VCOM (Android) (COM190); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6580B, E00 Sw version: MOLY.WR8.W1449.MD.WG.MP.V282.4 Hw Version: BIRD_Q0MP1_K80_BSP_HSPA_HW Reading phone info; IMEI: 354593-11-031xxxx Reading simlock info; Locked to: 655-07 code_cat_n: 12345678 enabled: yes tries: 16 code_cat_ns: 56781234 enabled: no tries: 20 code_cat_sp: 11112222 enabled: no tries: 20 code_cat_c: 33334444 enabled: no tries: 20 code_cat_sim: 55556666 enabled: no tries: 20 code_cat_ns_sp: 77778888 enabled: no tries: 20 code_cat_sim_c: 99990000 enabled: no tries: 20 Unlocking SIM2 too. Time needed - 00:01:01 Log file saved to: LOG_25_09_2020_19_09_02.txt |
09-26-2020, 11:07 | #15531 (permalink) |
Freak Poster Join Date: Dec 2013 Location: Saudi Arbia
Member: 2080403 Status: Offline Sonork: 100.1645596 Thanks Meter: 52 | MRD-Lx1F single click frp remove Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM39)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM39 Connecting; Downloading DA; Initializing; Rid: 4fc90ddf3e3490eea85864dcbe2c0c59 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] BB ID: RTNFOTNCQ0RCODM4QUI3RDcxQzYxREQxRDMzRjgyMDE= HW_STORAGE_EMMC: 0x51000115 0x4D333644 0xCEDC0142 0xBB461968 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xEE000000 SIZE: 0x659A00000 Formatting FRP partition now... Done; Factory Reset Protection successfully removed ! Time needed - 00:00:03 Log file saved to: LOG_26_09_2020_15_03_28.txt |
09-28-2020, 09:10 | #15532 (permalink) |
No Life Poster Join Date: Apr 2005 Location: mars
Member: 132881 Status: Offline Thanks Meter: 105 | Alcatel 5029D DONE!!! Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MTK USB Port (COM30)) (Driver version: 2.0.0.6) Preparing to start flash mode; Preparing to open COM30 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 846e1a799b8d25c4613379c87847370b Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] HW_STORAGE_EMMC: 0x534E0113 0x4B394A30 0x80181038 0x8D27AE6F [SIZE=0xE91000000] IMEI1 [OTP 0001]: 351547-11-xxxxxx-8 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5029D-2AVDGB22 USRDATA INFO: 0x193000000 SIZE: 0xCF8CFBE00 SPECIAL NOTE: If you are using windows 10 x64 be sure that the installed mtk driver version is 3.0.1504.0 . Any different drivers will create random read bugs on newer chipset phones. As usual the correct drivers come inside OTSMart archive inside the "usb_driver" folder Searching data; File not found; Phone unlocked; Remove battery and cable; Time needed - 00:00:01 |
09-29-2020, 14:45 | #15533 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,335 | Alcatel Tetra 5041C Resurrected DONE Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM20)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM20 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 80a2809fe707d982cb03be3e505988d0 Requesting baudrate change; Done; DEVICE INFO: BB CHIP: MT6739 [CB00, 02, 6739, 00] BB ID: MEZDM0I0RDBFRkQ4Q0I5QTc4QzAxNzBGNTE5MzUwOEE= HW_STORAGE_EMMC: 0x51000115 0x4D333645 0x57070342 0x0D85D2C2 [SIZE=0x3A4A00000] IMEI1 [OTP 0001]: 015163-00-441490-9 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5041C-2AAQUS6-R USRDATA INFO: 0x139000000 SIZE: 0x2672FBE00 Loading the file ... Cfg done ... Formatting file system now... Done; Formatting FRP partition now... Done; Formatting NVCFG partition now... Done; Formatting NVDATA partition now... Done; Formatting METADATA partition now... Done; Formatting SECCFG partition now... Done; Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:04:47 Log file saved to: LOG_29_09_2020_09_02_07.txt |
10-01-2020, 03:31 | #15534 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Chile
Member: 1797183 Status: Offline Thanks Meter: 148 | Zte Blade v10 Vita repair Imei ok... Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly volume DOWN key 3. Insert the usb cable inside the phone while keeping pressed volume DOWN Phone detected (@oem27.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 2.0.0.114) Preparing to sync; Port opened [COM14]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Starting auth; HW IMEI : 000000-00-000000-0 Analysing data; Please WAIT ! OK; PHONE INFO: NONE PHONE ID: MDgzNGMzOWUwMDkwMjlkNw== BT ADDR: NONE SW IMEI[0]: 868486-04-246035-4 SW IMEI[1]: 867400-02-031664-6 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON Reading NV; NV saved to : NV_000000-00-000000-0_868486-04-246035-4_98550000_1_10_2020_09_55_14.spd Gathering security data; Security check result: 0 Connecting to server; Authorisation process started; Done; Requesting data from server ! Wait please ... Re-programming; Security programmed; Sync NV; Done; IMEI[0] repaired; Remove battery and cable; |
10-01-2020, 03:35 | #15535 (permalink) |
Member: 1797183 Status: Offline Thanks Meter: 148 | Zte blade v10 vita Imei repair ok Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly volume DOWN key 3. Insert the usb cable inside the phone while keeping pressed volume DOWN Phone detected (@oem27.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 2.0.0.114) Preparing to sync; Port opened [COM14]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Starting auth; HW IMEI : 000000-00-000000-0 Analysing data; Please WAIT ! OK; PHONE INFO: NONE PHONE ID: MDgzNGMzOWUwMDkwMjlkNw== BT ADDR: NONE SW IMEI[0]: 868486-04-246035-4 SW IMEI[1]: 867400-02-031664-6 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON Reading NV; NV saved to : NV_000000-00-000000-0_868486-04-246035-4_98550000_1_10_2020_09_55_14.spd Gathering security data; Security check result: 0 Connecting to server; Authorisation process started; Done; Requesting data from server ! Wait please ... Re-programming; Security programmed; Sync NV; Done; IMEI[0] repaired; Remove battery and cable; |
10-01-2020, 19:15 | #15536 (permalink) |
No Life Poster Join Date: Dec 2008 Location: just around
Member: 914220 Status: Offline Thanks Meter: 206 | 5029e unloc success Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM25)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM25 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 97efb819ae252512ab0ee1d2e8a6b245 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] HW_STORAGE_EMMC: 0x534E0113 0x4B394A30 0x351A1038 0xD33784A1 [SIZE=0xE91000000] IMEI1 [OTP 0000]: 354059-11-062641-1 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 5029E-2CRGDO11 USRDATA INFO: 0x193000000 SIZE: 0xCF8CFBE00 Searching data; File not found; Phone unlocked; Remove battery and cable; Time needed - 00:00:01 Log file saved to: LOG_1_10_2020_14_05_34.txt |
10-01-2020, 19:18 | #15537 (permalink) |
Member: 914220 Status: Offline Thanks Meter: 206 | blade a3 lite success unlock Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly volume DOWN key 3. Insert the usb cable inside the phone while keeping pressed volume DOWN Phone detected (@oem360.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 2.0.0.131) Preparing to sync; Port opened [COM376]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Starting auth; HW IMEI : 000000-00-000000-0 Analysing data; Please WAIT ! OK; PHONE INFO: NONE PHONE ID: MDA5MDE0OTMwYTMwZDBhMg== BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 864538-04-118017-9 SW IMEI[1]: 867400-02-031662-0 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON Reading NV; NV saved to : NV_000000-00-000000-0_864538-04-118017-9_98550000_30_09_2020_18_14_54.spd Gathering security data; Security check result: 0 Connecting to server; Authorisation process started; Done; Requesting data from server ! Wait please ... Re-programming; Security programmed; Sync NV; Done; Phone unlocked; Remove battery and cable; |
10-02-2020, 02:10 | #15538 (permalink) |
Member: 2680008 Status: Offline Thanks Meter: 1,640 | Alcatel 5033G Write Firmware Done Code: Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MTK USB Port (COM3)) (Driver version: 2.0.0.1) Preparing to start flash mode; Preparing to open COM3 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: cefc6d9fb00f7bec238e75a172fac9d1 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6739 [CB00, 02, 6739, 00] BB ID: NDdDMzE5QzJBNjI4MzUzOEU4NjI2MkZGMDNEMzMzRDA= HW_STORAGE_EMMC: 0x46000115 0x4D323645 0x8FA20342 0xBFA625F2 [SIZE=0x3A4A00000] IMEI1 [OTP 0001]: 358710-10-136325-9 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x85000000 SIZE: 0x31B2FBE00 SPECIAL NOTE: If you are using windows 10 x64 be sure that the installed mtk driver version is 3.0.1504.0 . Any different drivers will create random read bugs on newer chipset phones. As usual the correct drivers come inside OTSMart archive inside the "usb_driver" folder Loading the file ... Cfg done ... Formatting file system now... Done; Formatting FRP partition now... Done; Formatting NVCFG partition now... Done; Formatting NVDATA partition now... Done; Formatting METADATA partition now... Done; Formatting SMART partition now... Done; Formatting TCTPERSIST partition now... Done; Formatting PROTECT1 partition now... Done; Formatting PROTECT2 partition now... Done; Formatting SECCFG partition now... Done; Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:02:36 Log file saved to: LOG_2_10_2020_03_05_15.txt |
The Following 2 Users Say Thank You to yuranc8 For This Useful Post: |
10-02-2020, 04:21 | #15539 (permalink) |
Member: 1797183 Status: Offline Thanks Meter: 148 | Zte blade A3 lite FRP done Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly volume DOWN key 3. Insert the usb cable inside the phone while keeping pressed volume DOWN Phone detected (@oem27.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 2.0.0.114) Preparing to sync; Port opened [COM14]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Starting auth; HW IMEI : 000000-00-000000-0 Analysing data; Please WAIT ! OK; PHONE INFO: NONE PHONE ID: MDA5MDE3OTMwNDA2MDExYQ== BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 864538-04-257048-5 SW IMEI[1]: 867400-02-031662-0 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON Starting format; Formatted; Done; Remove battery and cable; Log file saved to: LOG_2_10_2020_11_18_44.txt Time needed - 00:01:49 |
The Following User Says Thank You to Clinphone For This Useful Post: |
10-02-2020, 22:36 | #15540 (permalink) |
Member: 1797183 Status: Offline Thanks Meter: 148 | Zte blade A5 2019 Imei repair ok Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly volume DOWN key 3. Insert the usb cable inside the phone while keeping pressed volume DOWN Phone detected (@oem141.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 2.0.0.114) Preparing to sync; Port opened [COM383]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Starting auth; HW IMEI : 000000-00-000000-0 Analysing data; Please WAIT ! OK; PHONE INFO: NONE PHONE ID: MDAwMjQ3MGYwMDkwMmE1Mw== BT ADDR: NONE SW IMEI[0]: 862182-04-165157-4 SW IMEI[1]: 867400-02-031662-0 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON Reading NV; NV saved to : NV_000000-00-000000-0_862182-04-165157-4_98550000_2_10_2020_13_40_16.spd Gathering security data; Security check result: 0 Connecting to server; Authorisation process started; Done; Requesting data from server ! Wait please ... Re-programming; Security programmed; Sync NV; Done; IMEI[0] repaired; Remove battery and cable; Log file saved to: LOG_2_10_2020_13_40_30.txt Time needed - 00:02:30 |
The Following 2 Users Say Thank You to Clinphone For This Useful Post: |
