Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #15676 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2016 Location: ZIMBABWE
Member: 2534995 Status: Offline Thanks Meter: 24 ![]() | Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5201 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM3)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM3 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 9926b36a382996a250b91dbd6c0491f3 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem28.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM28; DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, 05] HW_STORAGE_EMMC: 0x54000170 0x31383242 0x8E0B2036 0x9B76AB6A [SIZE=0x3A8C00000] IMEI1 [OTP 0001]: 352317-10-526246-5 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 9009G-2AVCZA5-1 USRDATA INFO: 0x80000000 SIZE: 0x324480000 Searching data; Locked to [SIM1]: 655-01 code_cat_n: 20709731 enabled: yes tries: 0 code_cat_ns: 04246752 enabled: no tries: 10 code_cat_sp: 99053974 enabled: no tries: 10 code_cat_c: 38811420 enabled: no tries: 10 code_cat_sim: 81379673 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:11 Log file saved to: LOG_28_03_2021_08_54_32.txt |
![]() | #15677 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2007
Member: 509103 Status: Offline Thanks Meter: 17 | Sonim XP5560 unlock -push button right side under display "-"(not work with *) and put cable. Searching phone; Phone detected (@oem27.inf,%vcom_bootrom%;MediaTek USB Port) Preparing to start meta mode; COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: 11.3.0-34.20-2-4025-1.00 Hw Version: NOLLEC76_11A_HW Reading phone info; IMEI: 013399-00-894758-3 Reading simlock info; Unlock codes: Locked to: 001-01 code_cat_n: 64234337 enabled: yes tries: 4 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 |
![]() | #15678 (permalink) |
![]() | #15679 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Nov 2016 Location: Plumtree, Zimbabwe
Member: 2647569 Status: Offline Thanks Meter: 38 ![]() | Itel 2132 successfully fully unlocked after write patched firmware Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly the boot key 3. Insert the usb cable inside the phone while keeping pressed the boot key Phone detected (@oem121.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 2.0.0.114) Preparing to sync; Port opened [COM7]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.2 Starting FDL2; FDL2 sent; Chip type: 6562:0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 [000070E3229C64D7:B2C1] Reading phone info; PHONE INFO: NONE BT ADDR: C8:16:49:64:39:FC SW IMEI[0]: 359249-10-446540-6 SW IMEI[1]: 359249-10-446541-4 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 103B0000 Reading NV; Reading security; NV saved to : NV_000000-00-000000-0_359249-10-446540-6_65620000_1_04_2021_15_39_17.spd IMEI: 359249-10-446540-6 UNLOCK CODE: NONE Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_1_04_2021_15_39_59.txt Time needed - 00:01:30 Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly the boot key 3. Insert the usb cable inside the phone while keeping pressed the boot key Phone detected (@oem121.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 2.0.0.114) Preparing to sync; Port opened [COM16]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.2 Starting FDL2; FDL2 sent; Chip type: 6562:0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 [000070E3229C64D7:B2C1] Reading phone info; PHONE INFO: NONE BT ADDR: C8:16:49:64:39:FC SW IMEI[0]: 359249-10-446540-6 SW IMEI[1]: 359249-10-446541-4 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: OFF FIXED NV BASE: 103B0000 Uncompressing; Done; Re-programming; FLS programmed; Done; Remove battery and cable; Log file saved to: LOG_1_04_2021_17_24_15.txt Time needed - 00:05:45 ![]() Sent from my SM-G930F using Tapatalk |
![]() | #15680 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2002 Location: i'm in a ZON place...
Member: 9709 Status: Offline Thanks Meter: 33 | ![]() 01-04-2021 15:58:24 FlyCaptain Huawei Module v1.0.0.0378 Account: 5624D088 Before operation turn phone to TestPoint mode: Turn off phone, then short TestPoint on phone pcb and plug USB cable Wait for device "HUAWEI USB COM 1.0" in Ports Repair New SIM_LOCK status : UNLOCKED Unlock downgrade/customization limitations Selected Cpu/Bootloader - Kirin710_P1_V2 2021-04-01 15:58:24.047 Connecting to server... 2021-04-01 15:58:24.390 Connected! 2021-04-01 15:58:25.887 Find device COM3, handle 10560 BOOTLOADER selected to update:Kirin710_P1_V2 downloading file Kirin710_P1_V2_0.dtwork... downloading file Kirin710_P1_V2_2.dtwork... downloading file Kirin710_P1_V2_3.dtwork... downloading file Kirin710_P1_V2_4.dtwork... downloading file Kirin710_P1_V2_6.dtwork... 2021-04-01 15:59:32.425 Waiting for device REMOVAL/INSERTION... 2021-04-01 15:59:39.105 Device ready! 2021-04-01 15:59:39.231 Unlocking bootloader... 2021-04-01 15:59:39.234 Reading Certify data... 2021-04-01 15:59:39.593 Reading Certify data success! 2021-04-01 15:59:39.597 Signing Certify data... 2021-04-01 15:59:40.418 Reading info... 2021-04-01 15:59:41.987 IMEI certificate saved to C:\Program Files (x86)\FURIOUS-GOLD\PACK7\FlyCaptainHuaweiModule_375\Backup\certi ficates\cert_864056040684497_6000.bin 2021-04-01 15:59:47.378 PINetFile.hash invalid hash! 2021-04-01 15:59:47.381 CKNetFile.hash invalid hash! 2021-04-01 15:59:47.385 Done! Fastboot provided info: CPU: kirin710 Model: MAR-LX1A Firmware: MAR-L01A 10.0.0.365(C431E13R2P7) Vendor: hw Country: eea SN: JRQ4C19503XXXXX PCB SN: 4C5NRH195XXXXX WIFI MAC: FC87436XXXX BT MAC: FC87436CXXX Theme color: black Device color: black FBLOCK: 1 Bootloader FB lock: unlocked Bootloader User lock: locked Found signed IMEI: Key: 0x6000 IMEI1: 8640560406XXXXX SIM NW_LOCK status: LOCKED Found NV data: Modems: 3 IMEI1: 8640560406XXXXX IMEI2: 000000000000000 IMEI3: 000000000000000 PESN: 00000000 MEID: 00000000000000 Found OEM data: Model: MAR-L01A Vendor: hw Country: eea Version limitation: OFF Bootloader User lock: locked Phone ID: BA3626EF0F2XXXX 2021-04-01 15:59:55.420 Repairing... 2021-04-01 15:59:55.672 Update PIHeadFile.bin success! 2021-04-01 15:59:55.883 Write partition modem_secure... 2021-04-01 15:59:56.515 Write partition modem_secure success! 2021-04-01 15:59:56.543 Unlocking restrictions... 2021-04-01 15:59:56.660 Unlock restrictions success! 2021-04-01 15:59:56.667 Done! Memo log saved to C:\Program Files (x86)\FURIOUS-GOLD\PACK7\FlyCaptainHuaweiModule_375\Logs\2021040 1_155956_FlyCaptainHuaweiModule_XloaderRepair_BA36 26EF0F2XXXX.txt |
![]() | #15681 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: pakistan Age: 36
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 490 | alcatel 8068 frp done Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5195 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM5)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM5 Connecting; Downloading DA; Initializing; Rid: 55494259eaef9cc378fb739f3509e30d Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem4.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM34; DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, 05] HW_STORAGE_EMMC: 0x54000170 0x31383242 0x84162036 0x973757D3 [SIZE=0x3A8C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 8068-2BALWEM USRDATA INFO: 0x7A000000 SIZE: 0x32CF80000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_4_04_2021_13_48_31.txt |
![]() | #15682 (permalink) |
![]() | #15683 (permalink) |
Member: 2534995 Status: Offline Thanks Meter: 24 ![]() | Alcatel one touch 9015W pop 7 lte network unlock furious gold Done unlocking thank you very much you are very good Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem81.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM90 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory size 7.3 GB, target id 8909 IMEI: 01462000000000 PTH: 03 PTS: BC6 PROV_ID: 9015W-2BTBUS1 SBTADDR: 24:0D:C2:B1:E0:54 SWIFIADDR: 24:0D:C2:C4 ![]() HS_PN: SAA1FD0AB10C SSN: 73KC06BD5OZ01JB Bruteforcing data; This operation can take up to 30 minutes !!! Done; Work id: 06BF9B80 Done; Stype: 00000001 SECURITY: XJB0UM00BR00 Size: 00000329 Backup saved to: 01462000350588-9 Backup file(s) removed; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_7_04_2021_09_36_37.txt Time needed - 00:08:47 |
The Following User Says Thank You to mapopeemma For This Useful Post: |
![]() | #15684 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2010 Location: :::LONDON:::
Member: 1442994 Status: Offline Thanks Meter: 301 | HuAWEI Y6 2019 MRD0LX1 UNLOCK DONE WITH TP Quote:
![]() | #15685 (permalink) | |
Member: 1442994 Status: Offline Thanks Meter: 301 | HuAWEI Y6 2019 MRD-LX1 UNLOCK DONE WITH TP................. Quote:
![]() | #15686 (permalink) | |
Member: 1442994 Status: Offline Thanks Meter: 301 | ALcATEL 5033X UNLOCK DONE IN FEW SECONDS... Quote:
![]() | #15687 (permalink) | |
![]() | #15688 (permalink) | |
Member: 1442994 Status: Offline Thanks Meter: 301 | HuAWEI Y6 2019 MRD-LX1 FLASH FIRMWARE DONE Quote:
![]() | #15689 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2018 Location: Future.... ✌️
Member: 2825953 Status: Offline Thanks Meter: 207 | VF1100-2AVDZA1 FRP Removed Done Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM3)) (Driver version: 3.2.0.0) Preparing to start flash mode; Preparing to open COM3 Connecting; Downloading DA; Initializing; Rid: ff5b1b3073168a9e110abeaaea9d65e6 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x30000111 0x37473830 0x78260030 0x71942B1E [SIZE=0x1D2C00000] IMEI1 [OTP 0001]: 357083-07-XXXXXXX-3 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: VF1100-2AVDZA1 USRDATA INFO: 0xD9800000 SIZE: 0xF4C80000 SPECIAL NOTE: If you are using windows 10 x64 be sure that the installed mtk driver version is 3.0.1504.0 . Any different drivers will create random read bugs on newer chipset phones. As usual the correct drivers come inside OTSMart archive inside the "usb_driver" folder Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_9_04_2021_10_30_56.txt |
![]() | #15690 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2006 Location: PORTUGAL
Member: 216446 Status: Offline Thanks Meter: 198 | Lg t385b unlock LGE M3 MODULE......PACK 3 Attach the phone without battery to the USB cable Phone detected; USB Port opened; Boot-loader Alive; Sending loaders; Done; Boot Mode: BB; Ebl_ver: 2150_Bootloader_1.2 1..2; Sending loader config; Done; Memory Info: 00AD:00BA [0x00000000] Getting flash config; Config found and applied; Reading ROOT_DISK; SAVED B9A05ED597C12602444ACC7C30C0A2B2.bin Reading STATIC_EEP; SAVED 1553A11D78F2B44729CA37EF05B00185.bin MCC-MNC: 268-01 IMEI: 353626-05-245772-3 BTAD: 06:8E:AA:F7 ![]() PID: CB45S130109004272 LOCK STATUS: ON Writing ROOT_DISK; DONE; Writing STATIC_EEP; DONE; Time needed - 00:05:32 |
