02-17-2010, 15:03 | #2881 (permalink) |
No Life Poster Join Date: Sep 2005 Location: -=HORIZON=-MobiSoft Rahwali GR Age: 38
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09 Imei: 3543540 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_17.29.35_17.02.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:03 |
02-17-2010, 15:24 | #2882 (permalink) |
No Life Poster Join Date: Aug 2005
Member: 175945 Status: Offline Sonork: ziiyyaad Thanks Meter: 704 | Shutdown phone... Starting service mode Press POWER button shortly Can't init service mode. Try to restore Bootcore.. Shutdown phone... Press POWER button shortly Can't init boot. Shutdown phone... Starting service mode Press POWER button shortly Model: CF75 v22 IMEI: 356909006203683 Exploiting.... Shutdown phone... Press POWER button shortly FlashID: 0089:880D Set port speed. ESN: 57D8905C OTPIMEI: 356909006203683 Memory size: 32Mb Read memory map. Reading EEFULL. IMEI[5009]: 356909006203683 Unlocking Writing back EEFULL Restoring Bootcore All done! |
02-17-2010, 16:09 | #2883 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 572 | Blackberry 8900 Buguyes Telecom France Searching for usb device ... Reading info ... IMEI: 35538303xxxxxxx Calculating ... MEP: MEP-08918-001 MEP2 CODE: 1064848773174855 MEP3 CODE: 1328427362200327 MEP4 CODE: 3531613062606468 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:26 |
02-17-2010, 19:07 | #2885 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 572 | Vodafone 332V unlocked ok Press power on shortly ... Starting communication ... MCU ID: 27900115A99946C1020000000000641B ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: VF527 Hash: 0000220E Algo: 05 Firmware: EVN,PI: 200808 0938 Imei: 351959027146176 Phone code: 0000 Prod. code: 254025878 Id calculation done; CODES: NET LO CODE: 4127944284 NET HI CODE: 3058396828 DIRECT UNLOCK: OK Done ! |
02-18-2010, 09:06 | #2886 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | HUAWEI t156 ayz without open done Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031835118 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_17.45.02_13.02.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:07 |
02-18-2010, 09:08 | #2887 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Neverland
Member: 1099972 Status: Offline Thanks Meter: 208 | .: Telstra f156 :. .: TELSTRA F156 UNLOCKED PANIS SA FG :. Telstra F156 na lock sa Optus sapul Procedure: Update to latest version ng PACK5 via FG maintainance SW Search Port Do Job tapos... Insert sim (Smart/Globe) Input UNlock Code SAPUL NA !!!! Screenshots: CLICK THANKS BUTTON IF YOU FIND THIS POST USEFUL!!! |
The Following 2 Users Say Thank You to fullblast For This Useful Post: |
02-18-2010, 09:46 | #2888 (permalink) |
No Life Poster Join Date: May 2008 Location: Sri Lanka , Kandy Age: 34
Member: 763865 Status: Offline Sonork: Cvlvertcharges Thanks Meter: 123 | LG GW300 Unlock Successful LG GW300 Unlock Successful Thnk Furious Attach USB cable now ... Phone detected ! USB Port opened ! RamLoader download success; Config done ! Authorising; Authorisation passed; Getting memory info; Memory: EC000000B1 Getting unlock data; Checking unlock data; Calculating; IMEI: 35573703004XXXXXX Codes: 4293584292816652 4293584292816652 3970844244961438 Enter codes using 2945#*71001# Restarting; Time needed - 00:00:27 |
02-18-2010, 11:56 | #2889 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Bangladesh Age: 34
Member: 1217931 Status: Offline Sonork: 100.1604251 Thanks Meter: 267 | KP170 unlock done....... Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Searching flash image ... Reading flash image ... Unlock finished ! Done ! Time needed - 00:00:35 .............. |
02-18-2010, 11:58 | #2890 (permalink) |
Member: 1217931 Status: Offline Sonork: 100.1604251 Thanks Meter: 267 | B2100 UNLOCK DONE Press Power On ! Starting communication ... Sending application ... Application started ... Flash ID : 0020:88C5 IMEI : 35605100978179-3 Version : B2100P40FL_V10a Lock : ON Phone successfully unlocked. Enter without a sim inside and select ' Fact. Reset'.2945#*# Time needed - 00:00:08 |
02-18-2010, 12:05 | #2891 (permalink) |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Code: Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146xxxxxxx Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_15.04.51_18.02.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:08 |
02-18-2010, 12:20 | #2892 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | KU990 Unlocking Successfully Software engine version: 1.0.0.3543 Searching phone ... MODEL : KU990 COMPILED DATE : Jan 9 2008 21:58:00 RELEASE DATE : Oct 5 2007 17:00:00 FIRMWARE INFO : KU990-MSM6280-V10a-NOV-15-2007-XX IMEI : 353 BLUETOOTH ADDR : 59 89 4F 6B 1F 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00bogg MEMORY INFO : 0800:0040:06C3 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:12 |
02-18-2010, 12:33 | #2893 (permalink) |
Banned Join Date: Mar 2004
Member: 58357 Status: Offline Thanks Meter: 27 | vodafone 527 unlock MCU ID: 04F001121D7700C2000000000000B41C Press power on shortly ... Starting communication ... MCU ID: 04000102EC6500C2000000000000C01B ROM HASH: 731C27AB2AE00189FBD4FD3013B53252 ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: VF527 Hash: 0000283C Algo: 05 Firmware: EVN,PH: 250408 0928 Imei: 351959022736310 Phone code: 0000 Prod. code: 254028126 Id calculation done; CODES: NET LO CODE: 0903953015 NET HI CODE: 1973500471 Done ! Time needed - 00:02:07 |
02-18-2010, 13:18 | #2894 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | zte a316g+ unlock done Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B10 Imei: 354354030953692 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_17.11.02_18.02.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:10 |
02-18-2010, 15:10 | #2895 (permalink) |
Temporary banned !! Join Date: Apr 2007
Member: 482214 Status: Offline Sonork: 100.1617896 Thanks Meter: 316 | lg u300 successfully flash Searching phone ... MODEL : U300 INIT FLASHING ENGINE ... OK; NV READ SKIPPED; UPLOADING STARTED; WORKING IN EMERGENCY MODE; EFS ERASING; RESETTING PHONE ! WAITING 25s PHONE TO WAKE UP; PHONE ONLINE; Deleting folder : /LGAPP/Media/Common/Battery Deleting folder : /LGAPP/Media/Common/Logo Deleting folder : /LGAPP/Media/Common/SubLCD Deleting folder : /LGAPP/Media/Common Deleting folder : /LGAPP/Media/Images/Default images Deleting folder : /LGAPP/Media/Images Deleting folder : /LGAPP/Media/MMS Deleting folder : /LGAPP/Media/Midis Deleting folder : /LGAPP/Media/Multi Deleting folder : /LGAPP/Media/Others Deleting folder : /LGAPP/Media/Pafs Deleting folder : /LGAPP/Media/Play lists Deleting folder : /LGAPP/Media/Skins Deleting folder : /LGAPP/Media/Sounds/Voice records Deleting folder : /LGAPP/Media/Sounds Deleting folder : /LGAPP/Media/ThumbImages Deleting folder : /LGAPP/Media/Videos Deleting folder : /LGAPP/Media FOLDER MISSING. ERASE OF /LGAPP/ FAILED. Deleting folder : /LGAPP/Temp Writing : /LGAPP/qtv_config.cfg Writing : /LGAPP/Internet/ses/storage/0 Writing : /LGAPP/Internet/ses/storage/1 Writing : /LGAPP/Internet/ses/storage/10 Writing : /LGAPP/Internet/ses/storage/11 Writing : /LGAPP/Internet/ses/storage/2 Writing : /LGAPP/Internet/ses/storage/3 Writing : /LGAPP/Internet/ses/storage/4 Writing : /LGAPP/Internet/ses/storage/5 Writing : /LGAPP/Internet/ses/storage/6 Writing : /LGAPP/Internet/ses/storage/7 Writing : /LGAPP/Internet/ses/storage/8 Writing : /LGAPP/Internet/ses/storage/9 Writing : /LGAPP/Internet/SIpictograms/LG300_LSK_MSN_NEW.bmp Writing : /LGAPP/Internet/SIpictograms/LGChat2.bmp Writing : /LGAPP/Media/AD/default/teaser1.png Writing : /LGAPP/Media/AD/default/teaser2.png Writing : /LGAPP/Media/AD/default/teaser3.png Writing : /LGAPP/Media/AD/default/teaser4.png Writing : /LGAPP/Media/AD/default/teaser5.png Writing : /LGAPP/Media/AD/default/teaser6.png Writing : /LGAPP/Media/AvatarImages/Accessory/Access_1.bin Writing : /LGAPP/Media/AvatarImages/Accessory/Access_2.bin Writing : /LGAPP/Media/AvatarImages/Accessory/Access_3.bin Writing : /LGAPP/Media/AvatarImages/Accessory/Access_4.bin Writing : /LGAPP/Media/AvatarImages/Accessory/Access_5.bin Writing : /LGAPP/Media/AvatarImages/Accessory/Access_6.bin Writing : /LGAPP/Media/AvatarImages/Face/Face_1.bin Writing : /LGAPP/Media/AvatarImages/Face/Face_2.bin Writing : /LGAPP/Media/AvatarImages/Face/Face_3.bin Writing : /LGAPP/Media/AvatarImages/Face/Face_4.bin Writing : /LGAPP/Media/AvatarImages/Face/Face_5.bin Writing : /LGAPP/Media/AvatarImages/Face/Face_6.bin Writing : /LGAPP/Media/AvatarImages/Hair/Hair_1.bin Writing : /LGAPP/Media/AvatarImages/Hair/Hair_2.bin Writing : /LGAPP/Media/AvatarImages/Hair/Hair_3.bin Writing : /LGAPP/Media/AvatarImages/Hair/Hair_4.bin Writing : /LGAPP/Media/AvatarImages/Hair/Hair_5.bin Writing : /LGAPP/Media/AvatarImages/Hair/Hair_6.bin Writing : /LGAPP/Media/AvatarImages/Hair/Hair_7.bin Writing : /LGAPP/Media/AvatarImages/Hair/Hair_8.bin Writing : /LGAPP/Media/AvatarImages/Hair/Hair_9.bin Writing : /LGAPP/Media/AvatarImages/Pants/Pant_1.bin Writing : /LGAPP/Media/AvatarImages/Pants/Pant_10.bin Writing : /LGAPP/Media/AvatarImages/Pants/Pant_2.bin Writing : /LGAPP/Media/AvatarImages/Pants/Pant_3.bin Writing : /LGAPP/Media/AvatarImages/Pants/Pant_4.bin Writing : /LGAPP/Media/AvatarImages/Pants/Pant_5.bin Writing : /LGAPP/Media/AvatarImages/Pants/Pant_6.bin Writing : /LGAPP/Media/AvatarImages/Pants/Pant_7.bin Writing : /LGAPP/Media/AvatarImages/Pants/Pant_8.bin Writing : /LGAPP/Media/AvatarImages/Pants/Pant_9.bin Writing : /LGAPP/Media/AvatarImages/Scene/bg_1.bin Writing : /LGAPP/Media/AvatarImages/Scene/bg_2.bin Writing : /LGAPP/Media/AvatarImages/Scene/bg_3.bin Writing : /LGAPP/Media/AvatarImages/Scene/bg_4.bin Writing : /LGAPP/Media/AvatarImages/Scene/bg_5.bin Writing : /LGAPP/Media/AvatarImages/Scene/bg_6.bin Writing : /LGAPP/Media/AvatarImages/Scene/bg_7.bin Writing : /LGAPP/Media/AvatarImages/Scene/bg_8.bin Writing : /LGAPP/Media/AvatarImages/Shirts/Shirt_1.bin Writing : /LGAPP/Media/AvatarImages/Shirts/Shirt_10.bin Writing : /LGAPP/Media/AvatarImages/Shirts/Shirt_11.bin Writing : /LGAPP/Media/AvatarImages/Shirts/Shirt_12.bin Writing : /LGAPP/Media/AvatarImages/Shirts/Shirt_2.bin Writing : /LGAPP/Media/AvatarImages/Shirts/Shirt_3.bin Writing : /LGAPP/Media/AvatarImages/Shirts/Shirt_4.bin Writing : /LGAPP/Media/AvatarImages/Shirts/Shirt_5.bin Writing : /LGAPP/Media/AvatarImages/Shirts/Shirt_6.bin Writing : /LGAPP/Media/AvatarImages/Shirts/Shirt_7.bin Writing : /LGAPP/Media/AvatarImages/Shirts/Shirt_8.bin Writing : /LGAPP/Media/AvatarImages/Shirts/Shirt_9.bin Writing : /LGAPP/Media/AvatarImagesMini/Accessory/Mini_Access_1.bin Writing : /LGAPP/Media/AvatarImagesMini/Accessory/Mini_Access_2.bin Writing : /LGAPP/Media/AvatarImagesMini/Accessory/Mini_Access_3.bin Writing : /LGAPP/Media/AvatarImagesMini/Accessory/Mini_Access_4.bin Writing : /LGAPP/Media/AvatarImagesMini/Accessory/Mini_Access_5.bin Writing : /LGAPP/Media/AvatarImagesMini/Accessory/Mini_Access_6.bin Writing : /LGAPP/Media/AvatarImagesMini/Face/Mini_Face_1.bin Writing : /LGAPP/Media/AvatarImagesMini/Face/Mini_Face_2.bin Writing : /LGAPP/Media/AvatarImagesMini/Face/Mini_Face_3.bin Writing : /LGAPP/Media/AvatarImagesMini/Face/Mini_Face_4.bin Writing : /LGAPP/Media/AvatarImagesMini/Face/Mini_Face_5.bin Writing : /LGAPP/Media/AvatarImagesMini/Face/Mini_Face_6.bin Writing : /LGAPP/Media/AvatarImagesMini/Hair/Mini_Hair_1.bin Writing : /LGAPP/Media/AvatarImagesMini/Hair/Mini_Hair_2.bin Writing : /LGAPP/Media/AvatarImagesMini/Hair/Mini_Hair_3.bin Writing : /LGAPP/Media/AvatarImagesMini/Hair/Mini_Hair_4.bin Writing : /LGAPP/Media/AvatarImagesMini/Hair/Mini_Hair_5.bin Writing : /LGAPP/Media/AvatarImagesMini/Hair/Mini_Hair_6.bin Writing : /LGAPP/Media/AvatarImagesMini/Hair/Mini_Hair_7.bin Writing : /LGAPP/Media/AvatarImagesMini/Hair/Mini_Hair_8.bin Writing : /LGAPP/Media/AvatarImagesMini/Hair/Mini_Hair_9.bin Writing : /LGAPP/Media/AvatarImagesMini/Pants/Mini_Pant_1.bin Writing : /LGAPP/Media/AvatarImagesMini/Pants/Mini_Pant_10.bin Writing : /LGAPP/Media/AvatarImagesMini/Pants/Mini_Pant_2.bin Writing : /LGAPP/Media/AvatarImagesMini/Pants/Mini_Pant_3.bin Writing : /LGAPP/Media/AvatarImagesMini/Pants/Mini_Pant_4.bin Writing : /LGAPP/Media/AvatarImagesMini/Pants/Mini_Pant_5.bin Writing : /LGAPP/Media/AvatarImagesMini/Pants/Mini_Pant_6.bin Writing : /LGAPP/Media/AvatarImagesMini/Pants/Mini_Pant_7.bin Writing : /LGAPP/Media/AvatarImagesMini/Pants/Mini_Pant_8.bin Writing : /LGAPP/Media/AvatarImagesMini/Pants/Mini_Pant_9.bin Writing : /LGAPP/Media/AvatarImagesMini/Scene/Mini_bg_1.bin Writing : /LGAPP/Media/AvatarImagesMini/Scene/Mini_bg_2.bin Writing : /LGAPP/Media/AvatarImagesMini/Scene/Mini_bg_3.bin Writing : /LGAPP/Media/AvatarImagesMini/Scene/Mini_bg_4.bin Writing : /LGAPP/Media/AvatarImagesMini/Scene/Mini_bg_5.bin Writing : /LGAPP/Media/AvatarImagesMini/Scene/Mini_bg_6.bin Writing : /LGAPP/Media/AvatarImagesMini/Scene/Mini_bg_7.bin Writing : /LGAPP/Media/AvatarImagesMini/Scene/Mini_bg_8.bin Writing : /LGAPP/Media/AvatarImagesMini/Shirts/Mini_Shirt_1.bin Writing : /LGAPP/Media/AvatarImagesMini/Shirts/Mini_Shirt_10.bin Writing : /LGAPP/Media/AvatarImagesMini/Shirts/Mini_Shirt_11.bin Writing : /LGAPP/Media/AvatarImagesMini/Shirts/Mini_Shirt_12.bin Writing : /LGAPP/Media/AvatarImagesMini/Shirts/Mini_Shirt_2.bin Writing : /LGAPP/Media/AvatarImagesMini/Shirts/Mini_Shirt_3.bin Writing : /LGAPP/Media/AvatarImagesMini/Shirts/Mini_Shirt_4.bin Writing : /LGAPP/Media/AvatarImagesMini/Shirts/Mini_Shirt_5.bin Writing : /LGAPP/Media/AvatarImagesMini/Shirts/Mini_Shirt_6.bin Writing : /LGAPP/Media/AvatarImagesMini/Shirts/Mini_Shirt_7.bin Writing : /LGAPP/Media/AvatarImagesMini/Shirts/Mini_Shirt_8.bin Writing : /LGAPP/Media/AvatarImagesMini/Shirts/Mini_Shirt_9.bin Writing : /LGAPP/Media/Common/Battery_charging_anim.gif Writing : /LGAPP/Media/Common/CalculatorBG.bin Writing : /LGAPP/Media/Common/sub_in_calling.gif Writing : /LGAPP/Media/Common/sub_out_calling.gif Writing : /LGAPP/Media/Common/te_connected.gif Writing : /LGAPP/Media/Common/WorldClockBG.bin Writing : /LGAPP/Media/Common/new_in_calling.gif Writing : /LGAPP/Media/Common/new_out_calling.gif Writing : /LGAPP/Media/Common/Battery/battery.bin Writing : /LGAPP/Media/Common/Battery/battery_0.bin Writing : /LGAPP/Media/Common/Battery/main_charging_full.bin Writing : /LGAPP/Media/Common/Internet/InternetInfo.bin Writing : /LGAPP/Media/Common/Logo/ML_HutchLogo.bin Writing : /LGAPP/Media/Common/Logo/SL_HutchLogo.bin Writing : /LGAPP/Media/Common/Logo/SL_HutchLogo_PwrOn.bin Writing : /LGAPP/Media/Common/SubLCD/battery_sub.bin Writing : /LGAPP/Media/Common/SubLCD/battery_sub_0.bin Writing : /LGAPP/Media/Common/SubLCD/sub_charging_full.bin Writing : /LGAPP/Media/DRM/license.db Writing : /LGAPP/Media/EMS/Animations/Data/EPA_00.paf Writing : /LGAPP/Media/EMS/Animations/Data/EPA_01.paf Writing : /LGAPP/Media/EMS/Animations/Data/EPA_02.paf Writing : /LGAPP/Media/EMS/Animations/Data/EPA_03.paf Writing : /LGAPP/Media/EMS/Animations/Data/EPA_04.paf Writing : /LGAPP/Media/EMS/Animations/Data/EPA_05.paf Writing : /LGAPP/Media/EMS/Animations/Data/EPA_06.paf Writing : /LGAPP/Media/EMS/Animations/Data/EPA_07.paf Writing : /LGAPP/Media/EMS/Animations/Data/EPA_08.paf Writing : /LGAPP/Media/EMS/Animations/Data/EPA_09.paf Writing : /LGAPP/Media/EMS/Animations/Data/EPA_10.paf Writing : /LGAPP/Media/EMS/Animations/Data/EPA_11.paf Writing : /LGAPP/Media/EMS/Animations/Data/EPA_12.paf Writing : /LGAPP/Media/EMS/Animations/Data/EPA_13.paf Writing : /LGAPP/Media/EMS/Animations/Data/EPA_14.paf Writing : /LGAPP/Media/EMS/PredefSound/EPS_00.mmf Writing : /LGAPP/Media/EMS/PredefSound/EPS_01.mmf Writing : /LGAPP/Media/EMS/PredefSound/EPS_02.mmf Writing : /LGAPP/Media/EMS/PredefSound/EPS_03.mmf Writing : /LGAPP/Media/EMS/PredefSound/EPS_04.mmf Writing : /LGAPP/Media/EMS/PredefSound/EPS_05.mmf Writing : /LGAPP/Media/EMS/PredefSound/EPS_06.mmf Writing : /LGAPP/Media/EMS/PredefSound/EPS_07.mmf Writing : /LGAPP/Media/EMS/PredefSound/EPS_08.mmf Writing : /LGAPP/Media/EMS/PredefSound/EPS_09.mmf Writing : /LGAPP/Media/Flex/Flex.ini Writing : /LGAPP/Media/Frames/frame_01.bmp Writing : /LGAPP/Media/Frames/frame_02.bmp Writing : /LGAPP/Media/Frames/frame_03.bmp Writing : /LGAPP/Media/Frames/frame_04.bmp Writing : /LGAPP/Media/Frames/frame_05.bmp Writing : /LGAPP/Media/Frames/frame_06.bmp Writing : /LGAPP/Media/IM/History/IM_History_Sample.txt Writing : /LGAPP/Media/Images/brasile.jpg Writing : /LGAPP/Media/Images/green.jpg Writing : /LGAPP/Media/Images/sea.jpg Writing : /LGAPP/Media/Images/Default images/disco_ad1.bmp Writing : /LGAPP/Media/Images/Default images/Hutch_Off.gif Writing : /LGAPP/Media/Images/Default images/Hutch_On.gif Writing : /LGAPP/Media/Images/Default images/Idle.gif Writing : /LGAPP/Media/Images/Default images/IdleAD.gif Writing : /LGAPP/Media/Images/Default images/in_calling.gif Writing : /LGAPP/Media/Images/Default images/out_calling.gif Writing : /LGAPP/Media/Images/Default images/Sending_message.gif Writing : /LGAPP/Media/Images/Default images/Shutdown.gif Writing : /LGAPP/Media/Images/Default images/Startup.gif Writing : /LGAPP/Media/Images/Default images/ThemeIdle.jpg Writing : /LGAPP/Media/Images/Default images/VT_blocked_XL.jpg Writing : /LGAPP/Media/Images/Default images/VT_CaptureNoti_XL.jpg Writing : /LGAPP/Media/Internet/SIpictograms/118333.bmp Writing : /LGAPP/Media/Internet/SIpictograms/880_RSK_3player.bmp Writing : /LGAPP/Media/Internet/SIpictograms/about3.bmp Writing : /LGAPP/Media/Internet/SIpictograms/alerts.bmp Writing : /LGAPP/Media/Internet/SIpictograms/atob.bmp Writing : /LGAPP/Media/Internet/SIpictograms/comedy.bmp Writing : /LGAPP/Media/Internet/SIpictograms/ecards.bmp Writing : /LGAPP/Media/Internet/SIpictograms/email.bmp Writing : /LGAPP/Media/Internet/SIpictograms/extras.bmp Writing : /LGAPP/Media/Internet/SIpictograms/finance.bmp Writing : /LGAPP/Media/Internet/SIpictograms/find.bmp Writing : /LGAPP/Media/Internet/SIpictograms/********.bmp Writing : /LGAPP/Media/Internet/SIpictograms/games.bmp Writing : /LGAPP/Media/Internet/SIpictograms/goingout.bmp Writing : /LGAPP/Media/Internet/SIpictograms/horoscopes.bmp Writing : /LGAPP/Media/Internet/SIpictograms/LGRSKPlanet3_minimised.bmp Writing : /LGAPP/Media/Internet/SIpictograms/movies.bmp Writing : /LGAPP/Media/Internet/SIpictograms/music.bmp Writing : /LGAPP/Media/Internet/SIpictograms/my3.bmp Writing : /LGAPP/Media/Internet/SIpictograms/news.bmp Writing : /LGAPP/Media/Internet/SIpictograms/Planet3.bmp Writing : /LGAPP/Media/Internet/SIpictograms/quickmap.bmp Writing : /LGAPP/Media/Internet/SIpictograms/showbiz.bmp Writing : /LGAPP/Media/Internet/SIpictograms/sport.bmp Writing : /LGAPP/Media/Internet/SIpictograms/sports.bmp Writing : /LGAPP/Media/Internet/SIpictograms/topshelf.bmp Writing : /LGAPP/Media/Internet/SIpictograms/travel.bmp Writing : /LGAPP/Media/Internet/SIpictograms/TV.bmp Writing : /LGAPP/Media/Internet/SIpictograms/weather.bmp Writing : /LGAPP/Media/Internet/SIpictograms/LGChat2.bmp Writing : /LGAPP/Media/Internet/SIpictograms/LG300_LSK_MSN_NEW.bmp Writing : /LGAPP/Media/Java/ams/00.jar Writing : /LGAPP/Media/Java/ams/00.png Writing : /LGAPP/Media/Java/ams/00_1.png Writing : /LGAPP/Media/Java/ams/01.jar Writing : /LGAPP/Media/Java/ams/01.png Writing : /LGAPP/Media/Java/ams/01_1.png Writing : /LGAPP/Media/Java/ams/02.url Writing : /LGAPP/Media/Java/ams/pushlist Writing : /LGAPP/Media/Java/ams/03.url Writing : /LGAPP/Media/Java/ams/00.jad Writing : /LGAPP/Media/Java/ams/00.sec Writing : /LGAPP/Media/Java/ams/01.jad Writing : /LGAPP/Media/Java/ams/01.sec Writing : /LGAPP/Media/Java/ams/02.sec Writing : /LGAPP/Media/Java/ams/03.jad Writing : /LGAPP/Media/Java/ams/03.jar Writing : /LGAPP/Media/Java/ams/03.mnf Writing : /LGAPP/Media/Java/ams/03.sec Writing : /LGAPP/Media/Java/ams/00.mnf Writing : /LGAPP/Media/Java/ams/00.url Writing : /LGAPP/Media/Java/ams/01.mnf Writing : /LGAPP/Media/Java/ams/01.url Writing : /LGAPP/Media/Java/ams/02.jad Writing : /LGAPP/Media/Java/ams/02.jar Writing : /LGAPP/Media/Java/ams/02.mnf Writing : /LGAPP/Media/Java/ams/contentInfo Writing : /LGAPP/Media/Java/ams/00/defualt.txt Writing : /LGAPP/Media/Java/ams/01/defualt.txt Writing : /LGAPP/Media/Java/ams/02/defualt.txt Writing : /LGAPP/Media/Java/ams/03/defualt.txt Writing : /LGAPP/Media/Java/backup/00.jar Writing : /LGAPP/Media/Java/backup/00.png Writing : /LGAPP/Media/Java/backup/00_1.png Writing : /LGAPP/Media/Java/backup/01.jar Writing : /LGAPP/Media/Java/backup/01.png Writing : /LGAPP/Media/Java/backup/01_1.png Writing : /LGAPP/Media/Java/backup/02.url Writing : /LGAPP/Media/Java/backup/pushlist Writing : /LGAPP/Media/Java/backup/suite Writing : /LGAPP/Media/Java/backup/03.url Writing : /LGAPP/Media/Java/backup/00.jad Writing : /LGAPP/Media/Java/backup/00.sec Writing : /LGAPP/Media/Java/backup/01.jad Writing : /LGAPP/Media/Java/backup/01.sec Writing : /LGAPP/Media/Java/backup/02.sec Writing : /LGAPP/Media/Java/backup/03.jad Writing : /LGAPP/Media/Java/backup/03.jar Writing : /LGAPP/Media/Java/backup/03.mnf Writing : /LGAPP/Media/Java/backup/03.sec Writing : /LGAPP/Media/Java/backup/00.mnf Writing : /LGAPP/Media/Java/backup/00.url Writing : /LGAPP/Media/Java/backup/01.mnf Writing : /LGAPP/Media/Java/backup/01.url Writing : /LGAPP/Media/Java/backup/02.jad Writing : /LGAPP/Media/Java/backup/02.jar Writing : /LGAPP/Media/Java/backup/02.mnf Writing : /LGAPP/Media/Java/backup/contentInfo Writing : /LGAPP/Media/Java/sys/splash.jpg Writing : /LGAPP/Media/Java/sys/preloadInfo Writing : /LGAPP/Media/Java/ui/Jumbo Rumble RB.01/suite Writing : /LGAPP/Media/Java/ui/ZUMA RB.00/suite Writing : /LGAPP/Media/Java/ui/3 Player.02/suite Writing : /LGAPP/Media/Java/ui/MSN Messenger.03/suite Writing : /LGAPP/Media/Java/cert/0 Writing : /LGAPP/Media/Java/cert/1 Writing : /LGAPP/Media/Java/cert/2 Writing : /LGAPP/Media/Java/cert/3 Writing : /LGAPP/Media/Java/cert/4 Writing : /LGAPP/Media/Java/cert/5 Writing : /LGAPP/Media/Java/cert/6 Writing : /LGAPP/Media/Java/cert/7 Writing : /LGAPP/Media/Java/cert/8 Writing : /LGAPP/Media/Java/cert/h3g.pol Writing : /LGAPP/Media/Java/cert/orange.pol Writing : /LGAPP/Media/Java/cert/tme.pol Writing : /LGAPP/Media/MMS/Attach/Attach_Folder.txt Writing : /LGAPP/Media/MultiTasking/subnoti_bg.paf Writing : /LGAPP/Media/MultiTasking/thpw_arrow_left.paf Writing : /LGAPP/Media/MultiTasking/thpw_arrow_right.paf Writing : /LGAPP/Media/MultiTasking/thpw_icon0.paf Writing : /LGAPP/Media/MultiTasking/thpw_icon1.paf Writing : /LGAPP/Media/MultiTasking/thpw_icon10.paf Writing : /LGAPP/Media/MultiTasking/thpw_icon11.paf Writing : /LGAPP/Media/MultiTasking/thpw_icon12.paf Writing : /LGAPP/Media/MultiTasking/thpw_icon13.paf Writing : /LGAPP/Media/MultiTasking/thpw_icon2.paf Writing : /LGAPP/Media/MultiTasking/thpw_icon3.paf Writing : /LGAPP/Media/MultiTasking/thpw_icon4.paf Writing : /LGAPP/Media/MultiTasking/thpw_icon5.paf Writing : /LGAPP/Media/MultiTasking/thpw_icon6.paf Writing : /LGAPP/Media/MultiTasking/thpw_icon7.paf Writing : /LGAPP/Media/MultiTasking/thpw_icon8.paf Writing : /LGAPP/Media/MultiTasking/thpw_icon9.paf Writing : /LGAPP/Media/MultiTasking/thpw_mainbg.paf Writing : /LGAPP/Media/Pafs/sub_vt_in_calling.paf Writing : /LGAPP/Media/Pafs/alarm.paf Writing : /LGAPP/Media/Pafs/MessagesPre_OneX.paf Writing : /LGAPP/Media/Pafs/vol1_sel.paf Writing : /LGAPP/Media/Pafs/ApplicationsNext_OneX.paf Writing : /LGAPP/Media/Pafs/SettingsNext_OneX.paf Writing : /LGAPP/Media/Pafs/vol2.paf Writing : /LGAPP/Media/Pafs/ApplicationsNo_OneX.paf Writing : /LGAPP/Media/Pafs/vol2_sel.paf Writing : /LGAPP/Media/Pafs/ApplicationsPre_OneX.paf Writing : /LGAPP/Media/Pafs/vol3.paf Writing : /LGAPP/Media/Pafs/vol3_sel.paf Writing : /LGAPP/Media/Pafs/vol4.paf Writing : /LGAPP/Media/Pafs/vol5.paf Writing : /LGAPP/Media/Pafs/BTSearch.paf Writing : /LGAPP/Media/Pafs/vol5_sel.paf Writing : /LGAPP/Media/Pafs/vol6.paf Writing : /LGAPP/Media/Pafs/check.paf Writing : /LGAPP/Media/Pafs/vol6_sel.paf Writing : /LGAPP/Media/Pafs/SyncAni.paf Writing : /LGAPP/Media/Pafs/vol7.paf Writing : /LGAPP/Media/Pafs/Crss_req.paf Writing : /LGAPP/Media/Pafs/datacall.paf Writing : /LGAPP/Media/Pafs/deleting.paf Writing : /LGAPP/Media/Pafs/vol7_sel.paf Writing : /LGAPP/Media/Pafs/vol_nor.paf Writing : /LGAPP/Media/Pafs/vol_sel.paf Writing : /LGAPP/Media/Pafs/Tick.paf Writing : /LGAPP/Media/Pafs/warning.paf Writing : /LGAPP/Media/Pafs/sub_scheduler.paf Writing : /LGAPP/Media/Pafs/SubInsert_SIM.paf Writing : /LGAPP/Media/Pafs/SyncAni_sub.paf Writing : /LGAPP/Media/Pafs/Applications_Grid.paf Writing : /LGAPP/Media/Pafs/Applications_OneX.paf Writing : /LGAPP/Media/Pafs/arrow_black_L.paf Writing : /LGAPP/Media/Pafs/arrow_black_R.paf Writing : /LGAPP/Media/Pafs/te_connecting.paf Writing : /LGAPP/Media/Pafs/Browser_Grid.paf Writing : /LGAPP/Media/Pafs/Browser_OneX.paf Writing : /LGAPP/Media/Pafs/Tools_Grid.paf Writing : /LGAPP/Media/Pafs/BrowserNo_OneX.paf Writing : /LGAPP/Media/Pafs/BrowserNext_OneX.paf Writing : /LGAPP/Media/Pafs/BrowserPre_OneX.paf Writing : /LGAPP/Media/Pafs/Calling_Grid.paf Writing : /LGAPP/Media/Pafs/Calling_OneX.paf Writing : /LGAPP/Media/Pafs/CallingNo_OneX.paf Writing : /LGAPP/Media/Pafs/Tools_OneX.paf Writing : /LGAPP/Media/Pafs/CallingNext_OneX.paf Writing : /LGAPP/Media/Pafs/CallingPre_OneX.paf Writing : /LGAPP/Media/Pafs/Contacts_Grid.paf Writing : /LGAPP/Media/Pafs/Contacts_OneX.paf Writing : /LGAPP/Media/Pafs/ContactsNext_OneX.paf Writing : /LGAPP/Media/Pafs/ContactsNo_OneX.paf Writing : /LGAPP/Media/Pafs/ContactsPre_OneX.paf Writing : /LGAPP/Media/Pafs/Display_Grid.paf Writing : /LGAPP/Media/Pafs/Display_OneX.paf Writing : /LGAPP/Media/Pafs/DisplayNo_OneX.paf Writing : /LGAPP/Media/Pafs/DisplayNext_OneX.paf Writing : /LGAPP/Media/Pafs/ToolsNext_OneX.paf Writing : /LGAPP/Media/Pafs/ToolsNo_OneX.paf Writing : /LGAPP/Media/Pafs/DisplayPre_OneX.paf Writing : /LGAPP/Media/Pafs/ToolsPre_OneX.paf Writing : /LGAPP/Media/Pafs/DmSyncAni.paf Writing : /LGAPP/Media/Pafs/Downloading.paf Writing : /LGAPP/Media/Pafs/TopmenuBg_Grid.paf Writing : /LGAPP/Media/Pafs/DownloadingU880.paf Writing : /LGAPP/Media/Pafs/TopmenuBg_OneX.paf Writing : /LGAPP/Media/Pafs/HourGlass.paf Writing : /LGAPP/Media/Pafs/IM_Login_ani.paf Writing : /LGAPP/Media/Pafs/in_calling.paf Writing : /LGAPP/Media/Pafs/TopmenuTitle_Grid.paf Writing : /LGAPP/Media/Pafs/info.paf Writing : /LGAPP/Media/Pafs/info_icon.paf Writing : /LGAPP/Media/Pafs/infopop*****.paf Writing : /LGAPP/Media/Pafs/infopop*****_2.paf Writing : /LGAPP/Media/Pafs/Insert_SIM.paf Writing : /LGAPP/Media/Pafs/internet.paf Writing : /LGAPP/Media/Pafs/irda.paf Writing : /LGAPP/Media/Pafs/load1.paf Writing : /LGAPP/Media/Pafs/load2.paf Writing : /LGAPP/Media/Pafs/load3.paf Writing : /LGAPP/Media/Pafs/load4.paf Writing : /LGAPP/Media/Pafs/load5.paf Writing : /LGAPP/Media/Pafs/load6.paf Writing : /LGAPP/Media/Pafs/loading.paf Writing : /LGAPP/Media/Pafs/loading2.paf Writing : /LGAPP/Media/Pafs/LoadingPage.paf Writing : /LGAPP/Media/Pafs/main_charging.paf Writing : /LGAPP/Media/Pafs/main_charging_1.paf Writing : /LGAPP/Media/Pafs/main_charging_2.paf Writing : /LGAPP/Media/Pafs/main_charging_3.paf Writing : /LGAPP/Media/Pafs/main_charging_4.paf Writing : /LGAPP/Media/Pafs/Messages_Grid.paf Writing : /LGAPP/Media/Pafs/Messages_OneX.paf Writing : /LGAPP/Media/Pafs/MessagesNext_OneX.paf Writing : /LGAPP/Media/Pafs/MessagesNo_OneX.paf Writing : /LGAPP/Media/Pafs/missedcall.paf Writing : /LGAPP/Media/Pafs/mmp_aod.paf Writing : /LGAPP/Media/Pafs/mmp_blue_live.paf Writing : /LGAPP/Media/Pafs/mmp_default_live.paf Writing : /LGAPP/Media/Pafs/mmp_main_visualizer.paf Writing : /LGAPP/Media/Pafs/mmp_music.paf Writing : /LGAPP/Media/Pafs/mmp_night.paf Writing : /LGAPP/Media/Pafs/Msg_Network.paf Writing : /LGAPP/Media/Pafs/Multimedia_Grid.paf Writing : /LGAPP/Media/Pafs/Multimedia_OneX.paf Writing : /LGAPP/Media/Pafs/MultimediaNext_OneX.paf Writing : /LGAPP/Media/Pafs/MultimediaNo_OneX.paf Writing : /LGAPP/Media/Pafs/MultimediaPre_OneX.paf Writing : /LGAPP/Media/Pafs/Mystuff_Grid.paf Writing : /LGAPP/Media/Pafs/Mystuff_OneX.paf Writing : /LGAPP/Media/Pafs/MystuffNext_OneX.paf Writing : /LGAPP/Media/Pafs/MystuffNo_OneX.paf Writing : /LGAPP/Media/Pafs/MystuffPre_OneX.paf Writing : /LGAPP/Media/Pafs/net_search.paf Writing : /LGAPP/Media/Pafs/network_setup.paf Writing : /LGAPP/Media/Pafs/Organiser_Grid.paf Writing : /LGAPP/Media/Pafs/Organiser_OneX.paf Writing : /LGAPP/Media/Pafs/OrganiserNext_OneX.paf Writing : /LGAPP/Media/Pafs/OrganiserNo_OneX.paf Writing : /LGAPP/Media/Pafs/OrganiserPre_OneX.paf Writing : /LGAPP/Media/Pafs/out_calling.paf Writing : /LGAPP/Media/Pafs/popup_calendar.paf Writing : /LGAPP/Media/Pafs/Profiles_Grid.paf Writing : /LGAPP/Media/Pafs/Profiles_OneX.paf Writing : /LGAPP/Media/Pafs/ProfilesNext_OneX.paf Writing : /LGAPP/Media/Pafs/ProfilesNo_OneX.paf Writing : /LGAPP/Media/Pafs/ProfilesPre_OneX.paf Writing : /LGAPP/Media/Pafs/progress.paf Writing : /LGAPP/Media/Pafs/question.paf Writing : /LGAPP/Media/Pafs/schedule_alarm.paf Writing : /LGAPP/Media/Pafs/schemodeforsub.paf Writing : /LGAPP/Media/Pafs/searching.paf Writing : /LGAPP/Media/Pafs/Sending_ani.paf Writing : /LGAPP/Media/Pafs/Settings_Grid.paf Writing : /LGAPP/Media/Pafs/Settings_OneX.paf Writing : /LGAPP/Media/Pafs/SettingsNo_OneX.paf Writing : /LGAPP/Media/Pafs/SettingsPre_OneX.paf Writing : /LGAPP/Media/Pafs/SIM_lock.paf Writing : /LGAPP/Media/Pafs/smile.paf Writing : /LGAPP/Media/Pafs/SmsSending.paf Writing : /LGAPP/Media/Pafs/streaming_buffer.paf Writing : /LGAPP/Media/Pafs/sub_alarm.paf Writing : /LGAPP/Media/Pafs/sub_alarm_snooze_mono.paf Writing : /LGAPP/Media/Pafs/sub_calling.paf Writing : /LGAPP/Media/Pafs/sub_calling_vt.paf Writing : /LGAPP/Media/Pafs/sub_callreject.paf Writing : /LGAPP/Media/Pafs/sub_charging.paf Writing : /LGAPP/Media/Pafs/sub_charging_1.paf Writing : /LGAPP/Media/Pafs/sub_charging_2.paf Writing : /LGAPP/Media/Pafs/sub_charging_3.paf Writing : /LGAPP/Media/Pafs/sub_charging_4.paf Writing : /LGAPP/Media/Pafs/sub_in_calling.paf Writing : /LGAPP/Media/Pafs/sub_missedcall.paf Writing : /LGAPP/Media/Pafs/sub_sms.paf Writing : /LGAPP/Media/Pafs/vol1.paf Writing : /LGAPP/Media/picto/core/action/back.gif Writing : /LGAPP/Media/picto/core/action/clear.gif Writing : /LGAPP/Media/picto/core/action/find.gif Writing : /LGAPP/Media/picto/core/action/makePhoneCall.gif Writing : /LGAPP/Media/picto/core/action/next.gif Writing : /LGAPP/Media/picto/core/action/nextItem.gif Writing : /LGAPP/Media/picto/core/action/password.gif Writing : /LGAPP/Media/picto/core/action/stop.gif Writing : /LGAPP/Media/picto/core/action/top.gif Writing : /LGAPP/Media/picto/core/action/userAuthentication.gif Writing : /LGAPP/Media/picto/core/arrow/down.gif Writing : /LGAPP/Media/picto/core/arrow/fingerDown.gif Writing : /LGAPP/Media/picto/core/arrow/fingerLeft.gif Writing : /LGAPP/Media/picto/core/arrow/fingerRight.gif Writing : /LGAPP/Media/picto/core/arrow/fingerUp.gif Writing : /LGAPP/Media/picto/core/arrow/left.gif Writing : /LGAPP/Media/picto/core/arrow/lowerLeft.gif Writing : /LGAPP/Media/picto/core/arrow/lowerRight.gif Writing : /LGAPP/Media/picto/core/arrow/right.gif Writing : /LGAPP/Media/picto/core/arrow/Thumbs.db Writing : /LGAPP/Media/picto/core/arrow/up.gif Writing : /LGAPP/Media/picto/core/arrow/upperLeft.gif Writing : /LGAPP/Media/picto/core/arrow/upperRight.gif Writing : /LGAPP/Media/picto/core/button/0.gif Writing : /LGAPP/Media/picto/core/button/1.gif Writing : /LGAPP/Media/picto/core/button/2.gif Writing : /LGAPP/Media/picto/core/button/3.gif Writing : /LGAPP/Media/picto/core/button/4.gif Writing : /LGAPP/Media/picto/core/button/5.gif Writing : /LGAPP/Media/picto/core/button/6.gif Writing : /LGAPP/Media/picto/core/button/7.gif Writing : /LGAPP/Media/picto/core/button/8.gif Writing : /LGAPP/Media/picto/core/button/9.gif Writing : /LGAPP/Media/picto/core/info/charged.gif Writing : /LGAPP/Media/picto/core/info/freeofcharge.gif Writing : /LGAPP/Media/picto/core/info/new.gif Writing : /LGAPP/Media/picto/core/info/notice.gif Writing : /LGAPP/Media/picto/core/info/position.gif Writing : /LGAPP/Media/picto/core/info/reserved.gif Writing : /LGAPP/Media/picto/core/info/sharpdial.gif Writing : /LGAPP/Media/picto/core/info/speedinfo.gif Writing : /LGAPP/Media/picto/core/info/tollfree.gif Writing : /LGAPP/Media/picto/core/media/book.gif Writing : /LGAPP/Media/picto/core/media/cd.gif Writing : /LGAPP/Media/picto/core/media/dvd.gif Writing : /LGAPP/Media/picto/core/media/game.gif Writing : /LGAPP/Media/picto/core/media/radio.gif Writing : /LGAPP/Media/picto/core/media/tv.gif Writing : /LGAPP/Media/picto/core/media/video.gif Writing : /LGAPP/Media/picto/core/message/attachment.gif Writing : /LGAPP/Media/picto/core/message/document.gif Writing : /LGAPP/Media/picto/core/message/folder.gif Writing : /LGAPP/Media/picto/core/message/inbox.gif Writing : /LGAPP/Media/picto/core/message/message.gif Writing : /LGAPP/Media/picto/core/message/outbox.gif Writing : /LGAPP/Media/picto/core/message/receive.gif Writing : /LGAPP/Media/picto/core/message/send.gif Writing : /LGAPP/Media/picto/core/state/beginner.gif Writing : /LGAPP/Media/picto/core/state/copyright.gif Writing : /LGAPP/Media/picto/core/state/insecure.gif Writing : /LGAPP/Media/picto/core/state/secure.gif Writing : /LGAPP/Media/picto/core/state/trademark.gif Writing : /LGAPP/Media/picto/core/state/underConstruction.gif Writing : /LGAPP/Media/Sounds/Bluesmobile.mp3 Writing : /LGAPP/Media/Sounds/Default sounds/01 Clock Bell.aac Writing : /LGAPP/Media/Sounds/Default sounds/01 Flip Close.mid Writing : /LGAPP/Media/Sounds/Default sounds/01 Flip Open.mid Writing : /LGAPP/Media/Sounds/Default sounds/02 Clock Bell.aac Writing : /LGAPP/Media/Sounds/Default sounds/02 Flip Close.mid Writing : /LGAPP/Media/Sounds/Default sounds/02 Flip Open.mid Writing : /LGAPP/Media/Sounds/Default sounds/Alarm Clock.mid Writing : /LGAPP/Media/Sounds/Default sounds/Beep_Once.mid Writing : /LGAPP/Media/Sounds/Default sounds/Bell927.mid Writing : /LGAPP/Media/Sounds/Default sounds/Failure.mid Writing : /LGAPP/Media/Sounds/Default sounds/Fame_Irene Cara.mid Writing : /LGAPP/Media/Sounds/Default sounds/Happy Together_The Turtles.mid Writing : /LGAPP/Media/Sounds/Default sounds/HS_Connect.mid Writing : /LGAPP/Media/Sounds/Default sounds/HS_Disconnect.mid Writing : /LGAPP/Media/Sounds/Default sounds/Lady armalade_Christina Aguilera.mid Writing : /LGAPP/Media/Sounds/Default sounds/Love Me Do_Beatles.mid Writing : /LGAPP/Media/Sounds/Default sounds/LowBattery.mid Writing : /LGAPP/Media/Sounds/Default sounds/Message1.mid Writing : /LGAPP/Media/Sounds/Default sounds/Message2.mid Writing : /LGAPP/Media/Sounds/Default sounds/Message3.mid Writing : /LGAPP/Media/Sounds/Default sounds/Message4.mid Writing : /LGAPP/Media/Sounds/Default sounds/Message5.mid Writing : /LGAPP/Media/Sounds/Default sounds/Message6.mid Writing : /LGAPP/Media/Sounds/Default sounds/Message7.mid Writing : /LGAPP/Media/Sounds/Default sounds/Moonlight Shadow_Mike Oldfield.mid Writing : /LGAPP/Media/Sounds/Default sounds/Movie_Shot_end.mmf Writing : /LGAPP/Media/Sounds/Default sounds/Movie_Shot_start.mmf Writing : /LGAPP/Media/Sounds/Default sounds/PopUp.mid Writing : /LGAPP/Media/Sounds/Default sounds/Power Off.aac Writing : /LGAPP/Media/Sounds/Default sounds/Power On.aac Writing : /LGAPP/Media/Sounds/Default sounds/Ring1.mid Writing : /LGAPP/Media/Sounds/Default sounds/Ring2.mid Writing : /LGAPP/Media/Sounds/Default sounds/Shape Of My Heart_Sting.mid Writing : /LGAPP/Media/Sounds/Default sounds/Shutter1.wav Writing : /LGAPP/Media/Sounds/Default sounds/Shutter2.wav Writing : /LGAPP/Media/Sounds/Default sounds/Success.mid Writing : /LGAPP/Media/Sounds/Default sounds/TA Connect.mid Writing : /LGAPP/Media/Sounds/Default sounds/UPTOWN GIRL_Billy Joel.MID Writing : /LGAPP/Media/Videos/Welcome_To_3.mp4 Writing : /LGAPP/Media/dm/LG_DM_DDF.xml Writing : /LGAPP/Media/Language/English.tok.gz Writing : /LGAPP/Media/Language/Italian.tok.gz Writing : /LGAPP/Media/Language/Swedish.tok.gz Writing : /LGAPP/Media/Language/Danish.tok.gz Writing : /LGAPP/Media/Language/French.tok.gz Writing : /LGAPP/Media/Language/German.tok.gz Writing : /LGAPP/Obigo/msm/registry.dat Writing : /LGAPP/Obigo/msm/timers.dat Writing : /LGAPP/Obigo/ses/storage/0 Writing : /LGAPP/Obigo/ses/storage/1 Writing : /LGAPP/Obigo/ses/storage/10 Writing : /LGAPP/Obigo/ses/storage/11 Writing : /LGAPP/Obigo/ses/storage/2 Writing : /LGAPP/Obigo/ses/storage/3 Writing : /LGAPP/Obigo/ses/storage/4 Writing : /LGAPP/Obigo/ses/storage/5 Writing : /LGAPP/Obigo/ses/storage/6 Writing : /LGAPP/Obigo/ses/storage/7 Writing : /LGAPP/Obigo/ses/storage/8 Writing : /LGAPP/Obigo/ses/storage/9 Writing : /LGAPP/Obigo/stk/auth/index.dat Writing : /LGAPP/Obigo/stk/cache/content.dat Writing : /LGAPP/Obigo/stk/cache/index.dat Writing : /LGAPP/Obigo/stk/cookie/index.dat Writing : /LGAPP/Media/Version Writing : /UPLOAD/Pxo/ADManager.pxo Writing : /UPLOAD/Pxo/AgingTest.pxo Writing : /UPLOAD/Pxo/Alarm.pxo Writing : /UPLOAD/Pxo/AlarmClock.pxo Writing : /UPLOAD/Pxo/AlarmSpy.pxo Writing : /UPLOAD/Pxo/AlwaysOnPDPMngr.pxo Writing : /UPLOAD/Pxo/Bluetooth.pxo Writing : /UPLOAD/Pxo/Bookmark.pxo Writing : /UPLOAD/Pxo/Btsearch.pxo Writing : /UPLOAD/Pxo/Calculator.pxo Writing : /UPLOAD/Pxo/Calendar.pxo Writing : /UPLOAD/Pxo/CallBarring.pxo Writing : /UPLOAD/Pxo/CallCosts.pxo Writing : /UPLOAD/Pxo/CallDivert.pxo Writing : /UPLOAD/Pxo/CallDuration.pxo Writing : /UPLOAD/Pxo/callgwcsd.pxo Writing : /UPLOAD/Pxo/callgwfax.pxo Writing : /UPLOAD/Pxo/callmain.pxo Writing : /UPLOAD/Pxo/CallRegister.pxo Writing : /UPLOAD/Pxo/callvideo.pxo Writing : /UPLOAD/Pxo/callvoice.pxo Writing : /UPLOAD/Pxo/CallWaitingPopup.pxo Writing : /UPLOAD/Pxo/Camcorder.pxo Writing : /UPLOAD/Pxo/Camera.pxo Writing : /UPLOAD/Pxo/CissCBPWVerify.pxo Writing : /UPLOAD/Pxo/CommonComposer.pxo Writing : /UPLOAD/Pxo/Connectivity.pxo Writing : /UPLOAD/Pxo/DataCallManager.pxo Writing : /UPLOAD/Pxo/dayfinder.pxo Writing : /UPLOAD/Pxo/dday.pxo Writing : /UPLOAD/Pxo/Display.pxo Writing : /UPLOAD/Pxo/DMAgent.pxo Writing : /UPLOAD/Pxo/DMClient.pxo Writing : /UPLOAD/Pxo/EmailComposer.pxo Writing : /UPLOAD/Pxo/EmailList.pxo Writing : /UPLOAD/Pxo/EmailSettings.pxo Writing : /UPLOAD/Pxo/EManager.pxo Writing : /UPLOAD/Pxo/Emergencycall.pxo Writing : /UPLOAD/Pxo/enginmode.pxo Writing : /UPLOAD/Pxo/FileListCtrl.pxo Writing : /UPLOAD/Pxo/FileManager.pxo Writing : /UPLOAD/Pxo/FixedDialNum.pxo Writing : /UPLOAD/Pxo/GotoURL.pxo Writing : /UPLOAD/Pxo/IdleMngr.pxo Writing : /UPLOAD/Pxo/IdleSubDisplay.pxo Writing : /UPLOAD/Pxo/ImageEditor.pxo Writing : /UPLOAD/Pxo/ImageView.pxo Writing : /UPLOAD/Pxo/Infopopup.pxo Writing : /UPLOAD/Pxo/Internet.pxo Writing : /UPLOAD/Pxo/Java.pxo Writing : /UPLOAD/Pxo/JavaBg.pxo Writing : /UPLOAD/Pxo/JavaSv.pxo Writing : /UPLOAD/Pxo/Language.pxo Writing : /UPLOAD/Pxo/LSDrm.pxo Writing : /UPLOAD/Pxo/MediaManager.pxo Writing : /UPLOAD/Pxo/MemoGeneral.pxo Writing : /UPLOAD/Pxo/MemoSecret.pxo Writing : /UPLOAD/Pxo/Message.pxo Writing : /UPLOAD/Pxo/MessageBgProc.pxo Writing : /UPLOAD/Pxo/MMPlayer.pxo Writing : /UPLOAD/Pxo/MMSNotiView.pxo Writing : /UPLOAD/Pxo/Morningcall.pxo Writing : /UPLOAD/Pxo/MsgBox.pxo Writing : /UPLOAD/Pxo/MsgSettingsMenu.pxo Writing : /UPLOAD/Pxo/MyFavorite.pxo Writing : /UPLOAD/Pxo/notipopup.pxo Writing : /UPLOAD/Pxo/OTAPinPopup.pxo Writing : /UPLOAD/Pxo/OTAPManager.pxo Writing : /UPLOAD/Pxo/PacketTE.pxo Writing : /UPLOAD/Pxo/PBEntry.pxo Writing : /UPLOAD/Pxo/PBSearch.pxo Writing : /UPLOAD/Pxo/PBUtil.pxo Writing : /UPLOAD/Pxo/PFEM.pxo Writing : /UPLOAD/Pxo/PhoneAgent.pxo Writing : /UPLOAD/Pxo/PhoneBookSpy.pxo Writing : /UPLOAD/Pxo/PhoneIdle.pxo Writing : /UPLOAD/Pxo/Phonelock.pxo Writing : /UPLOAD/Pxo/PhoneMenu.pxo Writing : /UPLOAD/Pxo/PhoneMngr.pxo Writing : /UPLOAD/Pxo/PhoneMngrNoti.pxo Writing : /UPLOAD/Pxo/PhoneMngrNotiHeap.pxo Writing : /UPLOAD/Pxo/PhoneTest.pxo Writing : /UPLOAD/Pxo/PinProc.pxo Writing : /UPLOAD/Pxo/PreferMode.pxo Writing : /UPLOAD/Pxo/Profiles.pxo Writing : /UPLOAD/Pxo/PushViewer.pxo Writing : /UPLOAD/Pxo/PwrOn.pxo Writing : /UPLOAD/Pxo/Reset.pxo Writing : /UPLOAD/Pxo/Rodeo.pxo Writing : /UPLOAD/Pxo/SavedPage.pxo Writing : /UPLOAD/Pxo/SecManager.pxo Writing : /UPLOAD/Pxo/Security.pxo Writing : /UPLOAD/Pxo/Settings_Call.pxo Writing : /UPLOAD/Pxo/Settings_CB.pxo Writing : /UPLOAD/Pxo/Settings_Connection.pxo Writing : /UPLOAD/Pxo/Settings_Diary.pxo Writing : /UPLOAD/Pxo/Settings_ExpressLink.pxo Writing : /UPLOAD/Pxo/Settings_Internet.pxo Writing : /UPLOAD/Pxo/Settings_MemoryStatus.pxo Writing : /UPLOAD/Pxo/Settings_MMS.pxo Writing : /UPLOAD/Pxo/Settings_Phone.pxo Writing : /UPLOAD/Pxo/Settings_PhoneInfo.pxo Writing : /UPLOAD/Pxo/Settings_VMB.pxo Writing : /UPLOAD/Pxo/Settings_VMS.pxo Writing : /UPLOAD/Pxo/SmsCBViewer.pxo Writing : /UPLOAD/Pxo/SmsMngr.pxo Writing : /UPLOAD/Pxo/SmsSetting.pxo Writing : /UPLOAD/Pxo/SmsSubView.pxo Writing : /UPLOAD/Pxo/SmsViewer.pxo Writing : /UPLOAD/Pxo/SoundCalibration.pxo Writing : /UPLOAD/Pxo/sscisshi.pxo Writing : /UPLOAD/Pxo/ssmanager.pxo Writing : /UPLOAD/Pxo/ssussdhi.pxo Writing : /UPLOAD/Pxo/SyncMLClient_Engine.pxo Writing : /UPLOAD/Pxo/SyncMLClient_UI.pxo Writing : /UPLOAD/Pxo/Taskmngr.pxo Writing : /UPLOAD/Pxo/TermCallReject.pxo Writing : /UPLOAD/Pxo/Todo.pxo Writing : /UPLOAD/Pxo/UnitConverter.pxo Writing : /UPLOAD/Pxo/USAT.pxo Writing : /UPLOAD/Pxo/UsimMngr.pxo Writing : /UPLOAD/Pxo/VoiceRecorder.pxo Writing : /UPLOAD/Pxo/VTSetup.pxo Writing : /UPLOAD/Pxo/WapManager.pxo Writing : /UPLOAD/Pxo/WorldClock.pxo Writing : /UPLOAD/Pxo/Version RESETTING PHONE ! WAITING 130s PHONE TO WAKE UP; PHONE ONLINE; NV WRITE SKIPPED; WAITING 25s PHONE TO WAKE UP; PHONE ONLINE; FLASHING ENGINE SHUTDOWN ... OK; Time needed - 00:28:22 |
