03-07-2016, 06:15 | #13021 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on FTEAM USB Serial Port (COM83); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6573, E00 Sw version: MAUI.11AMD.W11.37.SP.V27.P22 Hw Version: JRD73_GIN_MODEM_GEMINI2_HW Reading phone info; IMEI: 862601-01-040361-8 Reading simlock info; Locked to: 214-04 code_cat_n: 11932329 enabled: yes tries: 9 code_cat_ns: 10085602 enabled: no tries: 10 code_cat_sp: 05134121 enabled: no tries: 10 code_cat_c: 12004624 enabled: no tries: 10 code_cat_sim: 12999953 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Time needed - 00:01:00 |
03-07-2016, 06:15 | #13022 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | t156 huawei unlock done Software engine version: 1.0.0.6594 Connect phone powered on ! Start auth ! SW Ver: P1.2PU02V01.01 Imei: 353081034780935 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_353081034780935_P1.2PU02V01.01_18.25.26_05. 03.2016_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:23 |
03-07-2016, 06:15 | #13023 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | imo 3g unlock Software engine version: 1.0.0.9836 Searching phone ... MODEL : QCOM SERIES 2 [KYUZ] COMPILED DATE : Apr 10 2009 19:16:00 RELEASE DATE : Jul 8 2008 05:00:00 FIRMWARE INFO : M6260A-KYRZ-2.5.1033_3A IMEI : 35422202265290-5 BLUETOOTH ADDR : B9 DB 54 40 12 00 MEMORY ID : 00AD:0078 MEMORY NAME : hynix_h8acs0ej0mcp MEMORY INFO : 0200:0020:1599 INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; RESET ! Log file saved to: LOG_6_03_2016_16_35_24.txt Time needed - 00:00:07 |
03-07-2016, 16:48 | #13024 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Huawei Y530-U00 Direct Unlock done in Manufacturing mode.. 3/7/2016 3:38:55 PM FlyCaptain Huawei Module v2.0.0.0058 Furious Gold Pack 7 Before detection connect cable to usb and enable Manufacture mode ! Qualcomm and HiSilicon: *#*#2846579#*#* MTK: *#*#14789632#*#* Windows: ##2846579# ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode 2016-03-07 15:39:00.318 Autodetect started! 2016-03-07 15:39:02.019 Found COM port: COM196 2016-03-07 15:39:02.034 Start read phone info! 2016-03-07 15:39:02.050 Open port COM196 (DBAdapter Reserved Interface (COM196))... 2016-03-07 15:39:02.175 Phone authorize start 2016-03-07 15:39:02.175 Connecting to server... 2016-03-07 15:39:05.217 Connected! 2016-03-07 15:39:05.217 Read data from server... 2016-03-07 15:39:07.510 Read data from server success! 2016-03-07 15:39:09.943 Phone authorize success! 2016-03-07 15:39:09.975 Read secure info... 2016-03-07 15:39:10.068 Read basic info... 2016-03-07 15:39:10.115 Detect phone done! Model: Y530_U00 IMEI: 864921024167126 Firmware ver.: MSM8x1xC900B512_AMSS Aug 7 201413:27:26 SN: C2Z7NB94C1503977 Custom SN: 022KRN7N4C013018 WiFi MAC: E0:19:1D:788:3E BlueTooth MAC: E0:19:1D:78:E5:87 Vendor: orange Country: ch MSM8x1xC900B512_BOOT MSM8x1xC900B512_AMSS Aug 7 201413:27:26 Y530U00C00B012_EFS_RFNV_B01 HD1Y530M_VERA APPSBOOT Aug 11 201418:38:13 Y530-U00V100R001C900B512_KERNEL Y530-U00V100R001C900B512_SYSTEM Y530-U00V100R001C900B512_RECOVERY MSM8210 IMEI 1 Sim Lock status: NET: locked, unlock retry counts: 10 NETSUB: unlocked SP: unlocked Bootloader code: 1531602211013266 2016-03-07 15:39:59.202 Autodetect started! 2016-03-07 15:40:00.918 Found COM port: COM196 2016-03-07 15:40:00.933 Open port COM196 (DBAdapter Reserved Interface (COM196))... 2016-03-07 15:40:01.074 Connecting to server... 2016-03-07 15:40:04.724 Connected! 2016-03-07 15:40:04.740 Read data from server... 2016-03-07 15:40:06.721 Read data from server success! 2016-03-07 15:40:06.736 Phone authorize start 2016-03-07 15:40:06.752 Phone authorize success! 2016-03-07 15:40:06.783 Unlocking start 2016-03-07 15:40:06.799 Read secure info... 2016-03-07 15:40:06.939 Read secure info success! 2016-03-07 15:40:06.955 Read basic info... 2016-03-07 15:40:07.002 Read basic info success! 2016-03-07 15:40:08.468 Read data from server... 2016-03-07 15:40:11.136 Read data from server success! 2016-03-07 15:40:11.151 Writing security data... 2016-03-07 15:40:11.338 Write security data success! 2016-03-07 15:40:11.806 Unlock done! 2016-03-07 15:40:11.838 Job finished! |
03-08-2016, 15:06 | #13025 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel one touch fierce xl 5054N Metro PCs Direct Unlock done.. Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (ALCATEL HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM136 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 01445100689667-3 PTH: 16 PTS: D6U PROV_ID: 5054N-2AE4US1 SBTADDR: 18:E3:BC:0E:CA:2C SWIFIADDR: 18:E3:BC:0E:CA:2D HS_PN: SAA35HAAA10C SSN: 2VKF09CL2PY02ZK Work id: 03626D0C Done; SECURITY: X8D0UP00BR10 Size: 000002B7 Backup saved to: 01445100689667-3 Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_8_03_2016_13_56_14.txt Time needed - 00:00:32 |
The Following 2 Users Say Thank You to razib143 For This Useful Post: |
03-09-2016, 15:30 | #13026 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | alcayel 5054n unlock done great great Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem136.inf,%qcdownloaddiag%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM117 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 01445100327 PTH: 15 PTS: D6U PROV_ID: 5054N-2AE4US1 SBTADDR: 1C:CB:99:A5:6B:07 SWIFIADDR: 1C:CB:99:A5:6B:08 HS_PN: SAA35HAAA10C SSN: 2VKF07CB6OY01G6 Work id: 01A88B04 Done; SECURITY: X8D0UP00BR10 Size: 000002B7 Backup saved to: 01445100327458-5 Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_9_03_2016_15_28_54.txt Time needed - 00:00:52 |
03-09-2016, 18:10 | #13027 (permalink) |
No Life Poster Join Date: Feb 2010 Location: Macedonia Age: 49
Member: 1246981 Status: Offline Sonork: 100.1590424 Thanks Meter: 316 | huawei scl-l01 (y6) unlock done Model: HUAWEISCL-L01 IMEI: 867538024636004 Firmware ver.: MSM8909C900B130_AMSS Sep 25 201520:25:42 SN: NQL7N15C03012053 Custom SN: 7N3FSE15B4006099 WiFi MAC: 48B:50:8C:8F:FE BlueTooth MAC: 48B:50:8C:94:00 Vendor: dt Country: mk SCL-L01C150B140_BOOT MSM8909C900B130_AMSS Sep 25 201520:25:42 SCL-L01_C00B007_EFS_RFNV_B05 HL3SCALEM SCL-L01C150B140_APPSBOOT SCL-L01C150B140_KERNEL SCL-L01C150B140_SYSTEM SCL-L01C150B140_RECOVERY MSM8909 HUAWEI SCL-L01 MKDC150 D004 IMEI 1 Sim Lock status: NET: unknown NETSUB: unknown SP: unknown 2016-03-09 18:05:32.835 Autodetect started! 2016-03-09 18:05:34.421 Found COM port: COM74 2016-03-09 18:05:34.429 Open port COM74 (DBAdapter Reserved Interface (COM74))... 2016-03-09 18:05:34.546 Connecting to server... 2016-03-09 18:05:35.360 Connected! 2016-03-09 18:05:35.363 Read data from server... 2016-03-09 18:05:36.837 Read data from server success! 2016-03-09 18:05:36.844 Phone authorize start 2016-03-09 18:05:36.853 Phone authorize success! 2016-03-09 18:05:36.865 Unlocking start 2016-03-09 18:05:36.869 Read secure info... 2016-03-09 18:05:36.925 Read secure info success! 2016-03-09 18:05:36.929 Read basic info... 2016-03-09 18:05:36.990 Read basic info success! 2016-03-09 18:05:37.035 Reading secure data from server... 2016-03-09 18:05:38.712 Reading secure data from server success! 2016-03-09 18:05:38.811 Unlock done! 2016-03-09 18:05:38.840 Job finished! 2016-03-09 18:06:55.001 Autodetect started! 2016-03-09 18:07:08.587 Found COM port: COM74 2016-03-09 18:07:08.587 Start read phone info! 2016-03-09 18:07:08.602 Open port COM74 (DBAdapter Reserved Interface (COM74))... 2016-03-09 18:07:08.712 Phone authorize start 2016-03-09 18:07:08.712 Connecting to server... 2016-03-09 18:07:09.524 Connected! 2016-03-09 18:07:09.524 Read data from server... 2016-03-09 18:07:10.969 Read data from server success! 2016-03-09 18:07:12.548 Phone authorize success! 2016-03-09 18:07:12.548 Read secure info... 2016-03-09 18:07:12.626 Read basic info... 2016-03-09 18:07:12.702 Detect phone done! Model: HUAWEISCL-L01 IMEI: 867538024636004 Firmware ver.: MSM8909C900B130_AMSS Sep 25 201520:25:42 SN: NQL7N15C03012053 Custom SN: 7N3FSE15B4006099 WiFi MAC: 48B:50:8C:8F:FE BlueTooth MAC: 48B:50:8C:94:00 Vendor: dt Country: mk SCL-L01C150B140_BOOT MSM8909C900B130_AMSS Sep 25 201520:25:42 SCL-L01_C00B007_EFS_RFNV_B05 HL3SCALEM SCL-L01C150B140_APPSBOOT SCL-L01C150B140_KERNEL SCL-L01C150B140_SYSTEM SCL-L01C150B140_RECOVERY MSM8909 HUAWEI SCL-L01 MKDC150 D004 IMEI 1 Sim Lock status: NET: unlocked NETSUB: unlocked SP: unlocked |
03-09-2016, 18:28 | #13028 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Sagem My220V Direct Unlock done.. Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:011A Reading ... Saved: SAGEM_17.17.26_09.03.2016_PARTIAL.bin Done ! Time needed - 00:01:27 |
03-11-2016, 16:27 | #13029 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | zte z730 unlock done Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; BRAND: ZTE MODEL: Z730 ANDROID: v4.3 CPU: QCOM IMEI: 863993022426987 KERNEL: Linux version 3.4.0+ (xueyibing@zte2) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Fri Mar 28 14:59:01 CST 2014 Cleaning; Setting usb config; Done; Reconnecting; Looking for the interface; Port found [ZTE Handset Diagnostic Interface (COM729)] Backing up sensitive data; Done; Backup saved to: 863993022426987.NV Done; Done; Restarting the phone; Setting usb config; Done; Reconnecting; Looking for the interface; Port found [ZTE Handset Diagnostic Interface (COM729)] Restoring sensitive data; Done; SIM_LOCK REMOVED ! POWER OFF / ON THE PHONE MANUALLY TO COMPLETE THE UNLOCK ! Log file saved to: LOG_11_03_2016_16_20_49.txt Time needed - 00:06:20 |
03-12-2016, 13:27 | #13031 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | alcatel ot 2010g unlock Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MTK USB Port (COM12)) Preparing to start meta mode; Requesting authorization; Done; Meta mode entered; Baseband Chip: MT6250 Sw version: MAUI.11B.W12.24.MP.V2.F21 Hw Version: JRDHZ50_12864_11B_24MP_HW Reading phone info; IMEI: 867964-01-026853-9 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:10 Log file saved to: LOG_12_03_2016_17_25_19.txt |
03-12-2016, 15:30 | #13032 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | alcatel 2005a unlock done only furios Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (USB Single Port (COM166)) Preparing to start meta mode; Requesting authorization; Done; Meta mode entered; Baseband Chip: MT6250 Sw version: MAUI.11B.W12.24.MP.V2.F41 Hw Version: JRDHZ50_12864_11B_24MP_HW Reading phone info; IMEI: 013506-00-122436-0 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:10 Log file saved to: LOG_12_03_2016_15_23_02.txt |
03-13-2016, 04:13 | #13033 (permalink) | |
No Life Poster Join Date: Nov 2003 Location: GT
Member: 44659 Status: Offline Thanks Meter: 363 | Alcatel 3022G direct unlock ... Quote:
03-13-2016, 04:19 | #13034 (permalink) | |
03-13-2016, 04:19 | #13035 (permalink) | |
