Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 04-12-2017, 11:34   #13651 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
Alcatel 2004c unlocked done
Using library Brom_DLL_v5.1316.1
Searching phone;
(for some models keep SPACE or * (STAR) key pressed before inserting the cable)
Phone detected (MediaTek USB Port (COM35))
Preparing to start meta mode;
Requesting authorization;
Done;
Meta mode entered;
Baseband Chip:    MT6260
Sw version:    MAUI.11B.W13.08.MP.V4.F54
Hw Version:    JRDHZ60A_11B_HW
Reading phone info;
IMEI:        014253-00-56xxxx-x
Reading security;
Done;
Checking;
Preparing;
Writing security;
Phone unlocked; Remove battery and cable;
Time needed - 00:00:22
Old 04-12-2017, 11:40   #13652 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
v685 UNLOCKED SUCCESSFULLY
Using library Brom_DLL_v7.1413.5
Searching phone in normal mode;
[connect the phone powered off to the usb cable]
Phone detected (MediaTek PreLoader USB VCOM (Android) (COM25))
Preparing to start flash mode;
Preparing to open COM25
Connecting;
Downloading DA;
Initializing;
Rid: 5ea9c63afb64b2390265e1c1a5accab4
Requesting baudrate change;
Done;
USB SPEED: USB_HIGH_SPEED
Switching to DA_HIGHSPEED_VCOM;
Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86;
If the detection fails, install manually the port from the device manager using usbvcom.inf;
DA_HIGHSPEED_VCOM (MediaTek DA USB VCOM (Android))
TRYING TO OPEN COM42;
DEVICE INFO:
BB CHIP: MT6572_S00 [CA01, 00, 6572, FF]
HW_STORAGE_EMMC: 0x4E000115 0x4D5A5835 0x73A40142 0xA5812EE0  [SIZE=0xE9880000]
IMEI1 [OTP 0001]: 354459-06-74XXXX-X
IMEI2 [OTP 0001]: 000000-00-000000-0
PROVIDER: V685-2AVDRO1
USRDATA INFO: 0x61B80000 SIZE: 0x87D00000
Searching data;
Locked to [SIM1]:    226-01
code_cat_n:    32400133 enabled:    yes    tries: 10
code_cat_ns:    31942239 enabled:    no    tries: 10
code_cat_sp:    30973654 enabled:    no    tries: 10
code_cat_c:    31377691 enabled:    no    tries: 10
code_cat_sim:    34142728 enabled:    no    tries: 10
code_cat_ns_sp:    53297761 enabled:    no    tries: 5
code_cat_sim_c:    86817778 enabled:    no    tries: 5
Old 04-13-2017, 16:52   #13653 (permalink)
Member: 2329547
Thanks Meter: 15
Lightbulb lg h440n unlock done
Software engine version: 1.0.0.10469 Searching phone ... MODEL: LG Leon 4G LTE COMPILED DATE :Jun 13 2015 17:26:00 RELEASE DATE :Mar 31 2015 01:00:00 FIRMWAREINFO:MPSS.DPM.2.0.c11-00018M8936FAAAANUZM-1 IMEI : 3588190602XXXX-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; WORKING; DONE; CALC 0 CALC 1 CALC 2 CALC 3 CALC 9 CALC 10 SIM_LOCK REMOVED ! Time needed - 00:00:36
Old 04-13-2017, 20:24   #13654 (permalink)
chadzar's Avatar
Member: 2489690
Thanks Meter: 287
huawei lua-l02 unlock in seconds
(insert the USB cable in the powered off phone)
Phone detected (MediaTek PreLoader USB VCOM (Android))
Preparing to start MTK debug mode;
Searching for debug port... (be sure drivers from support were installed!)
MTK debug mode entered
Baseband Chip: MT6735M,S01
Sw version:
Hw Version: ALPS.L1.MP3.V2.95_OT6735M.35GU.LU.L1_P1
Baseband Chip: MT6735, E00
Sw version: MOLY.LR9.W1444.MD.LWTG.MP.V48.P8
Hw Version: OT6735_65C_LU_L1_HW
Reading info...
IMEI 1: 869821020985353
IMEI 2: N/A
Open port success!
2017-04-13 21:13:23.619 Reading data from server...
2017-04-13 21:13:24.835 Reading data from server success!
Reading simlock info;
Gathering info;
Simlock ok;
SIM1 Locks cleared;
Simlock ok;
SIM2 Locks cleared;
Simlock read end;
The Following User Says Thank You to chadzar For This Useful Post:
Old 04-14-2017, 09:51   #13655 (permalink)
chadzar's Avatar
Member: 2489690
Thanks Meter: 287
huawei y550-l01 unlock done in seconds
Before detection connect cable to usb and enable Manufacture mode !
*#*#2846579#*#*
ProjectMenu
1.Background setting
2.USB ports setting
Select Manufacture mode
Select DBAdapter Reserved Interface COM port
2017-04-14 10:48:38.722 Start read phone info!
2017-04-14 10:48:38.768 Open port COM45 (DBAdapter Reserved Interface (COM45))...
2017-04-14 10:48:38.878 Phone authorize start
2017-04-14 10:48:38.878 Connecting to server...
2017-04-14 10:48:41.623 Connected!
2017-04-14 10:48:41.623 Read data from server...
2017-04-14 10:48:43.355 Read data from server success!
2017-04-14 10:48:44.977 Phone authorize success!
2017-04-14 10:48:44.993 Read secure info...
2017-04-14 10:48:45.055 Read basic info...
2017-04-14 10:48:45.102 Detect phone done!
Model: Y550-L01
IMEI: 865170028026297
SUB_IMEI: 865170028026297
Firmware ver.: Y550-L01V100R001C00B256_AMSS May 7 201515:26:55
SN: A3B7N15531001521
Custom SN: 7N2VGP155P069855
WiFi MAC: F4:8E:92:4D:E4:B2
BlueTooth MAC: F4:8E:92:4D:F0:A7
Vendor: mascom
Country: bw
SL: 00000000
Y550-L01V100R001C00B256_BOOT
Y550-L01_C00B110_EFS_RFNV_C05
HL3Y550M_VERC
Y550-L01V100R001C00B256_APPSBOOT
Y550-L01V100R001C00B256_KERNEL
Y550-L01V100R001C00B256_SYSTEM
IMEI 1 Sim Lock status:
NET: locked, unlock retry counts: 1
NETSUB: unlocked
SP: unlocked
2017-04-14 10:48:52.918 Open port COM45 (DBAdapter Reserved Interface (COM45))...
2017-04-14 10:48:53.042 Connecting to server...
2017-04-14 10:48:55.055 Connected!
2017-04-14 10:48:55.070 Read data from server...
2017-04-14 10:48:56.724 Read data from server success!
2017-04-14 10:48:57.114 Phone authorize start
2017-04-14 10:48:58.892 Phone authorize success!
2017-04-14 10:48:58.908 Read secure info...
2017-04-14 10:48:58.970 Read secure info success!
2017-04-14 10:48:58.986 Read basic info...
2017-04-14 10:48:59.017 Read basic info success!
2017-04-14 10:48:59.033 Unlocking start
2017-04-14 10:49:00.374 Read data from server...
2017-04-14 10:49:03.307 Read data from server success!
2017-04-14 10:49:03.323 Writing security data...
2017-04-14 10:49:03.448 Write security data success!
2017-04-14 10:49:03.838 Unlock done!
2017-04-14 10:49:03.853 Job finished!
Old 04-14-2017, 12:37   #13656 (permalink)
DUSKnenixs's Avatar
Member: 5169
Thanks Meter: 669
Originally Posted by theboy View Post
Unlock using pack 6 MTK code reader and Mobiwire Aquila model
Searching phone;
Phone detected (@oem72.inf,%vcom_preloader%;MediaTek PreLoader USB VCOM (Android))
Searching for debug port; (be sure drivers from support were installed)
Debug Port found on Gadget CDC VCOM Driver (COM793);
Preparing to connect meta mode;
Meta mode entered;
Baseband Chip: MT6580, E01
Sw version: MOLY.WR8.W1449.MD.WG.MP.V57.P3
Hw Version: SR6580_WE_M_HSPA_HW
Reading phone info;
IMEI: 359072-07-042734-5
Locked to: C1C-1C
code_cat_n: 12345678 enabled: no tries: 5
code_cat_ns: 56781234 enabled: no tries: 5
code_cat_sp: 11112222 enabled: no tries: 5
code_cat_c: 33334444 enabled: no tries: 5
code_cat_sim: 55556666 enabled: no tries: 5
code_cat_ns_sp: 77778888 enabled: no tries: 5
code_cat_sim_c: 99990000 enabled: no tries: 5
Time needed - 00:01:01
Log file saved to: LOG_6_03_2017_18_54_08.txt
Same here:
Searching phone;
Phone detected (@oem311.inf,%vcom_preloader%;MediaTek PreLoader USB VCOM (Android))
Debug Port found on MediaTek USB VCOM (Android) (COM10);
Meta mode entered;
Baseband Chip: MT6580B, E00
Reading phone info;
IMEI: 359072-07-060xxx-2
Locked to: C1C-1C
Time needed - 00:01:05
Log file saved to: LOG_14_04_2017_12_35_00.txt
Old 04-15-2017, 17:09   #13657 (permalink)
hagard's Avatar
Member: 161547
Thanks Meter: 241
Alcatel 2036A Successfuly Unlocked by SPD Service Tool New Version.
TEST REPORT..
Phone Locked to LIME
Use Navigation UP and DOWN then insert USB cable to detect the phone..
Searching phone;
For an successful connection do the following:
1. Remove battery and usb cable
2. Insert the usb cable in the phone
3. Keep pressed the boot key and insert the battery
Phone detected (@oem267.inf,%dvcdsc%;SCI USB2Serial)
Preparing to sync;
Port opened [COM73];
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Loader version: Spreadtrum Boot Block version 1.1
Starting FDL2;
FDL2 sent;
Chip type: 7702 FdlStat: 0000
Starting auth;
Memory NAND [CS0]: 0098:00B1 - SIZE : 08000000
EFUSE HASH: 0000000000000000000000000000000000000000
HW IMEI : 000000-00-000000-0
Reading phone info;
PHONE INFO: 2036A-3BCIJM1
BT ADDR: BC:2A:6F:51:AA:57
SW IMEI[0]: 014407-00-163177-0
SW IMEI[1]: 352751-01-265893-0
SW IMEI[2]: 358570-01-010389-3
SW IMEI[3]: 910575-60-140046-8
SIMLOCK FLAG: ON
FIXED NV BASE: 40040000
Reading NV;
NV saved to : NV_000000-00-000000-0_014407-00-163177-0_77020000_15_04_2017_11_02_17.spd
IMEI: 014407-00-163177-0 UNLOCK CODE: 58128810
Re-programming;
NV programmed;
Done;
Log file saved to: LOG_15_04_2017_11_02_42.txt
Time needed - 00:00:34
Hagard
Old 04-16-2017, 13:54   #13658 (permalink)
Member: 1215266
Thanks Meter: 122
Alcatel 1016 unlock done
Searching phone;
Phone detected (@oem151.inf,%dvcdsc%;SCI USB2Serial)
Preparing to sync;
Port opened [COM16];
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT
Chip type: 6531 FdlStat: 0001
Starting auth;
Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000
Reading phone info;
PHONE INFO: 1016G-3AE8GB1
BT ADDR: FF:FF:FF:FF:FF:FF
SW IMEI[0]: 359160-06-974772-2
SW IMEI[1]: 352751-01-952326-7
SIMLOCK FLAG: ON
FIXED NV BASE: 303C0000
Reading NV;
NV saved to : NV_000000-00-000000-0_359160-06-974772-2_65310001_16_04_2017_05_43_11.spd
IMEI: 359160-06-974772-2 UNLOCK CODE: 31524696
Re-programming;
NV programmed;
Done;
Log file saved to: LOG_16_04_2017_05_43_30.txt
Time needed - 00:00:28
Old 04-17-2017, 16:54   #13659 (permalink)
Member: 2382052
Thanks Meter: 1,499
ALCATEL 6055U UNLOCK DONE
Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ;
Phone detected (@oem408.inf,%qcdownloaddiag%;Qualcomm HS-USB QDLoader 9008)
Preparing to open COM29
Connecting;
Loading;
Init;
Port opened;
Hello Received;
BOOT Loaded;
Getting config;
Getting mem info;
Found an eMMC memory 22F8
IMEI: 01465800059274-0
PTH: 09
PTS: CAC
PROV_ID: 6055U-2ARKUSC-2
SBTADDR: 20:A9:0E:E3:84:29
SWIFIADDR: 20:A9:0E:F5:36:B9
HS_PN: SAA363AAS11C
SSN: F5KA11CB9KZ0171
Work id: 00FE90FB
Done;
SECURITY: X1C0UC00BX10 Size: 000002BF
Backup saved to: 01465800059274-0
Backup file(s) removed;
Unlocking;
SIM_LOCK REMOVED !
Log file saved to: LOG_17_04_2017_11_51_41.txt
Time needed - 00:29:34
Old 04-18-2017, 07:05   #13660 (permalink)
kamranas's Avatar
Member: 1154111
Sonork: 100.1620855
Thanks Meter: 157
vfd 300 unlock done furious gold pack 6 otsmart
Using library Brom_DLL_v7.1522.2
Searching in normal mode;
[connect the powered off to the usb cable]
detected (MediaTek PreLoader USB VCOM () (COM51))
Preparing to mode;
Preparing to open COM51
Connecting;
Downloading DA;
Initializing;
Rid: bcec25b94d5240c459dd60ba3c1af9f5
Requesting baudrate ;
Done;
Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86;
DA_HIGHSPEED_VCOM (@oem181.inf,%vcom_da%;MediaTek DA USB VCOM ())
TRYING TO OPEN COM22;
DEVICE INFO:
BB CHIP: MT6580_S00 [CA00, 00, 6580, FF]
HW_STORAGE_EMMC: 0x30000111 0x45473430 0x91270030 0xFD43CC77 [SIZE=0xEC480000]
IMEI1 [OTP 0000]: 000000-00-000000-0
IMEI2 [OTP 0000]: 000000-00-000000-0
PROVIDER: V300-2BVDGB2
USRDATA INFO: 0x47000000 SIZE: 0x60000000
Searching data;
Locked to [SIM1]: 234-15
code_cat_n: 9654589826597762 enabled: yes tries: 0
code_cat_ns: 4957604761903047 enabled: no tries: 10
code_cat_sp: 9077146077025256 enabled: no tries: 10
code_cat_c: 2327674908451254 enabled: no tries: 10
code_cat_sim: 9409919598990412 enabled: no tries: 10
code_cat_ns_sp: 8391823918787605 enabled: no tries: 5
code_cat_sim_c: 8313251747747286 enabled: no tries: 5
Time needed - 00:00:07
Log file saved to: LOG_18_04_2017_11_01_56.txt
Old 04-18-2017, 12:16   #13661 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
vodafone 795 unlocked successfuly
Connecting;
Downloading DA;
Initializing;
Rid: a50b000c81ec4b8ee89d9f8b342f2223
Done;
DEVICE INFO:
BB CHIP: MT6735M_S00 [CA00, 00, 335, FF]
HW_STORAGE_EMMC: 0x51000115 0x4D533237 0x57B10042 0x37136696  [SIZE=0x1D2880000]
IMEI1 [OTP 0001]: 352185-07-4xxxxx-x
PROVIDER: V795-2AVDRO1
USRDATA INFO: 0x99000000 SIZE: 0x39880000
Searching data;
code_cat_n:    2603712406310259 enabled:    yes    tries: 10
code_cat_ns:    1842905233155273 enabled:    no    tries: 10
code_cat_sp:    1500162048049001 enabled:    no    tries: 10
code_cat_c:    3206666641892794 enabled:    no    tries: 10
code_cat_sim:    6926172653115369 enabled:    no    tries: 10
code_cat_ns_sp:    6926172653115369 enabled:    no    tries: 5
code_cat_sim_c:    6926172653115369 enabled:    no    tries: 5
Old 04-18-2017, 12:23   #13662 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
huawei y330 unlocked done
[CODESearching phone;
Debug Port found on MediaTek USB VCOM (Android) (COM248);
Meta mode entered;
Baseband Chip: MT6572, E01
Sw version: MOLY.WR8.W1315.MD.WG.MP.V15.P10
Hw Version: HUAWEI72_WE_JB3_HSPA_HW
Reading phone info;
IMEI: 865705-02-1xxxxx-x
Locked to: FFF-FF
code_cat_n: FFFFFFFF enabled: no tries: 10
code_cat_ns: 56781234 enabled: no tries: 10
code_cat_sp: 11112222 enabled: no tries: 10
code_cat_c: 33334444 enabled: no tries: 10
code_cat_sim: 55556666 enabled: no tries: 10
code_cat_ns_sp: 77778888 enabled: no tries: 10
code_cat_sim_c: 99990000 enabled: no tries: 10
[/CODE]
Old 04-18-2017, 12:24   #13663 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
huawei u2800 unlocked
Searching phone ...
MODEL :        Q62xx-OSBL-
STARTING;
OK;
LOADING;
DONE;
STARTING AUTHORISATION;
AUTHORISATION PASSED;
INIT NAND ROUTINES;
NAND INIT MADE;
LOOKING SENSITIVE DATA;
OK;
DONE;
IMEI :        861941010xxxxx-x
READING;
SP_SAVED_TO:    SP_861941_E77_14.38.23_15.02.2017_HUAWEI.bin
ERASING;
WRITING;
SIM_LOCK REMOVED !
DONE !
RESET !
Time needed - 00:01:25
Old 04-18-2017, 12:26   #13664 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
another vf795 unlocked done
Connecting;
Downloading DA;
Initializing;
Rid: 8377714e60f6deb9bf0b2baaaaeb2617
Done;
DEVICE INFO:
HW_STORAGE_EMMC: 0x51000115 0x4D533237 0x7E6D0042 0x274372F2  [SIZE=0x1D2880000]
IMEI1 [OTP 0001]: 352185-07-xxxxxx-x
Searching data;
code_cat_n:    7377498910786000 enabled:    yes    tries: 10
code_cat_ns:    4207184104536760 enabled:    no    tries: 10
code_cat_sp:    7624782543353152 enabled:    no    tries: 10
code_cat_c:    2756758344431240 enabled:    no    tries: 10
code_cat_sim:    6832547845223548 enabled:    no    tries: 10
code_cat_ns_sp:    6832547845223548 enabled:    no    tries: 5
code_cat_sim_c:    6832547845223548 enabled:    no    tries: 5
Time needed - 00:00:06
Old 04-18-2017, 18:47   #13665 (permalink)
Member: 2382052
Thanks Meter: 1,499
ALCATEL 6039A UNLOCK DONE
Connecting;
Loading;
Init;
Port opened;
Hello Received;
BOOT Loaded;
Getting config;
Getting mem info;
Found an eMMC memory 22D4
IMEI: 01436800047165-1
PTH: 24
PTS: AK7
PROV_ID: 6039A-2ARGDO7
SBTADDR: 1C:CB:99:6FC:63
SWIFIADDR: 1C:CB:99:6FC:64
HS_PN: SAA34D1AC10C
SSN: PVKL16BBVNY02KO
Work id: 14E8B7B4
Setup 1;
Done;
Setup 2;
Done;
Setup 3;
Done;
Uploading;
Done;
SECURITY: X1A0NJ00BQ10 Size: 00000430
Backup saved to: 01436800047165-1
Checking the simlock;
Magic ok;
Unlocking;
SIM_LOCK REMOVED !
Log file saved to: LOG_18_04_2017_13_40_08.txt
Time needed - 00:00:43
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.35877 seconds with 9 queries
