04-19-2017, 09:22 | #13666 (permalink) |
No Life Poster Join Date: Jan 2010 Location: iraq
Member: 1215266 Status: Offline Thanks Meter: 129 | alcatel 2052x unlock done For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem151.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM6]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Chip type: 7702 FdlStat: 0000 Starting auth; Memory NAND [CS0]: 0001:00B1 - SIZE : 08000000 EFUSE HASH: 0000000000000000000000000000000000000000 HW IMEI : 000000-00-000000-0 Reading phone info; PHONE INFO: 2052X-3AVDAU1 BT ADDR: 14:62:67:E6:99:8C SW IMEI[0]: 864647-02-256244-4 SW IMEI[1]: 000000-00-000000-0 SW IMEI[2]: 000000-00-000000-0 SW IMEI[3]: 000000-00-000000-0 SIMLOCK FLAG: ON FIXED NV BASE: 40040000 Reading NV; NV saved to : NV_000000-00-000000-0_864647-02-256244-4_77020000_19_04_2017_01_20_05.spd IMEI: 864647-02-256244-4 UNLOCK CODE: 36519239 Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_19_04_2017_01_20_31.txt Time needed - 00:00:41 |
04-21-2017, 08:43 | #13667 (permalink) |
Junior Member Join Date: May 2007
Member: 512503 Status: Offline Thanks Meter: 14 | Mobiwire ayasha unlock done ! OTZflasher Using library Brom_DLL_v5.1428.0 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MediaTek USB Port (COM75)) Preparing to start meta mode; Meta mode entered; Baseband Chip: MT6261 Sw version: V02_160825_MBW_Ayasha_SKU1_MP Hw Version: SAGETEL61M_11C_HW Reading phone info; IMEI: 352441-08-019031-7 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:22 Log file saved to: LOG_21_04_2017_10_40_21.txt |
04-22-2017, 07:48 | #13668 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | Fero 180 done. Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem106.inf,%dc_diag%;SPRD U2S Diag) Preparing to sync; Port opened [COM293]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: NONE BT ADDR: NONE SW IMEI[0]: NONE SW IMEI[1]: NONE SW IMEI[2]: NONE SW IMEI[3]: NONE SIMLOCK FLAG: OFF FIXED NV BASE: 30398000 Uncompressing; Done; Re-programming; FLS programmed; Done; Remove battery and cable; Log file saved to: LOG_22_04_2017_09_40_09.txt Time needed - 00:02:49 |
04-22-2017, 09:23 | #13669 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Mirpur Azad Kashmir Age: 34
Member: 1154111 Status: Offline Sonork: 100.1620855 Thanks Meter: 158 | ALCATEL ONE tOUCH 1016G UNLOCK DONE FURIOUS GOLD PACK 2 SPD Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (SCI USB2Serial) Preparing to sync; Port opened [COM44]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: 1016G-3AE8GB1 BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 355454-08-........-0 SW IMEI[1]: 352751-01,,,,,,,,,,-7 SW IMEI[2]: 358570-01-.........-3 SW IMEI[3]: 910575-60-1...........-8 SIMLOCK FLAG: ON FIXED NV BASE: 303C0000 Reading NV; NV saved to : NV_000000-00-000000-0_355454-08-2.......-0_65310001_22_04_2017_13_15_40.spd IMEI: 355454-08.........-0 UNLOCK CODE: 92342648 Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_22_04_2017_13_15_56.txt Time needed - 00:00:25 |
The Following User Says Thank You to kamranas For This Useful Post: |
04-22-2017, 16:22 | #13670 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | alcatel 5065n frp done Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem408.inf,%qcdownloaddiag%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM29 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 01470500331383-8 PTH: 03 PTS: N5S PROV_ID: 5065N-2CE4US1 SBTADDR: 28:BE:03:EB:17:93 SWIFIADDR: 28:BE:03:F5:EC:A5 HS_PN: SAA34NBAA10C SSN: 98KJ12CG1MZ007Y Work id: 0694C4AC Done; SECURITY: X8C0LS01BR20 Size: 000002A5 Backup saved to: 01470500331383-8 Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; Erase Setup Done; Erase Done; FRPEx Done; Log file saved to: LOG_22_04_2017_11_17_27.txt Time needed - 00:00:28 |
04-23-2017, 12:50 | #13671 (permalink) |
No Life Poster Join Date: May 2005 Location: Tirana Age: 43
Member: 143851 Status: Offline Thanks Meter: 159 | 5054x unlock ok 1,hold both vol + & vol - 2.Connect with pc usb 3.Open amdo ,select firehorse proper model 4.press unlock .done Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem301.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM45 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 35273007028768-1 PTH: 23 PTS: C8L PROV_ID: 5054X-2ATBAL3 SBTADDR: 18:E3:BC:3C:05:CC SWIFIADDR: 18:E3:BC:3C:05:CD HS_PN: SAA35H0AAS0C SSN: 4VKG11CCAPY008T Work id: 0351FC77 Done; Stype: 00000001 SECURITY: X8C0CA00BR10 Size: 000002B1 Backup saved to: 35273007028768-1 Backup file(s) removed; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_23_04_2017_13_47_25.txt Time needed - 00:00:28 |
04-24-2017, 06:18 | #13672 (permalink) |
Freak Poster Join Date: Apr 2006 Location: P A K I S T A N (RWP)
Member: 267787 Status: Offline Thanks Meter: 71 | Wiko Jerry unlocked 1.JPG 2.JPG Code: Searching phone; Phone detected (MediaTek PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on MediaTek USB VCOM (Android) (COM27); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6580, E01 Sw version: MOLY.WR8.W1449.MD.WG.MP.V57.P5 Hw Version: TINNO6580_WE_M_HSPA_HW Reading phone info; IMEI: 358656-07-379962-6 Reading simlock info; Locked to: 228-02 code_cat_n: 87654321 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:01:53 Log file saved to: LOG_23_04_2017_23_16_03.txt |
04-24-2017, 08:00 | #13673 (permalink) |
Freak Poster Join Date: Sep 2003 Location: The land of rape and honey Age: 46
Member: 40118 Status: Offline Thanks Meter: 97 | Yeeeeeeeeeeeeeeeeeeeehaaaaaaaaaa!!!! 3-months epic story with zero imei MHA-L29 (Mate 9) just finished!!!!! Thx for your job, FGteam! |
The Following User Says Thank You to domestik For This Useful Post: |
04-25-2017, 10:55 | #13674 (permalink) |
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | huawei s305 unlock Software engine version: 1.0.0.6556 Connect phone powered on ! Start auth ! SW Ver: E-UG-MTN-P108A28(S)V1.0.0B03 Imei: 357925038455934 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 E4 34 C4 91 88 00 87 03 Flash ID(0): 00C2:22C4 Saved: ZTE_357925038455934_E-UG-MTN-P108A28(S)V1.0.0B03_12.51.21_25.04.2017_PARTIAL.bi n Unlocked ! Remove battery and put back ! Time needed - 00:01:42 |
The Following User Says Thank You to ibrajinja For This Useful Post: |
04-25-2017, 15:31 | #13675 (permalink) |
Banned Join Date: Sep 2006
Member: 349359 Status: Offline Thanks Meter: 7 | alcatel 9020a unlock done by furious gold Software engine version: 1.0.0.10486 Searching phone ... MODEL : QCOM SERIES 41 COMPILED DATE : Aug 14 2015 13:44:00 RELEASE DATE : Jun 17 2015 22:00:00 FIRMWARE INFO : MPSS.DI.2.0.1.c1.27-00018-M8926DAAAANAZM-1 IMEI : 01431800269728-2 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; WORKING; SAVED: B706F738E75D7E24F346ED465C73C9A0.bin UNLOCK CODE: N/A DONE; DOING EXTRA CALCULATION; AFTER UNLOCK YOU MUST RESTART THE PHONE MANUALLY; SIM_LOCK REMOVED ! RESET ! Log file saved to: LOG_25_04_2017_14_13_10.txt Time needed - 00:00:21 |
04-25-2017, 16:52 | #13676 (permalink) |
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | ZTE v807 unlock pack 6 Searching phone; Phone detected (@oem5.inf,%vcom_preloader%;MediaTek PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on MediaTek USB VCOM (Android) (COM92); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6577 Sw version: MAUI.11AMD.W12.22.SP.V15 Hw Version: ZTENJ77_CU_JB_HW Reading phone info; IMEI: 869250-01-018131-2 Reading simlock info; Locked to: 641-22 code_cat_n: 12345678 enabled: no tries: 10 code_cat_ns: 56781234 enabled: no tries: 10 code_cat_sp: 11112222 enabled: no tries: 10 code_cat_c: 33334444 enabled: no tries: 10 code_cat_sim: 55556666 enabled: no tries: 10 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Unlocking SIM2 too. Time needed - 00:00:31 Log file saved to: LOG_25_04_2017_18_43_39.txt |
04-25-2017, 18:53 | #13677 (permalink) |
Junior Member Join Date: May 2008 Location: Germany
Member: 771798 Status: Offline Sonork: 100.1580.135 Thanks Meter: 27 | ZTE Blade A510 FRP Done ZTE Blade A510 FRP Done OTSmart Select ZTE Blad A452 Connect Phone Power Off Connecting; Downloading DA; Initializing; Rid: e0dc22e6d3b8ef43ade2df19ae998438 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM244; DEVICE INFO: BB CHIP: MT6735M_S00 [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x51000115 0x4D533237 0x49CF0042 0xE5936ACE [SIZE=0x1D2880000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x99000000 SIZE: 0x39880000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_25_04_2017_19_41_45.txt |
04-26-2017, 11:05 | #13678 (permalink) |
Member: 1215266 Status: Offline Thanks Meter: 129 | Alcatel ( 5020a ) and unlock arabic Using library Brom_DLL_v7.1413.5 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM96)) Preparing to start flash mode; Preparing to open COM96 Connecting; Downloading DA; Initializing; Rid: 8ad67797d280468571c8eab6b4a7bc04 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem105.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM34; DEVICE INFO: BB CHIP: MT6575_S01 [CB00, E201, 6575, FF] HW_STORAGE_EMMC: 0x484A0190 0x64314734 0xA3018604 0xA5A02499 [SIZE=0xE7600000] IMEI1 [OTP 0001]: 013511-00-796689-9 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5020A-2BVDAU1 USRDATA INFO: 0x4AF4C000 SIZE: 0x9C6B4000 Searching data; Locked to [SIM1]: 000-00 code_cat_n: 35697405 enabled: no tries: 10 code_cat_ns: 18733704 enabled: no tries: 10 code_cat_sp: 37334106 enabled: no tries: 10 code_cat_c: 30781463 enabled: no tries: 10 code_cat_sim: 20033380 enabled: no tries: 10 code_cat_ns_sp: 35562285 enabled: no tries: 5 code_cat_sim_c: 23890978 enabled: no tries: 5 Code reading finished; Remove battery and cable; Time needed - 00:00:04 Log file saved to: LOG_26_04_2017_03_02_41.txt |
The Following User Says Thank You to tornado779 For This Useful Post: |
04-26-2017, 12:37 | #13679 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: 6520_NF05_S03A_V03_M161114_MP Hw Version: SAGETEL76_1G512_11B_HW Reading phone info; IMEI: 356990-07-127714-1 Reading simlock info; Unlock codes: Locked to: 460-01 code_cat_n: 11112222 enabled: yes tries: 6 code_cat_ns: 56781234 enabled: no tries: 10 code_cat_sp: 11112222 enabled: no tries: 10 code_cat_c: 33334444 enabled: no tries: 10 code_cat_sim: 55556666 enabled: no tries: 10 code_cat_ns_sp: 77778888 enabled: no tries: 10 code_cat_sim_c: 99990000 enabled: no tries: 10 Time needed - 00:00:19 Log file saved to: LOG_26_04_2017_16_36_ |
The Following User Says Thank You to iftikhar_246 For This Useful Post: |
04-26-2017, 16:47 | #13680 (permalink) |
No Life Poster Join Date: Nov 2015 Location: DHAKA
Member: 2489690 Status: Offline Thanks Meter: 289 | huawei lua-u02 unlock done (insert the USB cable in the powered off phone) Phone detected (MediaTek PreLoader USB VCOM (Android)) Preparing to start MTK debug mode; Searching for debug port... (be sure drivers from support were installed!) MTK debug mode entered Baseband Chip: MT6582,S01 Sw version: Hw Version: ALPS.L1.MP12.V1.2_WT6582.WE.SH.L1_P6 Baseband Chip: MT6582, E01 Sw version: MOLY.WR8.W1449.MD.WG.MP.V32.P10 Hw Version: WT6582_WE_SH_L1_HSPA_HW Reading info... IMEI 1: 861080030777270 IMEI 2: N/A Open port success! 2017-04-26 08:39:58.124 Reading data from server... 2017-04-26 08:39:59.109 Reading data from server success! Reading simlock info; Gathering info; Simlock ok; SIM1 Locks cleared; Simlock ok; SIM1 Locks cleared; Simlock ok; SIM2 Locks cleared; Simlock ok; SIM2 Locks cleared; Simlock read end; THANKS FG TEAM UNLOCK DONE IN SECONDS |
