Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 06-18-2017, 13:38   #13771 (permalink)
kamranas's Avatar
Member: 1154111
Sonork: 100.1620855
Thanks Meter: 157
Alcatel 1054x unlock done furious gold pack 2 spd SERVICE TOOL
Searching phone;
For an successful connection do the following:
1. Remove battery and usb cable
2. Insert the usb cable in the phone
3. Keep pressed the boot key and insert the battery
Phone detected (SCI USB2Serial)
Preparing to sync;
Port opened [COM44];
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT
Chip type: 6531 FdlStat: 0001
Starting auth;
HW IMEI : 000000-00-000000-0
Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000
Reading phone info;
PHONE INFO: 1054X-3AVRGBD-1
BT ADDR: 6B:42:F9:03:BE:28
SW IMEI[0]: 358299-07-120807-4
SW IMEI[1]: 352751-01-952326-7
SW IMEI[2]: 358570-01-010389-3
SW IMEI[3]: 910575-60-140046-8
SIMLOCK FLAG: ON
FIXED NV BASE: 303B8000
Reading NV;
NV saved to : NV_000000-00-000000-0_358299-07-120807-4_65310001_18_06_2017_17_34_17.spd
IMEI: 358299-07-120807-4 UNLOCK CODE: 16710750 or 3582990716710750
Re-programming;
NV programmed;
Done;
Phone unlocked; Remove battery and cable;
Log file saved to: LOG_18_06_2017_17_34_36.txt
Time needed - 00:00:30
The Following User Says Thank You to kamranas For This Useful Post:
Old 06-19-2017, 09:51   #13772 (permalink)
Member: 233142
Sonork: 100.1595099
Thanks Meter: 451
Alcatel ot 4022d unlock done
Searching phone;
Phone detected (@oem340.inf,%vcom_preloader%;MediaTek PreLoader USB VCOM (Android))
Preparing to start meta mode;
Searching for debug port; (be sure drivers from support were installed)
Debug Port found on USB VCOM (Android) (COM28);
Preparing to connect meta mode;
Meta mode entered;
Baseband Chip:	MT6572, E01
Sw version:	MOLY.WR8.W1449.MD.WG.MP.V2.P5
Hw Version:	JRDHZ72_W_FF_HSPA_HW
Reading phone info;
IMEI:		358808-06-038649-1
Reading simlock info;
Locked to:	208-01
code_cat_n:	14157723 enabled:	yes	tries: 0
code_cat_ns:	07234950 enabled:	no	tries: 10
code_cat_sp:	07698100 enabled:	no	tries: 10
code_cat_c:	07798035 enabled:	no	tries: 10
code_cat_sim:	15937040 enabled:	no	tries: 10
code_cat_ns_sp:	53297761 enabled:	no	tries: 5
code_cat_sim_c:	86817778 enabled:	no	tries: 5
Unlocking SIM2 too.
Time needed - 00:01:45
Log file saved to: LOG_19_06_2017_11_48_25.txt
Old 06-21-2017, 19:12   #13773 (permalink)
anis_rainbow's Avatar
Member: 597569
Sonork: 100.1593870
Thanks Meter: 265
OT-4007D permanent lock unlock done
OT-4007D permanent lock unlock done by FuriousGold
Searching phone;
Phone detected (@oem5.inf,%vcom_preloader%;MediaTek PreLoader USB VCOM (Android))
Debug Port found on Android Gadget VCOM Driver (COM5);
Meta mode entered;
Baseband Chip: MT6575
Sw version: MAUI.11AMD.W11.50.SP.V31.P2
Hw Version: JRDHZ75_PIXO_GB2_HW
Reading phone info;
IMEI: 863580-02-015190-5
Locked to: 000-00
code_cat_n: 05940908 enabled: no tries: 10
code_cat_ns: 25505088 enabled: no tries: 10
code_cat_sp: 06907256 enabled: no tries: 10
code_cat_c: 10876501 enabled: no tries: 10
code_cat_sim: 21603581 enabled: no tries: 10
Time needed - 00:00:38
The Following User Says Thank You to anis_rainbow For This Useful Post:
Old 06-21-2017, 21:17   #13774 (permalink)
Member: 2382052
Thanks Meter: 1,499
Alcatel 5056w unlock done
Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ;
Phone detected (@oem84.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008)
Preparing to start flash mode;
Preparing to open COM63
Connecting;
Loading;
Init;
Port opened;
Hello Received;
BOOT Loaded;
Getting config;
Getting mem info;
Found an eMMC memory 22CD
IMEI: 01474900012364-2
PTH: 08
PTS: B6N
PROV_ID: 5056W-2AWFUS7-R
SBTADDR: 24:0D:C2:2D:A81
SWIFIADDR: 24:0D:C2:2D:F6:9F
HS_PN: SAA1F5BWA10C
SSN: N6KB10CGTMZ02DU
Bruteforcing data; This operation can take up to 30 minutes !!!
Done;
Work id: 02E168CD
Done;
Stype: 00000001
SECURITY: XUB0UW03BR10 Size: 000002B7
Backup saved to: 01474900012364-2
Unlocking;
SIM_LOCK REMOVED !
Log file saved to: LOG_21_06_2017_16_10_57.txt
Time needed - 00:12:48
Old 06-22-2017, 09:21   #13775 (permalink)
Member: 2453225
Sonork: l
Thanks Meter: 29
huawei y560 frp
huawei y560 frp ok!!!!
2017.06.22. 10:15:14
FlyCaptain Huawei Module v2.0.0.0154 Furious Gold Pack 7
Dongle S/N: 73D51A44
Before detection connect cable to usb and enable Manufacture mode !
Qualcomm and HiSilicon: *#*#2846579#*#*
MTK: *#*#14789632#*#*
Windows: ##2846579#
ProjectMenu
1.Background setting
2.USB ports setting
Select Manufacture mode (for MTK other/debug mode)
2017-06-22 10:15:16.306 Start read phone info!
2017-06-22 10:15:16.454 Detect phone done!
Model: msm8909
Firmware ver.: Y560-L01V100R001C577B047
SN: Q6VBBBB5C2962519
Root State: UNROOT
Battery state: 4199mv
2017-06-22 10:15:21.568 Erase FRP start
2017-06-22 10:15:25.192 Reading phone info...
2017-06-22 10:15:25.266 Read phone info success!
Model: msm8909
2017-06-22 10:15:25.303 Reading data from server...
2017-06-22 10:15:25.621 Reading data from server success!
2017-06-22 10:15:25.624 Erasing FRP...
2017-06-22 10:15:25.881 Erase FRP done!
The Following User Says Thank You to hulk1978 For This Useful Post:
Old 06-22-2017, 17:01   #13776 (permalink)
Member: 6142
Thanks Meter: 47
Wink New security LUA-L01 succesfull unlock
All other tool failed!
Searching phone...
(insert the USB cable in the powered off phone)
Phone detected (MediaTek PreLoader USB VCOM (Android))
Preparing to start MTK debug mode;
Searching for debug port... (be sure drivers from support were installed!)
MTK debug mode entered
Baseband Chip: MT6735M,S01
Sw version:
Hw Version: ALPS.L1.MP3.V2.95_OT6735M.35GU.L1_P69
Baseband Chip: MT6735, E00
Sw version: MOLY.LR9.W1444.MD.LWTG.MP.V48.P16.T2
Hw Version: OT6735_65C_L1_HW
Reading info...
IMEI 1: 8616870327xxxxxx
IMEI 2: N/A
Open port success!
2017-06-22 17:58:58.563 Reading data from server...
2017-06-22 17:58:59.063 Reading data from server success!
Gathering info;
SIM UNLOCK CODE: 82886028
Simlock read end;
Thx furi
The Following User Says Thank You to roniri For This Useful Post:
Old 06-22-2017, 22:57   #13777 (permalink)
Member: 2382052
Thanks Meter: 1,499
ALCATEL 2004C UNLOCK DONE
Using library Brom_DLL_v5.1316.1
Searching phone;
(for some models keep SPACE or * (STAR) key pressed before inserting the cable)
Phone detected (MediaTek USB Port (COM18))
Requesting authorization;
Done;
Meta mode entered;
Baseband Chip: MT6260
Sw version: MAUI.11B.W13.08.MP.V4.F54
Hw Version: JRDHZ60A_11B_HW
Reading phone info;
IMEI: 014659-00-184191-2
Reading security;
Done;
Checking;
Preparing;
Writing security;
Time needed - 00:00:20
Log file saved to: LOG_22_06_2017_17_43_31.txt
Old 06-23-2017, 08:43   #13778 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
Alcatel 4013x unlocked done
Using library Brom_DLL_v7.1522.2
Searching phone in normal mode;
[connect the phone powered off to the usb cable]
Phone detected (MediaTek PreLoader USB VCOM (Android) (COM25))
Preparing to open COM25
Connecting;
Downloading DA;
Initializing;
Rid: 3844469506c6df86d6ad99dcf1760318
Requesting baudrate change;
Done;
USB SPEED: USB_HIGH_SPEED
Switching to DA_HIGHSPEED_VCOM;
Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86;
If the detection fails, install manually the port from the device manager using usbvcom.inf;
DA_HIGHSPEED_VCOM (MediaTek DA USB VCOM (Android))
TRYING TO OPEN COM42;
DEVICE INFO:
BB CHIP: MT6572_S00 [CA00, 00, 6572, FF]
HW_STORAGE_EMMC: 0x46000115 0x4135324A 0x84000242 0x35C2CA90  [SIZE=0xE9880000]
IMEI1 [OTP 0001]: 356257-06-9xxxxx-x
IMEI2 [OTP 0001]: 000000-00-000000-0
PROVIDER: 4013X-2ARGRO1
USRDATA INFO: 0x6E380000 SIZE: 0x7B500000
Searching data;
Locked to [SIM1]:    226-10
code_cat_n:    3892327907521997 enabled:    yes    tries: 10
code_cat_ns:    0779159091977695 enabled:    no    tries: 10
code_cat_sp:    5195622327768620 enabled:    no    tries: 10
code_cat_c:    4985783880121361 enabled:    no    tries: 10
code_cat_sim:    0478230696949170 enabled:    no    tries: 10
code_cat_ns_sp:    0478230696949170 enabled:    no    tries: 5
code_cat_sim_c:    0478230696949170 enabled:    no    tries: 5
Time needed - 00:00:08
Old 06-23-2017, 08:44   #13779 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
vodafone 300 unlocked done
Connecting;
Downloading DA;
Initializing;
Rid: e1a62ef619ae4fbeb72b508f4b2ecb67
Done;
DEVICE INFO:
BB CHIP: MT6580_S00 [CA00, 00, 6580, FF]
HW_STORAGE_EMMC: 0x30000111 0x45473430 0xCD150030 0x5153A823  [SIZE=0xEC480000]
IMEI1 [OTP 0000]: 000000-00-000000-0
IMEI2 [OTP 0000]: 000000-00-000000-0
PROVIDER: V300-2AVDRO1
USRDATA INFO: 0x47000000 SIZE: 0x60000000
Searching data;
Locked to [SIM1]:    226-01
code_cat_n:    1113531683220808 enabled:    yes    tries: 10
code_cat_ns:    0089550815023381 enabled:    no    tries: 10
code_cat_sp:    4952391196892074 enabled:    no    tries: 10
code_cat_c:    2327674908451254 enabled:    no    tries: 10
code_cat_sim:    9409919598990412 enabled:    no    tries: 10
code_cat_ns_sp:    8391823918787605 enabled:    no    tries: 5
code_cat_sim_c:    8313251747747286 enabled:    no    tries: 5
Time needed - 00:00:13
Old 06-23-2017, 08:46   #13780 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
Vodafone 975 successfully unlocked
Searching phone;
Debug Port found on Android Gadget VCOM Driver (COM246);
Meta mode entered;
Sw version:    MAUI.11AMDW1222SP.V15.F5.P9.T1
Hw Version:    JRDSH75_CU_JB_HW
Reading phone info;
IMEI:        869531-01-xxxxxx-x
NOTE: Most of the times one of the first variants will work !
MODEL: OT-V975
UNLOCK CODE: 4 2 1 2 4 9 1 0
MODEL: OT-V975
UNLOCK CODE: 3 7 6 1 8 0 4 6
MODEL: OT-V975
UNLOCK CODE: 3 7 0 7 8 6 3 6
Time needed - 00:02:40
Old 06-23-2017, 08:47   #13781 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
VDF 500 unlocked
Connecting;
Downloading DA;
Initializing;
Rid: 876323831faf95ae27aba21168524d0c
Done;
DEVICE INFO:
BB CHIP: MT6735M_S00 [CA00, 00, 335, FF]
HW_STORAGE_EMMC: 0x30000111 0x37473830 0xBFEB0030 0x67A31124  [SIZE=0x1D2C00000]
PROVIDER: V500-2BVDRO1
USRDATA INFO: 0x84000000 SIZE: 0x4EC00000
Searching data;
code_cat_n:    1113531683220808 enabled:    yes    tries: 5
Time needed - 00:00:10
Old 06-23-2017, 08:48   #13782 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
Alcatel 2001x unlocked done
Searching phone;
Phone detected (MediaTek USB Port (COM35))
Done;
Meta mode entered;
Baseband Chip:    MT6250
Sw version:    MAUI.11B.W12.24.MP.V2.F42
Hw Version:    JRDHZ50_12864_11B_24MP_HW
Reading phone info;
IMEI:        861292-02-8xxxxx-x
Reading security;
Done;
Checking;
Preparing;
Writing security;
Time needed - 00:00:12
Old 06-23-2017, 08:52   #13783 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
P8 lite unlocked done
ProjectMenu
2.USB ports setting
 Autodetect started!
 Found COM port: COM204
Open port COM204 (Android Adapter PCUI (COM204))...
 Connecting to server...
 Connected!
 Read data from server...
 Read data from server success!
 Phone authorize start
 Phone authorize success!
 Read secure info...
 Read secure info success!
 Read basic info...
 Read basic info success!
 Unlocking start
 Phone secure identify start
 Phone secure identify success
 Unlock done!
 Job finished!
Old 06-23-2017, 08:54   #13784 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
Huawei y530 unlocked done
Connecting;
Check your phone and "Always allow from this computer" and select "OK".
Connected;
BRAND: HUAWEI
MODEL: HUAWEI Y530-U00
ANDROID: v4.3
CPU: QCOM
IMEI: 868909020xxxxxx
KERNEL: Linux version 3.4.0+ ([email protected]) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Mon Aug 11 18:52:35 IST 2014
Cleaning;
Loading files;
Done;
Reconnecting;
Setting access;
Done;
Exploiting;
Android v4.3 TRUE
Backing up sec area;
Done;
Getting sec size;
00166595 bytes
Decompressing;
Backup saved to: 8689090208xxxxx
Finished;
IMEI: 8689090208xxxxx
BT ADDR: 24:00:BA:54:2E:64
MAC ADDR: 24:00:BA:54:25:03
BOOTLOADER PASS: 3915486165471915
MCC-MNC: 226-10 [orange/ro]
LOCK [0] HASH: 36F427320513182EE952718FA4325204
LOCK [1] HASH: 1C4703AD9A746AD39BD2B871FD769487
LOCK [2] HASH: 091FCD4C58F78206B956A521F47023A2
LOCK [3] HASH: E2F2652CB8D81AA70CAD0FE09DD363B2
LOCK [4] HASH: E2F2652CB8D81AA70CAD0FE09DD363B2
LOCK [5] HASH: FAC6221097A8F479BA926D86116D4432
LOCK [6] HASH: 44BAA3993AA1DC3B20195D9A731A460E
LOCK [7] HASH: E2F2652CB8D81AA70CAD0FE09DD363B2
LOCK [8] HASH: E2F2652CB8D81AA70CAD0FE09DD363B2
LOCK [9] HASH: E2F2652CB8D81AA70CAD0FE09DD363B2
Starting;
Done;
Unlocking in progress;
Calc 0000 ;
Calc 0001 ;
SIM_LOCK REMOVED !
Rebooting;
Time needed - 00:01:10
Old 06-23-2017, 18:49   #13785 (permalink)
Rui Romano's Avatar
Member: 1919025
Sonork: 100.1657804
Thanks Meter: 405
Huawei CUN-L01 FRP Removal
Huawei Y5 II CUN-L01 4G LTE FRP Removal
Searching phone...
Baseband Chip: MT6735,S01
Sw version:
Hw Version: CUN-L01C704B138
Sw version: MOLY.LR9.W1444.MD.LWTG.MP.V42.P40.T3
Hw Version: HQ6753_65C_B1N_L1_HW
Reading info...
IMEI 1: 869785022170357
IMEI 2: N/A
Open port success!
2017-06-22 20:04:33.136 Reading data from server...
2017-06-22 20:04:33.700 Reading data from server success!
Gathering info;
Simlock ok;
SIM1 Locks cleared;
Simlock ok;
SIM1 Locks cleared;
Simlock ok;
SIM2 Locks cleared;
Simlock ok;
SIM2 Locks cleared;
Simlock read end;
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.31294 seconds with 9 queries
