04-08-2018, 17:31 | #14521 (permalink) |
Freak Poster Join Date: Feb 2016
Member: 2526882 Status: Offline Thanks Meter: 9 | coolpad 3622A unlock done by furiousgold Check your phone and "Always allow from this computer" and select "OK". Connected; BRAND: COOLPAD MODEL: COOLPAD 3622A ANDROID: v5.1.1 CPU: QCOM IMEI: NA KERNEL: Linux version 3.10.49-g3523c12-00138-gcfd4736 (mine@ubuntu) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Fri Mar 31 14:58:32 CST 2017 Cleaning; Setting usb config; Done; Reconnecting; Looking for the interface; Port found [Qualcomm Diagnostics Interface 3197 (COM31)] Backing up sensitive data; connect_server: OK; backup in progress: OK; Backup saved to: C:\Users\ssitmih\AppData\Local\Temp\Rar$EXa4804.31 959\ADB\ Done; Done; Done; Restarting the phone; Setting usb config; Done; Reconnecting; Looking for the interface; Port found [Qualcomm Diagnostics Interface 3197 (COM31)] Restoring sensitive data; connect_server: OK; restore in progress: OK; Done; SIM_LOCK REMOVED ! POWER OFF / ON THE PHONE MANUALLY TO COMPLETE THE UNLOCK ! Log file saved to: LOG_8_04_2018_08_47_18.txt Time needed - 00:05:34 |
04-08-2018, 23:04 | #14522 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | Stylo_S551 Read Firmware & FRP Reset Done Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM107)) Preparing to start flash mode; Preparing to open COM107 Connecting; Downloading DA; Initializing; Rid: 5f76d35baaf4c94b1cca58ae113fc014 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem160.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM15; DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, 05] HW_STORAGE_EMMC: 0x46000115 0x4D32584E 0xCA680142 0x5B24E5DC [SIZE=0x1D2880000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xCA000000 SIZE: 0x106F80000 Getting partitions info; Reading info; Partitions info: [0x00080000-0x00300000]-[proinfo] [0x00380000-0x00500000]-[nvram] [0x00880000-0x00A00000]-[protect1] [0x01280000-0x00A00000]-[protect2] [0x01C80000-0x00040000]-[seccfg] [0x01CC0000-0x00060000]-[lk] [0x01D20000-0x01000000]-[boot] [0x02D20000-0x01000000]-[recovery] [0x03D20000-0x00080000]-[para] [0x03DA0000-0x00800000]-[logo] [0x045A0000-0x00A00000]-[expdb] [0x04FA0000-0x00100000]-[frp] [0x050A0000-0x00500000]-[tee1] [0x055A0000-0x00500000]-[tee2] [0x05AA0000-0x02000000]-[nvdata] [0x07AA0000-0x02560000]-[metadata] [0x0A000000-0x00200000]-[oemkeystore] [0x0A200000-0x00600000]-[secro] [0x0A800000-0x00800000]-[keystore] [0x0B000000-0xAF000000]-[system] [0xBA000000-0x10000000]-[cache] [0xCA000000-0x106F80000]-[userdata] [0x1D0F80000-0x01000000]-[flashinfo] Reading full dump; Contents saved to : C:\Users\Dream\Desktop\MEMORY_DUMP_Stylo_S551_5f76 d35baaf4c94b1cca58ae113fc014.osp Time needed - 01:28:00 Log file saved to: LOG_6_04_2018_11_32_05.txt Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM107)) Preparing to start flash mode; Preparing to open COM107 Connecting; Downloading DA; Initializing; Rid: 5f76d35baaf4c94b1cca58ae113fc014 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem160.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM15; DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, 05] HW_STORAGE_EMMC: 0x46000115 0x4D32584E 0xCA680142 0x5B24E5DC [SIZE=0x1D2880000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xCA000000 SIZE: 0x106F80000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_6_04_2018_09_38_25.txt |
04-09-2018, 10:09 | #14523 (permalink) |
No Life Poster Join Date: Nov 2006 Location: colombo
Member: 399781 Status: Offline Thanks Meter: 94 | y560-l01 frp 2018-04-09 14:34:15.077 Erase FRP start 2018-04-09 14:34:18.790 Reading phone info... 2018-04-09 14:34:19.383 Read phone info success! Model: msm8909 Firmware ver.: Y560-L01V100R001C600B103 SN: Q6VBBBB5C0306280 2018-04-09 14:34:19.632 Read from server... 2018-04-09 14:34:19.960 Read from server success! 2018-04-09 14:34:19.976 Erasing FRP... 2018-04-09 14:34:21.006 Erase FRP done! |
04-10-2018, 00:03 | #14524 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ALTICE S20 UNLOCK DONE Searching phone; Phone detected (@oem70.inf,%vcom_preloader%;PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on PreLoader USB VCOM (Android) (COM231); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6580, E01 Sw version: MOLY.WR8.W1449.MD.WG.MP.V91.5.P16 Hw Version: SR6580_WE_N_HSPA_HW Reading phone info; IMEI: 358109-08-088112-8 Reading simlock info; Locked to: 460-01 code_cat_n: 12345678 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:00:47 Log file saved to: LOG_9_04_2018_18_58_44.txt |
04-10-2018, 10:02 | #14525 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Portugal Age: 43
Member: 7557 Status: Offline Thanks Meter: 26 | Altice starnaute 4 Unlock done pack 6 MTK CODE READER Searching phone; Phone detected (@oem263.inf,%vcom_preloader%;MediaTek PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on MediaTek USB VCOM (Android) (COM200); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6580, E01 Sw version: MOLY.WR8.W1449.MD.WG.MP.V91.5.P5 Hw Version: SR6580_WE_N_HSPA_HW Reading phone info; IMEI: 358109-08-003944-6 Reading simlock info; Locked to: C1C-1C code_cat_n: 12345678 enabled: no tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:00:56 Log file saved to: LOG_10_04_2018_09_56_28.txt |
04-10-2018, 16:43 | #14526 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | ANOTHER CONEXIS X1 NETWORK UNLOCK SUCCESSFULLY DONE Software engine version: 1.0.0.10622 Searching phone ... MODEL : QCOM SERIES 48 COMPILED DATE : Nov 2 2016 12:31:00 RELEASE DATE : Sep 2 2016 08:00:00 FIRMWARE INFO : MPSS.JO.1.2.c3-00131-8909_GEN_PACK-1 IMEI : 862XXXXXXXXXX BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: FNB_ZA_P809F52V1.0.0B10 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: E:\furious box\pack 5\QCOM_SMART_TOOL_v1.0.0.10622_Z_Edition\862XXXXXX XXX_10_04_2018_17_39_00.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM480 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD Looking for the interface; Port found [ZTE Handset Diagnostic Interface (COM55)] connect_server: OK; restore in progress: OK; SIM_LOCK REMOVED ! Log file saved to: LOG_10_04_2018_17_41_35.txt Time needed - 00:02:38 |
04-10-2018, 20:33 | #14527 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | MobiWire Atohi unlock done MobiWire Atohi unlock done Use MTKReader_v1.0.0.629..... Press 0 and insert usb cable..... Searching phone; Phone detected (@oem26.inf,%vcom_bootrom%;MediaTek USB Port) Preparing to start meta mode; COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: V03_20160615_ATOHI_SWISSCOM_NL02_MP Hw Version: SELECTIONB1_1G512_11B_HW Reading phone info; IMEI: 353535-07-046703-8 Reading simlock info; Unlock codes: Locked to: 460-01 code_cat_n: 12345678 enabled: yes tries: 0 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:00:21 Log file saved to: LOG_7_04_2018_14_13_31.txt |
04-10-2018, 22:59 | #14528 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Dominican Republic
Member: 469532 Status: Offline Sonork: TG: CodebUnlocks Thanks Meter: 868 | Alcatel 5049Z unlock done! Code: Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MediaTek USB Port (COM12)) Preparing to start flash mode; Preparing to open COM12 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 2cccc096e9f1653fab20be6849e9fa4e Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem92.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM33; DEVICE INFO: BB CHIP: MT6738 [CB00, 01, 6738, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0xE8480742 0x85B48FDA [SIZE=0x748800000] IMEI1 [OTP 0001]: 014940-00-XXXXXX-6 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5049Z-2AE4US1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:17:08 Checking data integrity; Data integrity: OK; SIM_LOCK: ENABLED Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:17:27 Log file saved to: LOG_10_04_2018_17_27_49.txt |
04-11-2018, 14:18 | #14529 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | alcatel 5042a unlock done Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem207.inf,%qcdownloaddiag%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM11 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D4 size 7.3 GB IMEI: 01415200393598-1 PTH: 05 PTS: CTQ PROV_ID: 5042A-2DAVDO3 SBTADDR: 8C:99:E6:89:58:0B SWIFIADDR: 8C:99:E6:89:58:0C HS_PN: SAA6157AB10C SSN: NMJC31BE9MY01VH Work id: 11529CC1 Setup 1; Done; Setup 2; Done; Setup 3; Done; Uploading; Done; SECURITY: X2CTNKQ1BG00 Size: 00000430 Backup saved to: 01415200393598-1 Checking the simlock; Magic ok; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_11_04_2018_09_17_23.txt Time needed - 00:00:39 |
04-11-2018, 19:46 | #14530 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Abidjan,ivory coast
Member: 1272267 Status: Offline Sonork: 100.1667652 Thanks Meter: 408 | Orange Dive 71 Unlock Done By FuriousGold Software engine version: 1.0.0.10659 Searching phone ... MODEL : QCOM SERIES 48 COMPILED DATE : Jul 4 2016 03:36:00 RELEASE DATE : May 10 2016 23:00:00 FIRMWARE INFO : MPSS.JO.1.2.c3-00055-8909_GEN_PACK-1 IMEI : 86113103051580-4 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: CI_OR_P809F52V1.0.0B13 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: C:\Users\Debloc Pro Gsm\Downloads\Compressed\QCOM_SMART_TOOL_v1.0.0.10 659\86113103051580_11_04_2018_20_07_47.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM5 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD Looking for the interface; Port found [ZTE Handset Diagnostic Interface(DFU) (COM4)] connect_server: OK; restore in progress: OK; SIM_LOCK REMOVED ! Log file saved to: LOG_11_04_2018_20_11_33.txt Time needed - 00:03:50 DRIVER : https://www.4shared.com/rar/SvHthSse...71_Driver.html |
04-13-2018, 14:25 | #14531 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | ALCATEL OT-5044R REMOVE FRP DONE Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem88.inf,%qcdownloaddiag%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM84 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD size 7.3 GB IMEI: 01482700313390-7 PTH: 04 PTS: Y5Y PROV_ID: 5044R-2AAQUS1-R1 SBTADDR: D4:285:5C:B7:46 SWIFIADDR: D4:285:0FA:97 HS_PN: SAA1HQ0WA10C SSN: TCKC06CN8MA01F9 Work id: 22021984 Done; Stype: 00000001 SECURITY: X8C0LS01BR20 Size: 000002A5 Backup saved to: 01482700313390-7 Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; Erase Setup Done; Erase Done; Erase Done; FRPEx Done; Log file saved to: LOG_13_04_2018_09_22_13.txt Time needed - 00:00:22 |
04-14-2018, 13:22 | #14532 (permalink) |
No Life Poster Join Date: Jun 2007 Location: colmar
Member: 527800 Status: Offline Thanks Meter: 234 | Haier L52 FRP remooved chosen Vonino xavy t7 OTSmart pack 6 Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM19)) Preparing to start flash mode; Preparing to open COM19 Connecting; Downloading DA; Initializing; Rid: d9ecac0af34807cf7399f19834cf189b Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem70.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM20; DEVICE INFO: BB CHIP: MT6735M_S00 [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x56000170 0x30303031 0xE5075038 0x03334E25 [SIZE=0x1C3C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xA1000000 SIZE: 0x120F80000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_14_04_2018_14_12_26.txt |
04-14-2018, 13:55 | #14533 (permalink) |
Member: 1444462 Status: Offline Thanks Meter: 1,337 | Mobicel R1 Read & Write Flash Successfully By FG Box, World 1'st ;) Really it's Amazing Writing Logs: Code: Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM14)) Preparing to start flash mode; Preparing to open COM14 Connecting; Downloading DA; Initializing; Rid: 5a49777fb878b971b50819d2be6bfb03 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x484A0190 0x61344738 0xE136A532 0x19C455BE [SIZE=0x1D2C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xDA800000 SIZE: 0xF6780000 Preparing to write FULL_DUMP_PART0; Writing FULL_DUMP_PART0; Preparing to write FULL_DUMP_PART1; Writing FULL_DUMP_PART1; Preparing to write FULL_DUMP_PART2; Writing FULL_DUMP_PART2; Preparing to write FULL_DUMP_PART3; Writing FULL_DUMP_PART3; Preparing to write FULL_DUMP_PART4; Writing FULL_DUMP_PART4; Preparing to write FULL_DUMP_PART5; Writing FULL_DUMP_PART5; Preparing to write FULL_DUMP_PART6; Writing FULL_DUMP_PART6; Preparing to write FULL_DUMP_PART7; Writing FULL_DUMP_PART7; Preparing to write FULL_DUMP_PART8; Writing FULL_DUMP_PART8; Success; Time needed - 00:09:22 Log file saved to: LOG_14_04_2018_14_27_01.txt |
The Following User Says Thank You to ..::GMSR::.. For This Useful Post: |
04-16-2018, 14:04 | #14534 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@usb.inf,%usb\composite.devicedesc%;Dispositivo compuesto USB) Preparing to enter download mode; Preparing to open COM173 Connecting; Init; Port opened; Phone detected (@oem13.inf,%qcomserialportdesc90080%;Android HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM36 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD size 7,3 GB IMEI: 01469xxxxxxxxx-4 PTH: 04 PTS: M5K PROV_ID: 4060A-2AAQUS3-R1 SBTADDR: 20:A9:0E:87:64:5A SWIFIADDR: 20:A9:0E:95:8C:4A HS_PN: SAA1GY0WA10C SSN: 48KB05BPGJZ000Q Work id: 038C175F Done; Stype: 00000001 SECURITY: X8C0LS01BR20 Size: 000002A5 Backup saved to: 01469xxxxxxxxx-4 Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; Erase Setup Done; Erase Done; FRPEx Done; Log file saved to: LOG_16_04_2018_09_01_30.txt Time needed - 00:00:28 |
04-17-2018, 12:13 | #14535 (permalink) |
Freak Poster Join Date: Nov 2017
Member: 2775355 Status: Offline Thanks Meter: 177 | TECNO K8 Frp successfully removed Time needed - 00:00:00 by Furious Gold Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM24)) Preparing to start flash mode; Preparing to open COM24 Connecting; Downloading DA; Initializing; Rid: 6f7cab63efe743d105f5558e67a19032 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6737M [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x46000115 0x4D323645 0x51030342 0x03A49ECC [SIZE=0x3A4A00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x124000000 SIZE: 0x27ED80000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 |
