01-07-2011, 17:01 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508100 Status: Offline Sonork: 1600934 Thanks Meter: 189 | toshiba tg01 dead. i tried to unlock toshiba.. after putting it on other mode as shows in manual everything went ok.. it shows the unlocking code also.... but now it always stays in that mode i cant turn on the phone.. i hv done everything.. its just blank showing semi lighted... plsss furious team what to do|? |
01-07-2011, 17:06 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,569 | Quote:
Br | |
01-07-2011, 17:12 | #3 (permalink) |
Member: 508100 Status: Offline Sonork: 1600934 Thanks Meter: 189 | i did everything its just stuck on that mode tried to hard reset it by pressing vol up camera and power on aswel it just dont do anything pls advice wt to do? |
01-07-2011, 17:19 | #4 (permalink) | |
Br | |
01-07-2011, 23:21 | #5 (permalink) |
Member: 508100 Status: Offline Sonork: 1600934 Thanks Meter: 189 | thanx its done... it was bit complicated but all is well if end is well.. i think the reason was that the phone went dead is when you point those two tips under black plastic (near sim reader)sometimes it goes on download mode instead of blank semi lighted as shown on manual.. if it goes on download mode let it finish dont remove bettery or do anything else....otherwise phone dead ok this is procedure if sombody needs help... TG software TGTool 1.3 TG Downloader TG drivers TG have to be DISCONNECTED from PC!!!! 1. You need to be sure you have charged battery. Use fried TG or some external charging solution. 2. Install TG Downloader Before you will install application be sure that TG is NOT CONNECTED to PC. Install Downloader and click next. Application should install TG01W drivers. 3. Prepare bin file. tgtool -dec TG01WP_5005000176.tsw tg01.bin 3. Open Downloader as adimi (Vista) 4. Click on Browse and select tg01.bin. App will inform you about problem with version but accept. Now connect your TG with charged battery to PC. Windows should start install drivers and new device Toshiba DL and some ports. After installatin click "Change Port" at Downloader and choose "Toshiba Download Port" and click "Download Mode". App will inform "Faild to open port" click OK and click "Downloade Mode" again. On status bar app will inform Done and LED on TG will start to be white. Click on "Start Download" and go to make small coffe. TG's LED will start to blink on many colours and its correct. Wait till appp restart your TG. And you loved device is working again. Have nice day |
The Following User Says Thank You to 00aa For This Useful Post: |
01-27-2011, 13:33 | #6 (permalink) | |
No Life Poster Join Date: Apr 2010 Location: U.K. / INDIA
Member: 1283682 Status: Offline Thanks Meter: 304 | Quote:
01-28-2011, 10:48 | #7 (permalink) |
Member: 508100 Status: Offline Sonork: 1600934 Thanks Meter: 189 | Remove plastic use that points how it shows in picture if the phone gets semi lighted unlock phone... If it goes on download mode wait until it fineshes it self donot remove battery.. |
Repaired dead phone without backup | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-29-2011 11:26 |
help! Dead 5110 v5.30 | aklishin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-04-2001 11:56 |
nokia 5110 dead | alpha | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2001 11:59 |
Is it possible to use the Nokia 6150 with the IR Port of a Toshiba Laptop? | telefonman | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-13-2000 20:06 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
