11-18-2020, 22:36 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Chile
Member: 1797183 Status: Offline Thanks Meter: 148 | GPT Restore failed, LG K40S imei repair fail.. Code: Starting Re-init operation; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; ERROR: laf_cmd_kilo_proc - LAF_ERROR_ACCESS_DENIED ! Erase failed; Re-init operation completed; GPT Restore failed; Setting secure mode; ERROR: laf_cmd_protection - LAF_ERROR_ACCESS_DENIED ! LOG: Code: Using library Brom_DLL_v7.1813.3 Searching phone in emergency mode; [connect the phone in "Firmware Update" Mode. Hold the Volume Up on the powered off phone and enter the USB cable in order to enter it] Phone detected (USB\VID_1004&PID_6000&REV_0409) Preparing to start flash mode; Preparing to open COM13 Opened; Authorising; Authorized; LAF_ERROR_ACCESS_DENIED download_cable = 910K battery_level = 33 download_type = download_speed = 0 usb_version = UHS hardware_revision = rev_10 download_sw_version = device_sw_version = X430HM10n secure_device = S laf_sw_version = 1.1 device_factory_version = LMX430HMAT-00-V10b-SCA-XXX-DEC-04-2019+0 device_factory_out_version = LMX430HMAT-00-V10b-SCA-XXX-DEC-04-2019+0 pid = 01HEB622F8DR02R21 imei = 358942101573161 model_name = LM-X430HM device_build_type = U chipset_platform = mt6765 target_operator = LAO target_country = COM ap_factory_reset_status = 6 cp_factory_reset_status = 0 isDownloadNotFinish = 0 qem = 0 cupss_swfv = A1575500410-M1575500410-FFFFFFFFFFF-U1575507576-0 is_one_binary_dual_plan = 0 memory_size = 61071360 memory_id = hB8aP> bootloader_ver = MiniOS 3.0 islan_download = 0 skip_readwrite = 0 Starting; Setting secure mode; Done; Linux localhost 4.9.117 #1 SMP PREEMPT Wed Dec 4 20:06:25 -03 2019 armv7l Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Getting security info; Setting secure mode; Done; Reading security; Done; Checking security; Phone it's going restart several times during this step; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Done; Contents saved to : C:\Users\old_i\Desktop\Archivos\FuriousGold\OTSmart_v1.0.0.5011_SEC_Edition\SEC_BKP_LG K40S_358942101573161.osp Working; Connecting to server; Authorisation process started; Done; Requesting data from server ! Wait please ... Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; IMEI A: 358942-10-157316-1 IMEI B: 350305-26-000000-1 IMEI C: 350305-26-000000-1 WiFi ADDR: 7C:F3:1B:F0:DE:E2 BT ADDR: 7C:F3:1B:84:C3:BF LOCK STATUS: 0 0 0 0 Done; Working; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; IMEI1 repaired; Starting Re-init operation; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; ERROR: laf_cmd_kilo_proc - LAF_ERROR_ACCESS_DENIED ! Erase failed; Re-init operation completed; GPT Restore failed; Setting secure mode; ERROR: laf_cmd_protection - LAF_ERROR_ACCESS_DENIED ! Time needed - 00:05:56 box id 099AF677 https://drive.google.com/file/d/1IRv...ew?usp=sharing https://drive.google.com/file/d/1E9G...ew?usp=sharing |
11-18-2020, 23:29 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | GPT Restore failed, LG K40S imei repair fail.. Quote:
Refunded. You must keep the volume uo pressed all the time and repeat the operation. Be sure you use v5011 Sent from my iPhone using Tapatalk Pro | |
