05-22-2008, 17:04 | #1 (permalink) |
Freak Poster Join Date: Apr 2004
Member: 63172 Status: Offline Thanks Meter: 22 | key file |
05-22-2008, 19:07 | #2 (permalink) |
Member: 63172 Status: Offline Thanks Meter: 22 | Just to clarify, the software tells me that it has generated the key file - I just can't find it! Also still says license not found for just a few of the modules (eg U880) - other models work fine.. Any help appreciated, thanks. |
05-23-2008, 02:01 | #3 (permalink) |
Product Manager Join Date: May 2001 Location: Los Angeles
Member: 4584 Status: Offline Sonork: 100.69564 Thanks Meter: 15,093 | Key file is generated in same folder you start maintainance exe. Check here : http://furious-gold.com/help.php BR. |
05-28-2008, 19:28 | #9 (permalink) |
Member: 63172 Status: Offline Thanks Meter: 22 | Many thanks problem solved. For some reason if I run the maintenance from the windows Start menu although it says it has created the key file it but it kept putting in my document and settings folder, even though the shortcut definitely links to the Furious Gold folder. So I tried just double clicking the maintenance icon within the actual (windows explorer) furious gold folder. This time - as Furious Team said above - it generated the key file into the right place. Probably me or my computer doing something odd, but I am recording my solution here only in case anyone else has same problems. Thank you to all above for your help. |
KEY file | Javor | Redbox | 3 | 07-05-2004 14:35 |
Bad Key file!!! | Yashaka | Redbox | 5 | 04-04-2004 18:58 |
bad key file | 1taz | Redbox | 2 | 04-03-2004 22:41 |
kimagsm key file with the prog :)) | ghaithforstar | Motorola Old Legacy (EMMI) | 0 | 06-29-2002 07:18 |
Logomanager 1.21 Key file or crack | Hawk_mate | Nokia Multimedia | 14 | 06-14-2001 17:40 |
