.:hack3r2k:. the_genious man i need help in kg 130 with imei 08000 only [SOLVED] is it possible to repair a kg 130 that has only imei after flashing with full flash file using some other box.when we insert sim set shows sim card registration failed but this phone is not stolen listed on pta site. it looks like this issue is due to damaged eeprom. can i repair it? br hamid |
hello/ any one home? |
full flash the set with this ver KG130P32-30-V10c-202-05 JUN 03 2007+1.mot |
as u have seen imei damaged :) |
where is eeprom file on support area? |
i am trying to flash using a checked lg 7050 cable but softwre hangs on this Press power on ! Starting communication ... i selected kg 130 tried with fidion, choose the correct port, in my case com 3? please need urgent help |
i connected with the trick holding the power key given commmand do job inserting battary with out releasing powqer key for 3 min Press power on ! Starting communication ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Baud rate changed ok ! Flash ID(0): 0001:227E:2100 READING INFO ... WAIT ! (CAN TAKE ~60s) DATE: VUK JUL 24 2007ERATOR: 234-30 VERSION: V10a REVISION: 44 FIRMWARE: KG130P40FL IMEI: 35531101618118400 LOCK: ON Writting flash data ... |
thanks mr. Faheem Anjum my problem is solved with the said version. |
So everything it's ok now ? Br;) |
furious blackberry dongle unlock hi friend i have with the furious blackberry dongle unlock pack 4 the dongle work like pack 3 and no 4 help me please regards slyman007 |
