Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 09-15-2020, 18:14   #1 (permalink)
erocelmaster's Avatar
Member: 630907
Thanks Meter: 100
Exclamation Help please!!! cant repair imei zte blade a5 2020 [SOLVED]
Try repair imei zte blade a5 2020 but not change, showme same imei:
Searching phone;
For an successful connection do the following:
1. Power on the phone and power it off and leave the battery inside
2. Keep pressed firmly volume DOWN key
3. Insert the usb cable inside the phone while keeping pressed volume DOWN
Phone detected (@oem210.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 4.19.38.134)
Preparing to sync;
Port opened [COM21];
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Loader version: Spreadtrum Boot Block version 1.1
Starting FDL2;
FDL2 sent;
Starting auth;
HW IMEI : 000000-00-000000-0
Analysing data; Please WAIT !
OK;
PHONE INFO: NONE
PHONE ID: MDI0YThlODcwMDkwMzVhNg==
BT ADDR: NONE
SW IMEI[0]: 865651-04-007734-3
SW IMEI[1]: 111111-11-111111-9
SW IMEI[2]: 867400-02-031663-8
SW IMEI[3]: 867400-02-031664-6
SIMLOCK FLAG: OFF
Reading NV;
NV saved to : NV_000000-00-000000-0_865651-04-007734-3_98550000_15_09_2020_12_00_32.spd
Gathering security data;
Security check result: 0
Re-programming;
Security programmed;
Sync NV;
Done;
Please helpme, dont change imei.
Old 09-15-2020, 18:49   #2 (permalink)
AgicAga's Avatar
Member: 866455
Thanks Meter: 285
pay attention to the name you are fixing and select that name in the list 0 1 2 3
The Following User Says Thank You to AgicAga For This Useful Post:
Old 09-15-2020, 19:00   #3 (permalink)
Member: 630907
Thanks Meter: 100
Select imei 1, its OK?
Old 09-15-2020, 23:36   #4 (permalink)
Member: 630907
Thanks Meter: 100
Done in "diag mode" but now showme "invalid sim"
Searching phone;
1. Connect the phone powered off with the battery inside to the usb cable
Preparing to sync;
Entering diagnostic mode;
Done;
Chip type: 0000:0000
Platform Version: MOCORTM_18B_W19.10.2_ZLA_P26_Debug
Project Version: sharkl3_pub
BASE Version: FM_BASE_18B_W19.10.2_ZLA_P26
HW Version: sc9863A_modem
06-22-2020 15:22:30
Build number: TEL_MX_P963F50V1.0.0B19
PHONE INFO:
BT ADDR:
SW IMEI[0]: 865651-04-007xxx-x
SW IMEI[1]: 865651-06-007xxx-x
SIMLOCK FLAG: OFF
Done;
IMEI[0] repaired; Remove battery and cable;
Imei change but showme "invalid sim" try select "remove sim lock"
Searching phone;
Preparing to sync;
Done;
06-22-2020 15:22:30
PHONE INFO:
BT ADDR:
SW IMEI[0]: 865651-06-007xxx-x
SIMLOCK FLAG: OFF
BKP saved to : BKP_000000-00-000000-0_865651-06-007734-8_00000000_15_09_2020_17_04_28.spd
SIM_LOCK TYPE: 0
ERROR: Simlock not enabled ! Phone is unlocked;
Please help me, imei repair imei done but now showme "invalid sim" thanks a lot!!!
Old 09-16-2020, 07:43   #5 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 57,445
Cool
Is not ok . Must select IMEI[0] and repair from BOOT MODE !!!!!!! Do that and will work ! And never chnage imei from DIAG mode for secure models
Old 09-16-2020, 18:33   #6 (permalink)
Member: 630907
Thanks Meter: 100
Hi, try in "boot mode" and showme this:
Searching phone;
Preparing to sync;
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Starting FDL2;
FDL2 sent;
Starting auth;
ERROR: Get info failed !
Reading NV;
ERROR: Read NV failed !
Thanks for answer
Old 09-16-2020, 18:43   #7 (permalink)
Member: 15022
Sonork: 100.53452
Searching phone;
Preparing to sync;
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Starting FDL2;
FDL2 sent;
Starting auth;
Reading NV;
Thanks for answer
Power on /off and retry. Must connect same as it connected before
Sent from my iPhone using Tapatalk Pro
Old 09-16-2020, 19:09   #8 (permalink)
Member: 630907
Thanks Meter: 100
Try but showme same outcome, so try instal backup "nvm file" and showme this:
Searching phone;
Preparing to sync;
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Starting FDL2;
FDL2 sent;
Starting auth;
Uncompressing;
Done;
Re-programming;
ERROR: Simlock programming error !
please helpeme
Old 09-16-2020, 19:11   #9 (permalink)
Member: 15022
Sonork: 100.53452
Searching phone;
Preparing to sync;
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Starting FDL2;
FDL2 sent;
Starting auth;
Uncompressing;
Done;
Re-programming;
please helpeme
You do any usb sharing !? Because that can be a problem! Also try to install the drivers from the usb_driver and reboot the pc after.
Old 09-16-2020, 21:03   #10 (permalink)
Member: 630907
Thanks Meter: 100
Hi, will check drivers, reboot PC two times and showme same error "nvm"
Searching phone;
Phone detected (@oem138.inf,%dvcdsc%;SCI USB2Serial) (Driver version: 1.5.6.1)
Preparing to sync;
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Starting FDL2;
FDL2 sent;
Starting auth;
OK;
PHONE INFO: NONE
BT ADDR: NONE
SIMLOCK FLAG: OFF
Reading NV;
Log file saved to: LOG_16_09_2020_14_46_54.txt
Time needed - 00:04:17
Try in "boot mode"
Old 09-16-2020, 21:06   #11 (permalink)
Member: 15022
Sonork: 100.53452
Searching phone;
Preparing to sync;
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Starting FDL2;
FDL2 sent;
Starting auth;
OK;
PHONE INFO: NONE
BT ADDR: NONE
SIMLOCK FLAG: OFF
Reading NV;
Try in "boot mode"
Did you check the phone battery!? Is strange is not connecting since you can see on first post it connected just fine. Pm me ammyy id and pass to connect and check
Old 09-16-2020, 21:10   #12 (permalink)
Member: 630907
Thanks Meter: 100
Sure, teamviewer or what tool use?
Old 09-16-2020, 21:17   #13 (permalink)
Member: 15022
Sonork: 100.53452
www.ammyy.com
Old 09-16-2020, 21:22   #14 (permalink)
Member: 630907
Thanks Meter: 100
ID: 88 590 265
Password:
Old 09-18-2020, 23:42   #15 (permalink)
Member: 630907
Thanks Meter: 100
Searching phone;
Phone detected (@oem113.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 4.19.38.134)
Preparing to sync;
Port opened [COM18];
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Starting FDL2;
FDL2 sent;
Starting auth;
OK;
PHONE INFO: NONE
BT ADDR: NONE
SIMLOCK FLAG: OFF
Reading NV;
NV saved to : NV_000000-00-000000-0_865651-04-007734-3_98550000_18_09_2020_17_34_58.spd
Connecting to server;
Authorisation process started;
Done;
Requesting data from server ! Wait please ...
Re-programming;
Sync NV;
Done;
Done!! Thanks Mr. Hacker, my problem is my PC, try again in new pc format, great tool, great team, thanks a lot!!!
The Following User Says Thank You to erocelmaster For This Useful Post:
Page generated in 0.43457 seconds with 7 queries
