03-30-2022, 16:31 | #1 (permalink) |
Freak Poster Join Date: Jun 2004 Location: TUNISIA Age: 38
Member: 68330 Status: Offline Thanks Meter: 49 | help to unlock lm-q730tm Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5490 Searching phone in emergency mode; [connect the phone in "Firmware Update" Mode. Hold the Volume Up on the powered off phone and enter the USB cable in order to enter it] Phone detected (USB\VID_1004&PID_6000&REV_0409) Preparing to start flash mode; Preparing to open COM72 Opened; Authorising; Authorized; LAF_ERROR_ACCESS_DENIED download_cable = 910K battery_level = 23 download_type = download_speed = 0 usb_version = UHS hardware_revision = rev_11 download_sw_version = device_sw_version = Q730TM10y secure_device = S laf_sw_version = 1.1 device_factory_version = LMQ730TM9AT-00-V10y-310-240-DEC-17-2021-ARB00+0 device_factory_out_version = LMQ730TM9AT-00-V10y-310-240-DEC-17-2021-ARB00+0 pid = VH03S201217001486 imei = 354590118802778 model_name = LM-Q730TM device_build_type = U chipset_platform = mt6765 target_operator = LAO target_country = COM ap_factory_reset_status = 6 cp_factory_reset_status = 0 isDownloadNotFinish = 0 qem = 0 cupss_swfv = A1639711501-M1639711501-FFFFFFFFFFF-U1639714956-0 is_one_binary_dual_plan = 0 memory_size = 122159104 memory_id = G1J9P8 bootloader_ver = MiniOS 3.0 islan_download = 0 skip_readwrite = 0 Starting; Setting secure mode; Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Getting security info; Setting secure mode; Done; Reading security; Done; Checking security; Phone it's going restart several times during this step; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. ERROR: Scan port failed ! - Repeat the operation keeping pressed volume up during the whole procedure !!! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; This phone may require firmware downgrade !!! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. ERROR: Scan port failed ! - Repeat the operation keeping pressed volume up during the whole procedure !!! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. ERROR: Scan port failed ! - Repeat the operation keeping pressed volume up during the whole procedure !!! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Contents saved to : C:\furious\SEC_BKP_LG LM-Q730TM_NA.osp Working; Connecting to server; Authorisation process started; Furious Multipurpose Credits: 1 Done; Requesting data from server ! Wait please ... Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; IMEI A: NA IMEI B: NA IMEI C: NA WiFi ADDR: 00:00:00:00:00:00 BT ADDR: 00:00:00:00:00:00 LOCK STATUS: Unlock codes: NCK: NSCK: SPCK: CPCK: SIMCK: Enter the codes without a sim by using *#*#7465625#*#* Done; ERROR: simlock_status Failed ! Starting Re-init operation; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Erasing; Re-init operation completed; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Operation completed ! Setting secure mode; Done; Time needed - 00:07:11 |
03-31-2022, 07:54 | #2 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | Hello have you read this This phone may require firmware downgrade !!! |
The Following User Says Thank You to Fast Unlocker For This Useful Post: |
