08-27-2020, 18:53 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: in the web Age: 41
Member: 630907 Status: Offline Thanks Meter: 127 | Hi!!! try unlock motorola e6 play (xt2029-1) not worck Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (PreLoader USB VCOM (Android) (COM27)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739 Sw version: Hw Version: alps-mp-p0.mp1-V5.194_ontim.p0mp1.k39tv1.64.bsp_P4 RESULT: BootROM start command passed, but target has no response until timeout ERROR: BOOT_PHONE; Time needed - 00:01:19 Try read memory but showme this: Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM (Android) (COM27)) (Driver version: 1.0.1121.0) Preparing to start flash mode; Preparing to open COM27 Connecting; Downloading DA; Initializing; ERROR: STATUS_BROM_CMD_SEND_DA_FAIL ERROR: BOOT_PHONE; Please help me, thanks a lotˇˇˇˇ |
08-28-2020, 22:14 | #3 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Bogotá Colombia Age: 43
Member: 150844 Status: Offline Thanks Meter: 309 | Same error here Moto e6 play xt2029-1 cant boot Code: Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM9)) (Driver version: 2.0.0.0) Preparing to start flash mode; Preparing to open COM9 Connecting; Downloading DA; Initializing; ERROR: STATUS_BROM_CMD_SEND_DA_FAIL ERROR: BOOT_PHONE; Code: Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (PreLoader USB VCOM Port (COM9)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739 Sw version: Hw Version: alps-mp-p0.mp1-V5.194_ontim.p0mp1.k39tv1.64.bsp_P4 RESULT: BootROM start command passed, but target has no response until timeout ERROR: BOOT_PHONE; Time needed - 00:01:03 Log file saved to: LOG_28_08_2020_16_07_42.txt |
09-26-2020, 22:32 | #4 (permalink) |
Insane Poster Join Date: Aug 2009 Location: USA, Texas Age: 33
Member: 1089253 Status: Offline Sonork: 100.1659642 Thanks Meter: 8 | Same for me, not work Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MediaTek USB Port (COM27)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739 Sw version: Hw Version: alps-mp-p0.mp1-V5.194_ontim.p0mp1.k39tv1.64.bsp_P4 RESULT: BootROM start command passed, but target has no response until timeout ERROR: BOOT_PHONE; Time needed - 00:01:05 Log file saved to: LOG_26_09_2020_15_29_23.txt |
11-02-2020, 11:18 | #5 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Bulgaria Age: 53
Member: 1559599 Status: Offline Thanks Meter: 222 | Hello please check moto XT2029 Remove sim lock Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MTK USB Port (COM18)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739 Sw version: Hw Version: alps-mp-p0.mp1-V5.194_ontim.p0mp1.k39tv1.64.bsp_P4 RESULT: BootROM start command passed, but target has no response until timeout ERROR: BOOT_PHONE; Time needed - 00:01:10 Log file saved to: LOG_2_11_2020_12_05_23.txt |
11-02-2020, 11:18 | #6 (permalink) |
11-02-2020, 11:19 | #7 (permalink) |
11-02-2020, 11:19 | #8 (permalink) |
11-16-2020, 19:23 | #9 (permalink) |
Major Poster Join Date: May 2014
Member: 2178983 Status: Offline Thanks Meter: 0 | Using library Brom_DLL_v7.1813.3 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MediaTek USB Port (COM58)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739 Sw version: Hw Version: alps-mp-p0.mp1-V5.137.2_ontim.p0mp1.k39tv1.64.bsp_P5 RESULT: BootROM start command passed, but target has no response until timeout ERROR: BOOT_PHONE; Time needed - 00:01:01 Log file saved to: LOG_16_11_2020_21_18_58.txt |
