02-21-2022, 07:59 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 36
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | how to change language in nokia ta 1174/ after flash INVALID IMEI For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly the boot key 3. Insert the usb cable inside the phone while keeping pressed 4+7 keys Phone detected (@oem119.inf,%dc_diag%;SPRD U2S Diag) (Driver version: 1.0.0.21) Preparing to sync; Port opened [COM30]; Mobile type: Spreadtrum Boot Block version 1.2 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.2 Starting FDL2; FDL2 sent; Chip type: 6562:0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000 [000060824699945E:0000] Reading phone info; PHONE INFO: 20.00.17.01_MD23KIG74MY00 BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 357 SW IMEI[1]: 35 SW IMEI[2]: 358 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: OFF FIXED NV BASE: 103A0000 Uncompressing; Done; Re-programming; Programmed bootloader matches security settings; FLS programmed; Done; Remove battery and cable; |
